Question about Linksys BEFSR41 Cable/DSL Router W/4 Port Switch, Retail Box (DSLSBEFSR41)
I don't no how to hook up my Adsl Gateway
I have followed the instruction manual on how to set it up but i don't understand what to do,or what to do them in. i contacted my isp and he told me nothing.
please
help
    Scholar:
  • 89 Answers
See if maybe this will help. You didn't say what type of router(wired or wireless). Yhis should give you some idea. Hope this helps. Thanks
LinkSys Router Setup Physical Setup of a LinkSys Router Each model of LinkSys router will differ slightly, but the general design is similar across all models. Therefore, the setup is similar across all models.
  1. Attach the antennas to the router (if your LinkSys router support wireless)d
  2. Plug the Ethernet cable from your broadband Internet provider into the port labeled "Internet"
  3. Plug another Ethernet cable into one of the available ports
  4. Plug the other end of that same cable into an Ethernet port on your PC
LinkSys Router Configuration LinkSys routers now ship with a Setup Wizard which is intended to simplfy basic configuration tasks.
We do not recommend the LinkSys Setup Wizard for two reasons:
  1. The Setup Wizard is not significantly easier that the regular configuration menus
  2. If you use the Setup Wizard, you will end up learning two interfaces for your LikSys router instead of just one
Instead, we recommend simply starting your web browser and jumping into the configuration.
Once your web browser is open, go to the URL http://192.168.1.1/. This will take you to a popup box which asks you to enter a username and password.
Logging in to a LinkSys Router
The username is either blank or "admin" and the default password is "admin".
Once you are past the login screen, you are able to access (and change) a plethora of configuration options for your router.
Don't be worried by the enormous number and variety of options, your LinkSys router ships with default settings that enable it to work right out of the box in most environments.
From here the configuration options that you choose are largely up to your own personal preference.
If this is a wireless router, we recommend that you consider setting an SSID to identify the router as your own and configuring WEP to encrypt your wireless traffic.
Posted on Feb 19, 2008
ADSL modem Configured Gateway 192.168.0.9 by provide. i want to configure DLINK-DIR-816L & use Wifi. How can i configure/connect wifi router with ADSL modem??
I think you need only plug the modem into the router, then plug other devices into the router, or hook up through wifi..
If you want to reply, please click the Comment link.
Mar 03, 2018 | Gateway Computers & Internet
Can I set this up this wireless router if I have cable internet and not DSL?
You CAN do this if you have access to the firmware of the ADSL gateway.
Connect cat5 cable from ethernet port on cable modem to ethernet port 1 on ADSL Gateway. (Must be port 1)
-Connect cat5 cable from computer NIC to other port on ADSL Gateway.
-(You may need to) Start->Run->cmd
ipconfig -release all
ipconfig -renew
Here's the trick...
-Open web browser, go to ADSL Gateway homepage (likely 192.168.0.1)
-Configuration tab, Advanced WAN->WAN
-Change WAN PORT drop down from DSL ATM PORT to ETHERNET PORT 1
-Click Edit button. Change Protocol from PPPoE to ROUTED.
-Radio button for DHCP Client to Enable.
-Click Set button.
-(You may need to) Power cycle both Cable Modem and ADSL Gateway device
Now this was done on a Westell ADSL gateway from verizon, yours may differ and you may need to look up the instructions for your specific gateway.
Aug 08, 2011 | 2wire Wireless-G 802.11g ADSL Gateway
What is the password
If you are looking for the Password to an ATT 2 Wire ADSL Gateway it is located on the router. Here is an Image of where it should be located and the password is the second set of numbers between the 2 barcodes.
To get into your ATT 2wire from the computer follow these steps and you can set up your own information manually.
  1. Type this address into your web browser. http://gateway.2wire.net/
  2. You will go to the the main administrator gateway page.
  3. Then click on change system password.
  4. Change it too a password of your likeing.
  5. Save your new password.
  6. You are done.
Apr 23, 2011 | 2wire Wireless-G 802.11g ADSL Gateway
My wireless is going on and off, what's the problem?
Frequent wireless disconnection can be caused by different factors such as:
• Wireless interference within the network
• Wireless settings of the Linksys ADSL gateway are still set to default
• Firmware is corrupted
NOTE: Before going through the steps in this article, check if your wireless computers have stable connection when connected to other wireless networks (hotspots).
To resolve intermittent wireless connection, you need to perform the following steps:
i. Reducing Wireless Interference
ii. Customizing Wireless Settings of the ADSL Gateway
Nov 11, 2010 | Linksys Wireless-G WRT54G Router
Protect my wireless route
A secure wireless needs the wireless settings configured with encryption and limit the wireless connectivity to your wireless cards in the computers on your wireless network.
To secure your wireless network, please click on this link and follow my instructions :-
http://www.fixya.com/support/r3559128-wireless_router_security
Aug 01, 2010 | 2wire Wireless-G 802.11g ADSL Gateway
I no longer have the install software, how can I set up wep for my unsecured router?
You dont need the Software to do this - you can setup routers manually - by logging into them - to start lets find the correct online manual - this is the start of getting an online manual http://www.zoom.com/techsupport/adsl/adsl_5590cf.shtml Page 28 - shows how to setup the wireless security also shows details on page 13 how to login to the router - using 10.0.0.2 in an internet explorer address bar - now these are quite OLD settings - so they may still be valid or a firmware update may have changed - to check - on the PC do the following start>run {vista/7 search box}>CMD>ipconfig --- you should see a number next to default gateway if its 10.0.0.2 then thats the same as the manual - but it may start 192.168.x.x ---- so that maybe the number you need to enter into the webpage NEXT - the default username and password --- from page 14 of manual then goto the wireless section and set the WEP security you require
Mar 20, 2010 | Zoom X6 Adsl Modem/router Rohs...
Wireless set up problem - no gateway ip or limited connectivity
Connect using Lan Cable
be sure to enable java on your Browser.
Use ONLY IE: some router refuse other browser.
SET your PC on a static IP address on SAME subnet as your router (but of course different IP).
If subnet concept is NOT clear to just just ask here.
When connected with router (on Lan Cable) check every setting (WPA-PSK) TKIP key, Broadcast / Channel etc.
You can also disable every WLAN protection and restore it later.
Activate WLAN connection WHEN you are STILL connected.
Last but not least: SET your DNS IP address = your gateway IP (router)
Feb 07, 2009 | 2wire Wireless-G 802.11g ADSL Gateway
No Line on US Robotics ADSL Wireless Gateway
Initially what I suspect is that your USR's connection to your ISP is intermittent but with that of the USB modem is consistent. This is clearly an ISP issue and should be resolved by them.
One thing you can try is to verify the integrity of the line splitter that is commonly used to split the 2-wire signal to the telephone and to the modem/router. You can actually remove the splitter and connect the telephone line straight to the WAN/ADSL input of the USR 9106 Wireless Gateway and check if their is an improvement or if your ADSL and WAN IP will light up consistently.
Alternately, if your ISP is too busy to attend to your concern, you can try mimicking the USR's WAN settings to that of the USB modem's. While still using the USB (provided by your ISP) determine its WAN IP settings. This would be IP address, Subnet Mask, Default Gateway and DNS. You need to access the USB modem to get this data. Should you need detailed instructions, pls post back the make/model of the ISP provided USB modem. If you were able to gather the information. Connect your USR 9106 Wireless Gateway (Ethernet 1~4) to your PC using a LAN cable and enter its configuration page. In its WAN/ADSL settings, use the numbers gathered from the USB modem. You may need to do a full hard reset on the router (rear panel) prior to putting in the numbers.
Hope this be of initial help/idea. If problem persists, pls post back as requested, how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Apr 06, 2008 | Computers & Internet
Linksys BEFSR41 Cable/DSL Router W/4 Port Switch, Retail Box (DSLSBEFSR41) Logo
85 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
