Question about HP Compaq Presario SR2013WM (RE468AA#ABA) PC Desktop
I have sys which contain main board marrcury(p1865d7).now i will run visual studio2008 but not properly run so plz give suggetion @ processor & ram
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 5 Answers
According to Microsoft: Minimum: 1.6 GHz CPU, 384 MB RAM, 1024x768 display, 5400 RPM hard disk Recommended: 2.2 GHz or higher CPU, 1024 MB or more RAM, 1280x1024 display, 7200 RPM or higher hard disk
I know that Visual Studio 2008 runs fairly slowly on a 2.4GHz laptop with 1GB RAM, so I can't imagine that it would run all that well on a 1.6GHz machine.
Posted on Feb 02, 2010
22" led tv lg 22LN4105-TA no picture audio OK blinking one time .
Main digital board fault. Its video processor section circuit has the fault. Audio decoder and amp section is working properly. There is an IC [Digital Processor], which cannot be replaceable. Main digital board replacement is the only repair work to do to this set. If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
Jan 06, 2017 | LG Televison & Video
Will not dispense ice
commonly what you will find on that model is the main control board on the back of the unit is the source of your issue, it begins like a computer virus where the unit will render the water in the door feature useless, next goes the ice delivery sys, then the unit does not defrost properly causing cooling issues. But before running out and getting a new control board go by this check list first: 1) make sure your ice bucket is properly seeded, 2) make sure the ice in the bottom of the bucket is not melted together if so empty good ice in seperate container and put back in freezer quickly to avoid melting then run hot water in ice bucket to melt remaining bad ice afterwards completely dry ice bucket and put good ice back in and see if it works properly, 3) make sure the auger mtr is not seized due to door being left open and humidity freezing in mtr gear.
Apr 16, 2012 | GE Refrigerators
I have a Compaq Presario PC, SR5210NX Processor with Intel Celeron Processor 420. I got a message that windows did not start correctly and it said to run the diagnostic, which I did. After that was done,...
Unplug power and Open the computer case. Vacuum all the dust
inside it. Visually inspect all the fans: Power Supply, CPU, Chipset
and Case...Make sure they are spinning easily and freely.
Plug the power in, and turn on your system. Watch the fans, especially
the CPU Fan and the Main Board Fan (System Fan). Oil and dust over
times may accumulate and prevent the fans from spinning properly.
If you are handy, you can remove them, give them a good wash and lubricate
the shafts with a few drops of WD-40, they will be as good as new again.
Fans don't go bad that easily.
Jul 16, 2011 | HP Compaq Presario SR2150NX PC Desktop
Light comes on: Traction engaged and goes on and off. Also the anti-loc traction control light comes on and off on Cadillac 1997
My friend; Try this; Check the fuses / relays boxes in both cabin & engine compartment. Make sure there is no burned fuse or relay. U can check them visually & or using digital multi tester DMM. Check the brake peddle switch. This system {TCS} hooked up with ABS system & ESS & could be due to leaks or malfunction in the brake & or ABS sys. NOTE; TRY TO RESET THE SYS. BY Just ; 1. Dis-connect the battery negative cable, while the ignition switch in the ON position {Don?t Run the engine}. 2. keep it Dis-connect for at least 15 minutes { some experts said 13 hours """ Overnight""" }. 3. Re-connect the battery negative cable, put the ignition switch in the OFF position {Don?t Run the engine}. Then NOW run your engine & see if it disappears. Try it, & PLZ; let me know if I add any benefits to you. I hope I add some thing valuable to you. Regards; MAR; soer2@yahoo.com
Nov 09, 2009 | 1997 Cadillac DeVille
Switch on problem no processor running
845gvsr no display given ram beep but ram ;ram ic and bios is ok what can i do sir
Jul 27, 2009 | Intel D845GVSR Motherboard
Need installation software
you may be able to get a download from xpvistasite.com
or mercury-pc.com/downloads
May 30, 2009 | Mercury KVM400M-U Motherboard
Cant play gams on this board
hi...if you want more to run games try to buy a Video card separate..
if mother board is PCIE slot buy the PCIE Video Card.if AGP Slot buy the AGP Video Card..the best VGA is 512x128 mb..Thanks and Good Luck..^_^
May 11, 2009 | ASUS P5GC-MX/1333 - Motherboard - micro...
I have a p1865d7 v2.0 mercury motherboard i want to know whether it can support ddr2 ram or not and what are the processors it can support
http://www.mercury-pc.com/product-spec.php?productid=477 - here is the info. and answers are u can use any processor wht uses Socket A and u cant use ddr2 because it uses only ddr.
if this helped rate fixya
May 11, 2009 | Computers & Internet
Plz send driver for sound and vga
plz give me the sound & vga driver
Mar 28, 2009 | Mercury PVCLE266 Motherboard
Processor for P5VDC-MX
Hey there alcouto, your motherboard supports Intel Celeron, Intel Pentium 4, and Intel Pentium D processors. The socket set is LGA775. The FSB should be no higher than 800Mhz. It appears you have purchased the wrong CPU for your board. I hope the rest of the info helps you on your next purchase. Good Luck!
Jan 29, 2008 | ASUS P5VDC-MX Motherboard
HP Compaq Presario SR2013WM (RE468AA#ABA) PC Desktop Logo
113 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
