Question about Samsung 50" Slim-Depth DLP HDTV
When I try to cut on the TV all 3 indicator light start to blink.
  • 69 Answers
Listen to the tv from the rear you should hear a slight wind up of the colorwheel just after the power button is pressed. after that the lamp ballast should attempt to start the lamp . if the lamp is bad you will hear a buzzing and see no light coming from the lamp door. if you dont hear that winding up of the colorwheel its bad and needs to be replaced
Posted on Feb 07, 2010
Standby light blinks and tv wont cut on
How many times the standby light at its front panel blinks? Count it. These blinks are fault indications. Check this link for more details about Sony Blinking codes. Count the blinks that occur once, after switch the TV On by its front panel power switch. Check it.
Jan 02, 2013 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Samsung s50hw-yb01 red lights blinks 6 times
Google the model number with "error codes" or 6 blinks or as last resort call Samsung customer service
All blink codes indicate something wrong in the set and are only general in nature--will not of course say replace this specific part.
Apr 09, 2012 | Televison & Video
My LCD Sony KDF-60WF655 Powr/Standby light started to blink and automatically cut off after 10-15 minutes of being on -- the cooling fan comes on and then it powers back on. Now it is happening about...
The Standby/Power light of the TV blinks when there is any internal malfunction in the TV. The self-diagnostic function of the TV will cause the STANDBY light to blink or flash when the television detects an issue. The number of times the STANDBY light flashes corresponds to a specific issue.
Few examples are given below; some of the issues may be resolved without the need for service.
1 blink / 2 blinks / 5 blinks: - This indicates that there may be a power-related problem with your set.
3 blinks: - This indicates that there may be a power-related problem with your set. The set will need to be serviced to allow a technician to determine the specific issue that needs to be repaired. If the power light flashes three times in sequence in a Lamp TV, the lamp cover is not securely attached. Reattach the lamp cover to resolve this issue.
4 blinks: - This indicates that there may be a back light or lamp power problem.
6 blinks: - This indicates that there is some kind of audio problem with your set.
7 blinks: - This indicates that there is a temperature problem with your set. Please check to make sure that the air vents on the sides and back of the set are not blocked or clogged and there is adequate ventilation around the television. We recommend that you check and clean the vents periodically to make sure the set receives adequate air flow. If the problem continues, the set will need to be serviced.
8 blinks: - This indicates that there may be a video-related problem with your set. If the flash sequence is not listed above or the light continues to flash, follow the steps below to perform a power reset:
Try the following steps to check if the issue can be resolved.
Turn off the television.
Unplug the television power cord from the electrical outlet.
Let the television remain without power for 60 seconds.
Plug the power cord back into the electrical outlet.
If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
If the issue continues to occur, service may be required.
Thanks for using Fixya.
Jul 28, 2011 | Sony KDF-E60A20 60 in. LCD HDTV
Power light is red and flashing. when we press the power button it sounds like it's trying to power on the light turns to flashing green for a few seconds and then the power cuts off and turns back to...
Flashing red light in Sony tv indicates that tv got some internal problem and went on protection mode to avoid further damage. Now it needs service/ repair.
Blinking red light also has an error code that has info about possible cause of problem, let me know how many times red light is blinking after 3 seconds ling pause and model number of your tv to provide you helpful info.
Thanks.
Feb 23, 2011 | Sony KDS55A2000 55" HDTV
What is the code for philips tv using RCA universal remote control ??
just follow the steps below
1. Manually turn on the TV.
2.Press and hold the CODE SEARCH button until the
INDICATOR LIGHT lights, then release the CODE SEARCH button.
3.Press and release the TV button (The INDICATOR LIGHT will blink then remain lit).
4. Enter the code using the Number Buttons. After your code is entered, the INDICATOR LIGHT will turn off.
code list for philips :
003, 004, 008, 012, 019, 062,068, 069, 075, 076, 086, 087, 088
5. Aim the remote at your TV and press the ON•OFF button. Your TV should turn off.
6.With your TV on, press CH+. If the TV responds, no further programming is required.
if it works ignore the following thing (quite difficult and irritating one)
1. Press and hold CODE SEARCH until the INDICATOR LIGHT lights, then release CODE SEARCH.
2. Press and release the device button for the device’s code you are retrieving (TV). The INDICATOR
LIGHT will blink once then remain lit.
3. Press and release CODE SEARCH. The INDICATOR LIGHT will turn off.
4. Starting with 0 on the keypad,
press the number buttons in
order (0-9) until the
INDICATOR LIGHT blinks.
5. The number which causes the INDICATOR LIGHT to blink is the first digit of your code.
6. Repeat step 4 until you have
retrieved all three numbers in code
if you want code list for all devices
download this pdf
Jun 14, 2010 | Televison & Video
What is the code to use for universal remotes
i found that your brand is not RCA universal remote code list..
if your are using RCA controller follow the steps below
SEARCH.
2. Press and release the device button for the device’s code you are retrieving (TV,VCR or
DBS•CABLE). The INDICATOR LIGHT will blink once then remain lit.
Note: For AUX, press DVD•AUX
then the device button for the
code you are retrieving.
4. Starting with 0 on the keypad, press the number buttons in order (0-9) until the
6. Repeat step 4 until you have retrieved all three numbers in code
if you are not having RCA controller or the method above is not works then buy new GE universal remote
solution using GE controller
1. Turn on the device you wish to program.
2. Press and hold CODE SEARCH/SETUP until the INDICATOR LIGHT lights, then release.
3. Press and release the device button for the device you are programming (TV, VCR, DVD, etc.). The INDICATOR LIGHT will blink once then remain lit. For AUX, press AUX then the device button you are assigning to AUX.
i hope this will work
regards,
cseian
May 01, 2010 | Vivitek V37655 56" DLP TV
Lost remote control. have universal RCA and
i found that your brand is not listed RCA code list,
your G&E remote is good one and easy to detect code for your tv.
solution
using your GE remote :
1. Turn on the device(TV) you wish to program.
3. Press and release the device(TV) button for the device you are programming . The INDICATOR LIGHT will
using your RCA controller:
SEARCH.
i hope this will solve your problem
regards,
cseian
Apr 22, 2010 | Durabrand DWT2704 TV
Need a remote code
I am sorry to say that your brands are not listed in code list..
but try these codes : 456, 458,026,820,487
or run code search
SEARCH.
remain lit.
Mar 15, 2009 | RCA Universal Remote 3 Device Remote...
Blinking power indicator light
When TV indicator light is blinking and after that the power will cut off. First you need to check the power board. But I am still need more details of your tv. please call 323-767-6030 and I will go through thes trouble-shooting, with you.
Mar 08, 2009 | Astar LTV-32HBG 32 in. LCD Television
Samsung 50" Slim-Depth DLP HDTV Logo
493 people viewed this question
Henry  Thomas
Henry Thomas
