Question about Sanyo DP42746 42 in. Plasma Television
Broken jack i was just moving my tv when the jack to the cable broke ,is there any other way i can use it ?? and can it be fixed
    Genius:
  • Sanyo Master
  • 1,689 Answers
Sanyo has support for their products. You will have to find out who the authorised service rep is in your area. They may have to change the tuner module if the connector is part of the tuner if there is a lot of internal damage. Some models of sets have a secondary module outside of the tuner where the connector is mounted. This would be lower in cost to service.
Unless you are experienced in TV service, I do not suggest that you try to service this yourself.
Jerry G.
Posted on Apr 12, 2008
Coaxial input jack on the coby tv broke off
yes but you will have to replace the mainboard.
Jan 30, 2013 | Televison & Video
The cable hook up on the TV broke off.
Yes...You may have to buy a new RF connector and replace. This will take some very good patience or purchase a new complete tuner. If you are not in a hurry for the tech shop. Use the rca jacks on the tv to a cable or satellite box. Just be sure when you power off you tv, that the tv is really off. A blank raster will look as if it is shut down for the time being! Good Luck!
Nov 29, 2009 | Panasonic PT-50LC14 50" Rear Projection...
Cable connector broke off in back of tv
had same problem virtually impossible fix if broke off if you have rca plugs use vcr thats what i did!
Jun 30, 2009 | Televison & Video
My cable jack broke off
You have to tin weld one back onin its place this will work as i done it myself
thanks
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
May 02, 2009 | Sylvania SRT2432S TV
TV ANT Jack Broke off and lost cable viewing
Yes it can be replace only if it just a connector adapter connected independently unto tv tuner. But if it is with the tv tuner as a whole. You will replace the entire tv tuner. Just bring the part as reference to your favorite electronic store selling tv parts.
Apr 11, 2009 | RCA Alert Guard 20" Flat Screen 20F670T...
Inputs cable broke off into my input packs
You might be able to fix it yourself. Input jacks vary some you can use a pin or straighted paper clip to push the broken cable out. Remove the screws on the back (you my need to disconnect the speaker). If the jack is accessible (some are sealed ) using the clip or pin try to push it out from the back side of the jack.
If that doesn't work you are looking at about $50 to $70 replace the jack.
Mar 08, 2009 | Audio Players & Recorders
Cable jack on tv broke off
This is clearly not your fault! and sounds like a defect in the manufacturing process happend to this part!! if you used your fingers THIS PART SHOULD HAVE NEVER BROKE!!
hope this helps
Feb 12, 2009 | Panasonic CT-27D12D 27" TV
Cable connection part broke off in back
Are you talking about the part that connects the cable from the wall to the tv? I do not really understand which part on tv or vcr. It is true you can use the vcr as the tuner. You still have to connect the cable from the wall to the input cable jack on back of vcr. Then you hookup the R/W/Y rca plug- in cable from the back vcr output jacks (which are also color coded) to the tv's jacks. If you only have two jacks on the tv they will probably red and black. It doesn't really matter. Go from your video output on the vcr to the video input of tv, then use one of the audio outputs on vcr and go to the audio input on tv. It should work like that.
Jan 14, 2009 | Philips Magnavox DVD/VCR Dual Player
Jack
Yes, this is an easy problem for a technician to repair, especially if you still have all the broken parts. If nothing else, he can simply install a new jack anywhere on the back of the TV - if he has to order the exact replacement part, it will increase the cost dramatically and take much longer. If you're okay with a quick fix that "will work", anyone handy with a soldering iron can fix it.
Jan 02, 2009 | Sylvania 6427TE 27" TV
Coaxial Imput Jack Is Broke
Use your external jacks yellow red/white on video1 this will work other wise replace SSB board it cost 292.00
Sep 07, 2008 | RCA D52W19 52" Rear Projection Television
Sanyo DP42746 42 in. Plasma Television Logo
43 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
