Question about Briggs & Stratton 15,000 Watt Home Standby Generator
Where can I buy a replacement engine?
Where can I buy a replacement engine for a model #01815 briggs 12kw generator? The engine family is 1BSXS6272HW
    Champion:
  • 243 Answers
Go and have a look at smallenginewarehouse.com
Posted on Feb 27, 2010
B&S Model 040229 12kw has LCD display with 9999 code, what does it mean. It had a dead battery
Fault codes on this unit are usually 1 thru 8, or FC_1 thru FC_8.
You will need a usable battery installed for the control panel to operate. If you still get 9999 with a good battery, you will need to test it with a known good control panel, which may be the problem.
May 11, 2014 | Briggs & Stratton 15,000 Watt Home Standby...
I have a problem with the carburator at my coleman powermate pro gen 5000, where i buy this carburator on line. thanks
To find the correct part on line, first determine the engine model number and code stamped or labeled on the engine fan cover. For example will be Briggs, or Honda etc. Once you determine the Engine brand and model number, you can go to a web address like Jacks small engine, or even ebay or a replacement part or carb kit. May be easier to take the engine information to a mower repair shop in your area for a replacement. The engine on your generator is similar to one used on lawn equipment. Good luck
Aug 02, 2011 | Coleman Powermate Powermate 5000W...
Briggs & Stratton 12KW Model 040229 LPG Generator. 96 Volts @ the 120 Volts outlet, When I turn the house 2 Ton AC voltage increase to 106 Volts.
Can you manually adjust the voltage on the generator without load?? If you have 120/240 60hz output on it and you are not overloading the unit (amperage), then it may be as simple as adjusting whats called your gain setting for your voltage regulator. Obviously you are seeing what happens when it is set too low. Trying raising that setting until it becomes unstable then back it off. Unstable meaning voltage starts jumping all over.
Jun 27, 2011 | Briggs & Stratton Briggs Stratton 7 kW...
Recoil starter spring has unwound Briggs & Stratton 4 HP mower motor
you can buy the whole recoil + pull cord ready to install ,or have a small engine shop rewind it if you cant. some times the tab that held it breaks and you have to replace it.
Mar 06, 2010 | Briggs & Stratton Power Products 5,550...
I have a new Kohler 12kw res generator on propane - backfiring
Is the outside air temp cold. These generators will backfire if it is real cold and if the propane pressure is low. It is suppose to be 11 to 12 inches of water colume at the generator fuel input. drygwals
Feb 18, 2010 | Kohler 12 kW Emergency Power System -...
No charging voltage to battery
You can test the charger right at the battery. With the system just sitting in regular stand-by mode. If you lift the battery leads, they should have about 13.5 volts coming in from the trickle charger. If there is no voltage there, it can't charge. It would be a bad trickle charger.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Feb 09, 2009 | Briggs & Stratton 15,000 Watt Home Standby...
Briggs & Stratton 15,000 Watt Home Standby Generator Logo
150 people viewed this question
Top Briggs & Stratton Electrical Supplies Experts
John Trevino
Falcon52
Level 1 Expert
Craig Butler
Craig Butler
Are you a Briggs & Stratton Electrical Supply Expert? Answer questions, earn points and help others
