Question about HP Pavilion dv9000z Notebook
My HP dv1000 does not start. I checked both adapter and battery ( new ones), but still the problem persists. And the adapter makes a beep sound 2/sec, doens anybody know what it means. Please help me out.
  • vaibhav_iisc Feb 03, 2010
    Thanks for the post Saad, actually there is no response to anything, ie nosound from the processor, fan etc, No LED Lights. I tried putting another charged battery but no difference.And as you said my adapter and battery both r fine as they work perfectly with my friends system ( who has same model). I will take your suggestion and try putting different RAM.
    Problem Solver:
  • 6 Answers
I don't think it's your adapter which beeps, beep indicates Ram problem, does your laptop power on? if it does power on and you don't see anything on the screen then it is because of RAM. Try switching ram to other slot, or get a new ram.
Posted on Feb 03, 2010
Pavilion dv 1000 battery adaptor
You may take it to a tech center to fix it or buy a new charger. As for the cost, it is almost the same. So it is better to get a new adapter.
Replacement HP Pavilion DV1000 AC Adapter 65Watt 18.5V 3.5A
Nov 22, 2012 | HP Pavilion dv1000 Notebook
HP DV1000 won't run normal after a forced shutdown
For this kind of issue, please follow up the following steps to check:
1.confirm the battery and ac adapter connect the laptop normally.Maybe the bad connect lead to this problem. If there are no lights when you turn on laptop, one of possible reason is that your adapter is malfunction.
2.the second possible cause is laptop dc jack failure. If the dc jack is broken or loose, you are required to replace it or repair it.
3.Another possible reason is that there is something wrong with laptop motherboard. For this situation, it includs two kinds of possibility,a failure in an electronic circuit and BGA malfunction.
For more detailed reasons and solutions, please have a look at the following article:
http://www.ifitjams.com/lappower.htm
If you verify your laptop adapter is dead and you plan to order a new one, I recommend one for you on the basis of your laptop model:
Oct 28, 2012 | HP Pavilion dv1000 Notebook
Hp pavilion dv1000: When I turn it on, it does not boot up and I get a blank screen. I have tried hard reset by taking out the battery and holding the power button for 30 seconds, and then turning it back...
I just want to know if you see any power indicator on the machine? If you see any power indicator try to check if you hear any sound that it boots up to windows or try to check if there are any beeping sounds when you turn on the machine. If you hear the windows boot up sound try to use external monitor and see if the machine gives any display. If you hear consecutive beeping sound it means there are hardware that's faulty inside the machine.
Apr 03, 2011 | HP Pavilion dv1000 Notebook
The screen is black on start up. No image at all.
The dv1000's were a limited edition notebook withmany issues. the motherboard going on them was one of them. connect the motebook to a desktop monitor if you have one and simultaneously press Fn + F4 to use the monitor as a screen. If nothing happens begin crying. Time to buy a new laptop. You information is safe but you need an IDE/SATA PCI adapter to view the files on another computer. If you were using XP, i hope you didn't password protect it making it private. That will be problem number 2.
Mar 31, 2010 | HP Pavilion dv1000 Notebook
I bought a new ac charger for my hp pavillion dv1000 it will not power on
Check and make sure the Voltage on the AC adapter is the exact same as your previous one. Just because the connector fits in the port, doesn't mean it's the right one. Look in your manual to figure out if your AC adapter voltage is correct. If it is, it's possible that you have a dead battery, it happens when surges happen during power outages. If it's so, look on the HP website for a new replacement battery. It should allow you to type in your pavillion model number.
Jan 08, 2010 | HP Pavilion dv1000 Notebook
Beep on starting the laptop
Try to take memory out and put it back in to make sure they are seated in the slots properly and no loose.
May 27, 2009 | HP Pavilion dv1000 Notebook
HP pavillion dv1000 won't charge
Try using your laptop without the battery and just using your power supply (new universal or your old one).
If your laptop works on just mains power it means your battery is causing the problem, which is not unusual.
Aug 07, 2008 | HP Pavilion dv1000 Notebook
Battery won't charge
sounds like the ac adapter isnt working.Test the adapter with a volt meter.The sticker on the adapter should tell the output voltage.
Mar 22, 2008 | HP Pavilion dv1000 Notebook
Power LED flashes three times-no boot
Try this. Power down. Remove the battery. Remove the memory. Replace the memory. Replace the battery.
Try to power back up.
Best of luck...
R-
Nov 05, 2007 | HP Pavilion dv1000 Notebook
HP Pavilion dv9000z Notebook Logo
104 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
