Machine still works but makes a very loud noise when working. when finished the clothes are covered in black/brownish marks and there is pieces of the rubber seal from around the inside of the machine all through the clothes.
  • leonieeh Feb 01, 2010
    This is a "mezzo" Fully Automatic Drum Washing Machine. Front Loader.
    Model WM - 3011
    The noise seems to be whenever the drum is moving, from start when filling with water (no noise when drum stops during filling) during washing and spinning
    Thanks
    Exactly as described. I followed the comments and found the problem straight away. It was so easy and the description of what i should expect was exact. Thank you very much and I will be recommending your site to others.
  • 291 Answers
What brand and model number is your machine, and when in your wash cycle is the loud noise. Agitation cycle, spin cycle, only part of the spin cycle? Let me know, Thanks, Appliance Specialists
Posted on Feb 01, 2010
  • Norm Dickerson Feb 01, 2010
    Sounds like your main bearing. Remove your backing panel (the access plate behind your washer), unplug your washer and spin the pulley for the tub by hand. Do be careful, some of the pulleys, and some of the sheet metal are very sharp and can cut you. See if the noise is coming from the main bearing which is right behind the pulley. Also look for oil, bearing dust, water trails from this same bearing. If you cannot hear a noise, plug the washer back in and run it while you listen for the noise from that back bearing. If the bearing is bad, it is not worth the repair. The cost is close to, or more than the cost of a new washer. The only other thing that can make noise during the agitate and spin cycle is the drive motor, but this does not explain the black/brownish marks in your clothes. A main bearing failure will cause this, and the rubber seal pieces can come from the bearing seal, or from the tub rubbing against the front seal. Good Luck, Appliance Specialists
Clothes getting twisted around agitator
That does not sound good. New dogs sound great, but you must get to the bottom of why the clothes are becoming twisted on the agitator. Usually not enough WATER. Think loose flow of clothes submerged.
Long story short, you cannot jam pack this machine. Less clothes, more water, will equal long life.
Be sure that the mating teeth for the dogs, is not damaged. Slipping here would make loud noise.
More water, less clothes.
Apr 04, 2018 | Kenmore Washing Machines
Loud noise when spinning black marks on clothes leaves drum circle marks on clothes
it sounds like the bearings have gone ...are the marks on clothes oil marks ? or grease marks ? this is a sign of bearings. if there rubber marks it will be your door seal thats gone ( dose it leak )
May 05, 2015 | Beko Washing Machines
Blown fuse but appliance still works
There may be a short AROUND the fuse. Kinda rare but it does happen.
Nov 22, 2017 | Beko Wm & Wma Models Washing Machine Motor...
I have my LG Fuzzy Logic for 3 years now. Lately after washing my clothes I see that there is black particals stuck to my clothes after washing. I comes off when I shake the piece of clothing. I has a...
It's just a build up of residue. To clean out your drum, run a hot cycle (obviously with no clothes in the machine) with half a cup of vinegar then when the cycle is finished, wipe out all the residue, and trust me there will be alot. I do this every 3 months to give the drum a good clean out.
Oct 29, 2010 | LG WFT1071TP Top Load Washer
It started making a loud knocking noise and when the load is finished washing the clothes are still very wet. Apparently, it is now going through the spin cycle to spin the water off the clothes. Not...
Sounds like the idler pulley bracket clicking. Take front cover off and run it. See if the belt is jumping when it is spinning. Probably has a chunk of rubber missing on belt. If not you should be able to prise the bracket up enough to where it wont hit.
May 31, 2010 | Washing Machines
Amana washing machine makes loud noice when trying to spin
sounds like you are dealing with the same problem as me .
take off the front panel (after unplugging power) take a flash lite and look at the large pulley at the back just below the pulley is the helix check to see if they are worn .
http://fixitnow.com/wp/2008/10/21/amana-washer-makes-loud-ratcheting-noise-during-spin-but-doesnt-actually-spin/
Feb 26, 2010 | Amana NAV3330AW Top Load Washer
Dryer Noise & Black Marks On Clothes
Most likely the front drum bearing part number 5303937139 needs to be replaced. Instructions come with the kit.
May 31, 2008 | Frigidaire FDE336RE Dryer
Noise during spin cycles
GE WPXH214ACC Washer drum makes loud noise when spinning sometimes. We've had it since 2005 & never had this happen before. Washer is level, must stop & redistribute clothes to correct. Just started happening now.
Oct 12, 2007 | Washing Machines
Washing Machines Logo
44 people viewed this question
Top Washing Machines Experts
