Computer won't stay powered on
I normally leave my computer on. I recently started turning it off at night because one of my associates told me that leaving it on all the time shortens the life span. Well................ lo and behold, I hit the power button to turn it on two days ago and Nothing happened. It wouldn't come on. So today I decided to fix it. I took it apart and blew away the dust and made sure all the wires were still connected. They were. I discovered that if moved the wires coming from the power button, it would come on, but not STAY on. The wires are connected but must be loose. Can you help me?
Thanks
  • MississippiJ Feb 18, 2008
    It's a Compaq Presario S4120WM.
Hoss and Guest is wrong.... You need to yurn your computer off only if you are not going to be using it for at least a week. BECAUSE Electricity is going up a lot and you should try to save some. (Save the electricity, save the world... Cheerios...)
But it wont harm your computer unless you turn it off inproperly or just for fun start pressing power button over and over just to see lights flicker in the house.
Posted on Apr 03, 2009
Hoss is wrong. Turn the thing off. Hard drive bearings will not wear if they are not in use, nor will the cheapo sleeve bearings found in most power supplies.
Posted on May 19, 2008
    Problem Solver:
  • 5 Answers
What type of computer is it? Manufacture/partnumber...Your associates are incorrect, it is actually better to leave it on because turning it on and off is harder on a computer. This also depends upon your environment (dust, dirt, moisture, etc.) Companies all around the world leave computer systems up for years, only to shut them down when a part needs repalaced or windows requires a reboot.
Posted on Feb 18, 2008
Lg w2753v monitor shuts off
Make sure the power cable is firmly plugged into the monitor and into the wall. If so, you may have either a marginal power-supply to the monitor or the monitor electronics may be failing.
If there is a power-brick (adapter) on the power cord for the monitor, make sure the wires going in-to and out-of that are not loose or damaged. Consider a new power cord before condemning the monitor.
Dec 28, 2017 | Computers & Internet
Power led light on when pressing power it tuns on and goes of right away? power still lit..
I have the same problem, did you figure out what the problem is and solution by any chance? i purchased it recently, it started doing this the night after i left it on for the night. next day everytime i turn on, it turns off in 2 sec. after a month i tried a shot, it started and stayed up for 1 min may be... then same thing again 2 sec. i guess i have to wait for a year to turn it on .
garden led light
May 29, 2012 | Office Equipment & Supplies
Toshiba Satellite C655-S5082. Won't power on. Worked fine last night. Today it won't turn on. Plug it it and no power light. With power cord plugged in when I push the power button the light for...
Hi.
Take out the AC power jack and then remove the laptop battery. Plug AC power back in and see if the laptop will turn on. If it turns on let it boot the operating system and then shut down as normal, remove the power cord and reinsert the battery and again see if it will switch on. If it does then there has been a glitch with the battery. If it doesn't then there is a problem with the battery.
If the laptop won't switch on either with or without the battery then there is a possibility that the motherboard has developed a problem.
Good luck.
Jul 16, 2011 | Toshiba Computers & Internet
98 Pontiac Sunfire - Started and drove to work today as normal. Tried to start the car an hour later and it cranked and turned over but would not stay running. I'm told it may be a clogged fuel filter. ...
Try fuel filter if you haven't changed it recently. It is a place to start. If you have not tuned it up recently do that also. Always do preventitive maintenance first before thinking its a major problem.
Apr 04, 2011 | 1998 Pontiac Sunfire
Computer won't wake up after being left on at night
Some PC go into hibernation after running for a long time. If it is "sleep" just press and release your power button to return to normal function.
Good Luck
C2S
Jun 26, 2010 | Gateway 510H Pentium 2.4 GHz, 256MB RAM,...
Will not start in cold weather
Not solution, fuel injectors/ tune up can make a big difference, diagnostics can't tell you anything unless your car is running with engine lights on, timing is everything!
Feb 02, 2009 | 2003 Jeep Grand Cherokee
SET WON T STAY ON STARTING TURNING OFF ON IT S OWN NOW WON T PL
Check the power supply. This kind of sets usually has switching PS. Check the capacitors, common fail of special low ESR caps. It is easy to see if there is some electrolitic content outside the cap. In case caps are damaged replace them with higher voltage, never use normal caps in this PS.
Hope to help you.
Jan 11, 2009 | Naxa Electronics NX-517 Television
Need help monitor stays in sleep mode... :(
power down, everything, leave it off for a few minutes, turn it back on.. when it gets booted, disable sleep mode option in advanced power features.
Mar 19, 2008 | Computers & Internet
Computers & Internet Logo
276 people viewed this question
Alun Cox
David Payne
David Payne
