Question about HP Pavilion a1240n (EG136AA) PC Desktop
HP 640a cd/dvd burner
Had a toshiba DVD R/RW Drive model TS-h552 on my HP Pavillion a1230n that stopped coping data and replaced it with a HP 640a unit which still has the same problem. This has the Lightscribe technology. Unit came with Sonic software.
    Genius:
  • 3,587 Answers
Methinks you have a major device issue. Check it through control panel, hardware devices to see if driver is happy or not/
Posted on Feb 19, 2008
Need to replace dvd player in Toshiba Satellite C655
http://www.youtube.com/watch?v=ChrYyWjaEMY Toshiba Satellite C650 L675 DVD Replacement Guide Installation -- L670 C655. Install Fix Replace CD DVD/RW Optical Drive Burner. This guide is useful for these laptop models: TS-L633 - 142, V000210060, C655D, C650D, L675D, L670D
Jan 30, 2013 | Toshiba Satellite A135 Notebook
My system not detect dvd+r/rw ts-h552 drive
make sure that the dvd burner is getting enough power test all leads that are attached to the dvd burner including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or the drivers may have been corrupted or you might have a virus run your antivrus program you might have to physically unplug the leads for this cd/dvd burner then plug them back in this should activate the found new hardware wizard or you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps
Apr 08, 2011 | Samsung TS-H552 (810884008760) Burner
How do i set my TS-H552 as slave?
Look closely at the "back" of the unit.
Look for a 2-by-4 grid of pins, labelled:
* MA(ster)
* SL(ave)
* C(able)S(elect)
* SP(are)
Move the small "jumper" to the 'SL' position.
Aug 02, 2010 | Samsung TS-H552 (810884008760) Burner
My dvd writer will try reading dvd's or cd's but it stops and nothing pop ups on my screen. it is a dvd+-r/rw model ts-h552.
Try this quick fix :
What I suspect here is that you tried a bad CD or
DVD disk inside your drive, in that case, get a very
good lens cleaner to clean your drive first.
If that doesn't work,
Get a screw driver and trace the screw holding the
CD/DVD Drive to your system at the back of your
laptop, then unscrew it and remove your drive. If you
cant do this by yourself, just try and get a good
technician to do it for you. Then clean the interface
connecting the drive to your laptop.
After this, power up your system normally without the
drive connected.
Then shut down properly, and reconnect the drive,
making sure that its firmly connected.
Then power on again and check it in the system
BIOS if its now detected, then save and exit, then
boot your system properly again.
If it doesn't work after this, then I'm afraid you might
have to get another drive.
Hope this helps you out.
Apr 15, 2010 | Toshiba Style Bay DVD-RAM Drive Kit...
Cd burning problems
hello sir..i have a solution to your CD burning problem...sometimes if you are not regularly using your CD-RW drive then there are chances of CD-RW lense prob,so please do clean the lense using lense cleaner CD available in the market,even then if you not able to burb the CD then please do reinstall the software which you are using for CD burning...i suggest you NERO software for CD burning which is a user friendly software...
Oct 30, 2008 | QPS Que! Fire CD-RW Burner
Samsung TS-H492 Jumper
hai
if u have two seperate data cable to hard disk and dvd rw,there is no big changes to made in jumpers,but u have only one data cable u should select jumper as a master to hard disk and slave to dvd rw,
basic identification to master jumper is that ,it place is close to data cables ,and slave is next pin,in typical models
also u se the detail in hdd and dvd rw's jumper locations
thanks
prasanna
Mar 01, 2008 | Samsung TS-H492 (TSH492AWRBH)...
HP Pavilion a1240n (EG136AA) PC Desktop Logo
212 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
