Question about Compaq Keyboard
I turned my keyboad over to bang the dust out. Now a light is on in the upper right corner. It does not have a letter, just small triangle pointing down with a small line under. Does this hurt anything, what does it do? How can I cut the light off or do I need to? tks, bc
  • bcee1 Feb 01, 2010
    Tks very much. bc
  • 687 Answers
This is the scroll lock all that has happened is that the button has been pressed. Its on a toggle just press it again to make the light go OFF.
The Scroll lock is next to the PrintScrn and Pause Buttons
Posted on Feb 01, 2010
I cannot look back my photos i have taken on camera
Press the MODE button to enter the playback mode. A right-pointing triangle will appear in the upper-left corner of the screen.
Full details are in the "Playback Mode" section of the manual, beginning on page 14.
Jul 31, 2011 | Vivitar ViviCam 5024 Digital Camera
The background light comes on when placed in the vertical. I need to turn it off to save battery life
The Auto Light feature of your watch has been turned on. To turn it off, press and hold the button that is on the bottom right of your watch for about 2 seconds. In the upper right of the face of your watch is a circle with some text on it. There should be a down pointing triangle in the upper right of that circle. Below that triangle there should be a dark mark before you turn off the auto light. After you hold the lower right button down for the 2 seconds that dark mark should turn off. The Auto Light feature will also turn itself off after six hours to help you to conserve your battery life.
Mar 25, 2011 | Casio Sport Watch White Resin Watch for...
Exclamation point in triangle blinking on dashboard
Hi, The exclamation point in triangle blinking is the "Emergency Blinker" This blinker turns on all all of the turn signal lamps at all four corners of the car. Left and Right, Front and Back. The triangle represents the European symbol for roadside emergencies. In fact on European Mercedes and other cars there is a triangle shaped reflector you can put behind the car so that other drivers know you have an emergency. THAT TRIANGLE ON YOUR DASHBOARD IS A BUTTON. PUSH IT ONCE. THE BLINKING SHOULD STOP. If you have a roadside emergency, and are broken down by the side of the rode. Push the Red Triangle and your lights will blink on and off ouTside to say, in effect "help".
Hope this helps.
Best,
Mark
Jan 13, 2011 | 2005 Mercedes-Benz C-Class
How do i view pictures taken no info with my purchase
Press the MODE button until a right-pointing triangle in the upper-left corner indicates playback mode.
Full details are in the "Playback Mode" section beginning on page 37 of the manual.
Jan 11, 2011 | Vivitar Vivicam 8225 Digital Camera
What do i press to view my photos my camera is a vivicam5024
Press the MODE button until you see a right-pointing triangle in the upper-left corner of the LCD.
Jan 04, 2011 | Vivitar ViviCam 5024 Digital Camera
How do i look through the pictures on the camera ?
Press the HOME button until a right-pointing triangle in the upper-left corner of the screen indicates playback mode. Full details are in the "Playback Mode" section beginning on page 30 of the manual.
Sep 18, 2010 | Vivitar ViviCam X327 Digital Camera
How do i view my photos on my camra, vivitar 8225?
Press the MODE button until the right-pointing triangle in the upper-left corner indicates playback mode. Full details are in the "Playback Mode" section beginning on page 37 of the manual.
Jul 04, 2010 | Vivitar Vivicam 8225 Digital Camera
Hello, When typing on my Mo Droid if I want my caps to stay on how do I get that to work.....I tried holding it down but maybe I am not doing it properly?
If you are typing using the touchscreen, the upper-case arrow, touched once, will upper-case the next letter you type and then back to lower case. It you touch the upper-case arrow twice in a row, you should see a green light come on directly over it. That keeps the caps lock on.
If you are using the slide-out keyboard, touch the upper case key once and you should see a triangle underneath the cursor on the screen. That will upper case the next letter you type. To get it to stay in upper case, hit the upper case button again and the triangle should change to a > symbol, point up, underneath the cursor. That should keep it in upper case mode. Don't hold the upper case button down, as that won't do anything. A third press returns it to normal (lower case).
Jun 14, 2010 | Motorola Mobility Droid (2 GB) Cell Phone
Dust on Drum
The corona wire can be cleaned as follows:
Take the cartridge out of the printer.
As you are holding it in the same position as you took it out of the printer, in the uppper right hand corner there will be a small light blue / purplish tab with a triangle on it. The triangle points to another triangle on the black part of the cartridge.
Slide this blue tab back and forth several times. You have just cleaned your corona wire.
Make sure you slide the tab all the way back over to the right before putting the cartridge back into the printer.
Jul 18, 2008 | Brother MFC-7820N Laser Printer
How do you make you r letters capitol on sign in page for email
You can make the letters capital just by pressing "0" key
"0" key here works as a SHIFT key of computer
You will notice that when you press this key, there is a
change in upper right corner, for example look like this:
"abc" All small letter
"Abc" First capital and others small
"ABC" All small letter
Jan 14, 2008 | Cell Phones
Compaq Keyboard Logo
16 people viewed this question
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
