Question about Dryers
Check lint light on replaced thermal fuse 2x blew again??
I am losing my mind...please help...the check lint light came on, dryer would not run, replaced thermal fuse, worked for 2 loads...cleaned vent, lint area replaced again, ran for several days, was hot to touch on side of dryer on jeans button, now blew again...what is causing this and how do i fix it?
  • bulldglady Feb 01, 2010
    sorry, this is a electric dryer...single mom of 2 laundry piling up!!! Help...where is the airflow sensor located?
  • 111 Answers
It would be nice to know if it's gas or electric, I think it may be an airflow sensor switch,clean or replace switch
Posted on Feb 01, 2010
Testimonial: "I will try to find the airflow sensor, thank u"
Thermal cutoff switch fails 2x in a year. Heating coil ohms out ok.
Whirlpool Thin Twin, dryer thermal cutoff failed twice - Appliance ...
forum.appliancepartspros.com > Appliance Repair Help > Dryer Repair
Oct 12, 2011 - 6 posts - ‎2 authors
Friends Whirlpool Thin Twin came with purchase of condo half a year ago. A month ago it stopped heating. I checked continuity and found the ... Whirlpool Dryer Thermal Cutoff
Jan 9, 2013
Thermal cutoff blew again (Whrpl Elect Dryer)
1 post
Jan 5, 2013
More results from forum.appliancepartspros.com
Why does the thermal fuse keep blowing in my dryer ...
www.shopyourway.com > Manage My Life > Questions
Dec 28, 2015 | Dryers
Dryer stopped working
blew a thermal shut off thermostat, but replacing it will not suffice as u need to find out why it blew? the fuse is located on the blower usually has 2 prongs connected. You may have a bad venting problem or clogged blower and lint screen , check for lint build up.
Mar 01, 2015 | Dryers
Sears 417.80042990 keeps blowing thermal fuse
Did you clean out the lint filter at the front, heat is the enemy. Clean out all lint from front, if you are handy, get around back and remove all lint and dust by blowing compressed air.
Sep 21, 2012 | Frigidaire FEQ332E Electric Dryer
I replaced the thermal fuse because there was no heat. Now the dryer over heats and shuts off. Everything checks ok on ohm meter. The timer works in the "no heat" mode. Could it be the timer...
after you changed the thermal fuse did you clean out the dryer and the vent line?if not you blew the fuse again and it will keep doing this until you clean out the duct that the lint filter slides into,vac and blow out the motor and the cabinet where the motor is and blow out the vent line,if it's a long run remove the vent line from the back of the dryer and blow it out with a leaf blower.the dryer went over 300 degrees from lint buildup and popped the thermal fuse,it's a safety so the dryer doesn't run hot and start a fire.if the dryer is running and sfter like 20 minutes it shuts down and won't start for a while until it cools down then the motor is bad also probably from the dryer running to hot from the lint build up.
Apr 08, 2011 | Amana DLE330RAW Electric Dryer
My Kenmore Elite dryer just quit heating up...is it the heating element or possibly a fuse? The lint trap had qite a bit of lint in it..maybe it just over heated and blew a fuse?
There is a thermal sensor attached to the housing of the heating element, you can check the thermal sensor by jumpering the two wires to the thermal sensor together, and then run the dryer and see if the heating element is now working, if the dryer is now heating up then replace the thermal sensor.
May 10, 2010 | Dryers
Entire vent system cleaned (was really bad). Purchased thermal fuse and thermostat kit la-1053 . Motor spinning fine as well as the air wheel is tight. Removed tumbler unit, checked tension pulley, motor,...
Did you clean the exhaust from the wall behind your dryer to the outside. This is more important than the dryer exhaust system itself. If not get behind dryer and remove exhaust to the wall and using a leaf blower,(electric) put it inside house vent then push dryer back to hold in place go outside and watch to see what all blows out. Good luck.
Jan 29, 2010 | Dryers
I replaced the thermal fuse and it blew again shortly after.
The main cause for thermal fuses to blow is a restricted airway. You need to make sure that your path for airflow is clear:
Check your dryer hose: make sure it is clear of debris inside, make sure it is not kinked when the dryer is in place.
Check your dryer vent: some houses and apartments have a fairly long dryer venting system before it reaches outside.
Check your dryer: just after the lint trap and prior to the blower motor is a common place for a blockage. You may have to take the front of the dryer apart to get to it. I have seen all kinds of things get passed the lint filter.
Each of these things would cause even a new thermal fuse to blow quickly. A combination of them could easily do that. The thermal fuse is the dryer's safety cut off, preventing your dwelling from burning down from an out of control dryer. So it's all about airflow, airflow, airflow.
Oct 26, 2009 | Whirlpool Dryers
My whirlpool duet dryer stopped working 20 minutes into normal mode and wont steart again any help would be appriciated
probably blew the thermal fuse your dryer and lint hose is probably full of lint and took out the fuse ... getting too hott. whirlpoolpartssurplus.com
Jun 29, 2009 | Whirlpool GEW9250 Electric Dryer
Hotpoint NVL333EY Electric dryer blows thermal fuse
I had the same thing happen, I replaced the thermal cutoff and made sure no lint build up. It lasted a week then blew again. I then replaced it again and got to thinking why it would blow. I then took apart the exaust inside the dryer running fron the drum to the motor and right before the motor was a build up of lint ane particals that was almost like compressed sawdust which was blocking half of the line. I cleaned this out and it seemed to work much better.
Jan 04, 2008 | Hotpoint NVL333EY Electric Dryer
Dryers Logo
81 people viewed this question
Top Dryers Experts
