Question about Whirlpool MH1150XMQ Microwave Oven
Whirlpool microwave oven
I have a customer that has a otr microwave oven model number mh1170xsb-0.
her fan stays on when the microwave is done cooking, and will stay on .
she will have to unplug the oven to stop the fan until she wants to cook again.
i believe she said that there is an error code saying that there is a short.
i tried to call her back to varify that , but she was not available.
im tring to get as much info as possible before i go out to repair.
thanks.......Robert
  • Whirlpool Master
  • 9,098 Answers
I have a nice PDF version of the technical sheet from a model MH1150, which should be similar. It's here:
http://www.microwavedisplay.com/whirlpool_mh1150xmq-0_wiring.pdf
Looking at that, I would say the fan relay "on/off" is stuck.
If your shop doesn't do board-level repair, we do it for $39.95 nationwide. You'll find a link to our site in our listing here on FixYa: http://tinyurl.com/yzjozk
If you'd like to discuss this further, please e-mail or call me via that link.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Feb 19, 2008
Whirlpool microwave fan not working
I would unplug the oven for 2 minutes to do a hard reset and try it again, just in cause there was a glitch.
Without knowing your full model number from the tag on the oven, I would wonder if it has a separate internal cooling fan from the hood vent exhaust fan. It could be an unrelated issue.
For more free DIY and other help & advice, feel free to contact me with your full model number and FCC ID number from the tag on your oven.
William E. Miller, AS-EET
pupista@gmail.com
http://www.microwavecontrol.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
Mar 11, 2017 | Microwave Ovens
Whirlpool mh1170XSB-0
Inside the oven. There are usually 3 fuses. 2 are on the board, while one is on a wire enclosed in a plastic twist to open capsule. The fuses in a microwave oven is a little bit specialized. Be sure to get the proper replacement part.
Mar 16, 2014 | Microwave Ovens
NTC cover message after replacing fuse in my whirlpool microwave MH1170xsb
The "negative temperature coeffecient" (NTC) thermistor was left unplugged after reassembly or it is defective.
It is the hood thermistor, and should be plugged into connector P4 on the circuit board.
I think it should be at the bottom of the board, on a little tongue-like protrusion, as shown in the attached photo.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
If you don't find yours, or if you want to look at it without disassembling the oven, you can download it here (just enter your model number).
You can also find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
Aug 16, 2009 | Whirlpool MH1170XS Microwave Oven
Whirlpool Microwave Oven Serial Number MH660XW-0
Hi Adam,
Built in over the range? The models change so rapidly unless it is less than a year old there probably wont be an identical replacement, Fortunately the mounting brackets remain close if you stay in the same brand. Whirlpools can be purchased at almost any retailer like Lowe's, Sears, BestBuy etc. Measure the the original and look for one that fits that dimension.
Eric
Jun 09, 2009 | Whirlpool Microwave Ovens
OTR Amana microwave- No power, lights, clock or sounds.
Either your magnetron, cooling fan, or the magnetron thermostat is failing.
Since it's less than one year old, it would be fully covered under warranty. I'd suggest contacting the manufacturer to get it fixed free.
Amana / Whirlpool customer service is here.
Please contact them to find your nearest authorized service center.
Jun 06, 2009 | Amana Radarange Microwave Oven
Whirlpool OTR microwave no oven 'fan'
FIRST ,,MICROWAVE OVENS ARE REALLY SAFTY MINDED AND THATS A GOOD THING....THERE ARE USUALLY THREE DOOR SWITHCES NEXT THE KEYBOARD--THE ONE ON TOP AND THE ONE ON BOTTOM ARE PRIMARY AND SECONDARY SWITCHES,,YOUR PROBLEM SOUNDS LIKE ONE OF THESE IS NOT MAKING CONNECTION..YOU MIGHT BE ABLE TO PRESS 'DOWN" WITH A LITTLE PRESSURE ON THE DOOR AFTER CLOSING TO SEE IF THE FAN WILL START,,,IF YOU NOTICE --THERE ARE 2 LATCHES(HOOKS) COMING OUT OF THE DOOR,,WHEN THE DOOR IS CLOSED,THOSE LATCHES ARE SPRING LOADED AND MAKE CONTACT ON THOSE SAFTY SWITCHES....THIS IS NOT A CUSTOMER REPAIR--MICRO'S ARE JUST TO DANGEROUS WHEN YOU TAKE THE COVER OFF--IF THIS DOES BRING THE FAN BACK ON--YOU GOT A BAD DOOR SWITCH AND SHOULD BE A REASONABLE REPAIR
THE OTHER SOLUTION STILL WOULD BE A CONNECTION PROBLEM ON THE KEYBOARD ITSELF-THE WIRES JUST PLUG ON THE CIRCUIT BOARD BEHIND THE KEYBOARD---STILL A EASY REPAIR--GOOD LUCK TUNICA
Oct 30, 2008 | Microwave Ovens
OTR Microwave Oven
I would suspect you have a bad door switch or door switch mount.
This is usually caused by either a bad door switch, a loose door switch mount, or a problem on the control panel.
Even though a door switch clicks, it may still be bad inside.
This can be caused by slamming the door or by habitually opening the door while it's cooking without hitting the Stop pad first.
If you or a friend decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
If you think the problem is on the control panel, which we repair these nationwide for $39.95 postpaid.
Please write back with your model number if you need further help.
Jan 01, 2008 | Microwave Ovens
MH1170XSB-0
The most common causes for a lack of heating are a bad door switch, a loose connection on the magnetron, a bad magnetron, bad connection on the control circuit board, a bad relay on the board, bad high voltage diode, or bad high voltage transformer. If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk You can find helpful exploded view diagrams and order parts by entering your model number here: http://tinyurl.com/gv383
Sep 29, 2007 | Whirlpool MH1141XM Microwave Oven
Whirlpool MH1150XMQ Microwave Oven Logo
186 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
