Question about ViewSonic VX910 19" LCD Monitor
How can i fix my lcd monitor it just went blank can't see nothing at all??
  • 1 more comment
  • lillian_fiso Feb 02, 2010
    No light at all whatsoever
    No there is no light at all whatsoever
  • jimnuggats May 11, 2010
    Are there any lights on the monitor at all, a light on the front or did the whole thing just cut off?
  • 11,361 Answers
The problem can be caused by bad caps in the power supply, bad inverter circuits, bad lamps. You need to open it up and look inside first and report back what you see so we can guide you further, see example of failed monitors due to bad caps here: http://s807.photobucket.com/home/budm/allalbums
Posted on Feb 01, 2010
My screen went blank but the light is on - Philips 244E. Is is fixable or should I just buy a new one?
i also have been through what you're talking about. the laptop is on and everything but still there's nothing that I can see on the screen.
This is what this person said to do.....
1) UNPLUG THE LAPTOP
2) REMOVE THE BATTERY
3) HOLD DOWN THE POWER BUTTON FOR ABOUT 30 SECONDS TO 2 MINUTES
4) THEN PUT THE BATTERY BACK IN
5) START IT UP..
Oct 02, 2016 | Philips 244E1SB 24 inch LCD Monitor
Blank screen the screen has been working for over a year and all of a sudden went blank its not my pc as i plugged my pc into another screen and worked fine.... the standby flashing stops flashing when i...
Since you have tried another monitor with your computer, then we can only assume that your LCD monitor had gone bad.
If the light is green but you can't see anything on the screen, then most likely the backlight has gone bad. Unless you want to take the monitor apart, I would suggest buying a new monitor.
Apr 19, 2010 | Samsung SyncMaster 203B LCD Monitor
Westinghouse 22 lcd monitor. faint click and went
More likely the filter caps failed and may have taken out the inverter fuse and the MOSFET in the inverter circuits also. yoo need to open it up and inspect the inside, see example of failed monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Mar 09, 2010 | Westinghouse L2046NV Monitor
I have a Viewsonic VG175 monitor. Out of the
The back light inverter may have gone out, You need to look for 12~18vdc feeding the board, there are also surface mouted fuse on the board,
Jan 03, 2010 | ViewSonic VG175 17.4 in. Flat Panel LCD...
Screen went blank and orange light is on
fiona_sheeha, If ACER warranty service not an option, then unit will need local tech to troubleshoot unit's power supply/inverter circuit for possible COMMON and repairable printed circuit board fix. You must read more of my fixya profile and visit the web links you find there so you will know and understand what ALL your options are!!! Some units require less than $5 in parts to refurbish them to working status. Your "cold-cathode-fluorescent-lamp" backlit LCD monitor isn't any different than any other brand of monitor in it's basic operating principles!! I hope this helps. 12fixlouie
Dec 30, 2009 | Acer AL1916W 19" LCD Monitor
Screen Goes Blank
Ive seen this on other monitors. Look for a 1 and 2. Some monitors do NOT auto detect a signal, and this one might not. Look for a way to set the monitor from Digital input to VGA input. Try that and see.
Jul 21, 2009 | Dell E173FP 17" LCD Monitor
ViewSonic LCD (VA1912w) Went Blank
I am using this great LCD for about an year. But few times in the past my LCD didnt show up the display though the Green light was still ON, turning off the LCD and opening it again always solved the problem. But now My LCD completely went blank. Turning off/on didnt work at all now. I've tried couple of other tweaks mentioned on this site but they didnt work. I am just seeing a blank screen with green light ON. and ya theres a very low hissing sound coming from the LCD.
Feb 18, 2009 | ViewSonic VA1912w 19" LCD Monitor
Poloroid 42" lcd monitor went blank
30 YR SERVICE TECH
YOUR UNIT NEEDS EITHER THE POWER SUPPLY BOARD OR THE MAIN TOTAL ASSY.TAKE IT IN TO A AUTHORIZED SERVICER.
Jan 12, 2009 | Polaroid FLM-4201 42 in. LCD Television
Dell 19" Monitor - Dead
Hi this is the way how to examine what's wrong with your LCD monitors. Power on both CPU and monitor. After it went blank, you have to check that you can see the image on the screen by shining a flashlight into the screen, not directly but find the best angle to the screen and take a look very closely. If you can see the icons or any image, there will be a minor problem. Like mine, I can see window image using flashlight and check lamps inside. Some of them were broken and it is very easy to replace. If you cannot see anything on the screen, there'll be some problems with inverter board. If you have soldering tool and want to fix it by yourself, check the caps first. It may cause this problem. Some caps might show leaking or burn spot on the board because of too high temp. If you don't have soldering tool, you better go get a technician to do so.
Thank you,
Tan
Mar 15, 2008 | Dell UltraSharp 2005FPW 20.1" LCD Monitor
LCD monitor went blank
Which model is it?Does power led remain on?
Samir
Jan 22, 2008 | BenQ FP737S-D 17" LCD Monitor
ViewSonic VX910 19" LCD Monitor Logo
147 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
