BT49QT-9R scooter manual
I bought a BT49QT-9R 50cc scooter (Baotian Escuta City) secondhand without a manual.
Where can I download a user manual?
    Scholar:
  • 125 Answers
Posted on Feb 01, 2010
I have a cpi Oliver city scooter on the starter relay is a black and red wire witch is normal but there is two wires with have been cut and the leccy start won't work but everything else dose
Hi, Nathan for this scenario you will need your service/owners manual if you can't find the first and best tool you ever bought for your CPI, despair not, for a mere $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
Scooter Troubleshooting Scooter won start All about Scooters
Scooter electric start doesn work scooters
http://www.scootermasters.com/manuals/CPI%20Cheetah%20XS%20Service%20Manual%202t.pdf
http://www.family-motorsports.net/GY6-50cc-150cc.pdf
CPI OLIVER CITY Owner Manual
Jun 29, 2016 | Cpi Motorcycles
Hi I have a Baotian 50cc bt49q 9r. Bike won't start I've cleaned the carb drained old fuel etc, bought a new battery and a new spark plug.CDI might be faulty which I have ordered or the coil pack ?
Hi, Neil and the usual suspects are:
1. Fuel tank empty.
2. Fuel supply valve/petcock turned off.
3. Fouled spark plugs.
4. Engine flooded as a result of overuse of the enricher.
5. Vacuum hose to the fuel supply valve/petcock disconnected, broken, cracked, or pinched.
6. Fuel valve/petcock or filter clogged.
7. Discharged battery, check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
8. Loose or corroded wire connection at the coil, battery or plug between ignition sensor and module.
9. Spark plug cables in bad condition and shorting, cable connections loose, or connected to the wrong cylinders.
10. Ignition timing incorrect due to a faulty ignition coil, ignition module or sensors (MAP, CMP, CKP, O2 and/or BAS).
11. Security alarm needs a reset.
For more information about your issue and free downloads that you will need please visit the websites below. Good luck and have a nice day.
cranks but wont start
Tao Tao 50cc Scooter Won Start SOLVED REPLACE CARBURATOR
http://www.baotian-scooters.net/wp-content/uploads/2012/11/baotian-rocky-service-handleiding.pdf
Feb 01, 2016 | Motorcycles
Why does my baotian bt125t-12 evolution scooter cut out at 5000 rpm?
Hi, Darrell and the usual suspects are:
1. Severely discharged or a damaged battery must have 12.5 volts or more and be able to pass a proper "LOAD" test if necessary, you may have a preliminary reading of 12.5 volts or more but little or zero amperage the battery is faulty and must be replaced, AGM batteries fail in this scenario more so than lead acid batteries.
2. Faulty alternator/generator and or voltage regulator.
3. Loose or corroded battery terminals and or cables especially the "NEGATIVE" cable, look for loose, corroded, or broken connectors inside the cable harness at "BOTH" ends.
4. Faulty main circuit breaker or ignition switch, check for loose connections and continuity.
5. Faulty system and or ignition relay, check for continuity.
6. Faulty ignition coil, ignition/electronic module.
7. Faulty CKP, CPS, CMP, MAP, TPS, or BAS sensor, corroded, loose or broken wire connector pins/sockets.
8. Throttle cables and or idle speed improperly adjusted hot idle speed should be 950 RPM to 1000 RPM.
9. Faulty neutral, side stand or clutch lever safety switch.
10. Fuel tank empty
11. Fuel tank contaminated with ethanol sludge.
12. Water or dirt in the fuel system, or clogged filter.
13. Restricted, blocked or kinked fuel line.
14. Faulty fuel pump.
15. Faulty pressure regulator.
16. Faulty or clogged fuel injectors.
17. Lean angle switch is faulty or needs adjustment.
For more information about your issue and valuable "FREE" downloads that you need please click on the blue links below. Good luck and have a wonderful day.
Bike cutting out at Full Throttle 50cc Scooter
Troubleshooting
Baotian Classic Service And Repair Manual Part 1 of 2
Baotian Classic Service And Repair Manual Part 2 of 2
Baotian BT125T 12 Evolution 125cc
Baotian BT49QT 11 User Manual
Jun 16, 2017 | Motorcycles
Lost keys for a 2010 cpi Oliver sport 50cc how to hotwire @
Hi, Michael for more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
How to Start your scooter without keys
How to hotwire Chinese Scooter
http://fullmanuals24.com/brand/cpi
CPI Scooter Parts Racing Planet USA
Dec 21, 2014 | 2010 Cpi Oliver Sport
Where is spark plug located
Hi, Anonymous sorry you can't find the first and best tool you ever bought for your CPI despair not for a mere $0 you can download another one. For more information about your issue and free downloads that you will need please visit the websites below. Good luck and have a nice day.
CPI Oliver Sport
How to change spark plug in Yamaha Vino 50cc Scooter XC50
http://absolutelyscooters.net/service-manuals.html
https://scootergrisen.dk/scooterhjemmeside/download/cpi_oliver_brugermanual.pdf
Apr 07, 2013 | 2011 Cpi Oliver City
I have a 2010 cpi oliver city scooter and i cant get the drive belt on
Hi, Mikeaspearman sorry you can't find the first and best tool you ever bought for your CPI despair not for a mere $0 you can download another one. For more information about your issue and free downloads that you will need please visit the websites below. Good luck and have a nice day.
50cc 49cc Scooter Performance Clutch and Variator install variator roller...
How To Change Moped Scooter Drive Belt CVT
Jun 20, 2012 | 2011 Cpi Oliver City
How do you set up an 06 cpi oliver city 125 carburetor?
Hi, Peter sorry you can't find the first and best tool you ever bought for your CPI despair not for a mere $0 you can download another one. For more information about your issue and free downloads that you will need please visit the websites below. Good luck and have a nice day.
CPI Oliver City 50cc problems 49ccScoot com Scooter Forums
Cpi oliver City
CPI Oliver City 125 2006
Feb 12, 2012 | 2006 Cpi Oliver City 125
My aunt recently bought a secondhand scooter shoprider us pat no 4798255 without a users manual and the scooter will not charge please could you help?
Kathryn Was the scooter working when she bought it? If the batteries were fully charged and now it won't charge then I would suspect the charger. If the scooter wasn't charged when she got it and won't charge then I would replace the batteries Hope this helps
Apr 25, 2011 | Health & Beauty
Computers & Internet Logo
995 people viewed this question
David Payne
David Payne
