Question about Radio Shack Radio Communications
How do you get out of PGM wired - Radio Shack Radio Communications
    Problem Solver:
Sel this radio nd buy simple radio from india
Posted on Feb 01, 2010
Code lamp " don't flashed or work
Hi, Medo your cell phone can call any Honda Dealership in the world for this situation I would call or visit my local dealer or reputable shop's service/parts department and inquire about any possible quick fix, answers, or parts inquiry.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
F1 light CBR Forum Enthusiast forums for Honda CBR Owners
Honda CBR600F4I 2001 Service Manual
http://www.partsfish.com/page/oem-parts-for-honda
Honda CBR600F4i Owner Manual
Apr 21, 2017 | 2002 Honda CBR 600 F(4)i
Honda h22 5 speed
stalls. ( ever tune it up,at the 60k service points? )
what year, no year , no joy, 1978 to 2001 , lots huh?
and what engine option, displacement (size)
over 10 engines
Third-generation Honda Prelude engines:
B20A/B20A1 - 2.0L DOHC PGM-FI 143/160 hp (Japan/Europe)
B20A3 - 2.0L SOHC 12v carb 104 hp North America
B20A4 - 2.0L SOHC 12v carb Global, except North America
B20A5 - 2.0L DOHC PGM-FI 135 hp (101 kW) North America
B20A6 - 2.0L DOHC PGM-FI 142 hp (106 kW) Oceania
B20A7 - 2.0L DOHC PGM-FI 150 hp (110 kW) Europe
B20A8 - 2.0L DOHC PGM-FI 133 hp (99 kW) Europe
B20A9 - 2.0L DOHC PGM-FI 140 hp (100 kW) Europe
B21A - 2.1L DOHC PGM-FI 145 hp (108 kW) Japan (SI States)
B21A1 - 2.1L DOHC PGM-FI 140 hp (100 kW) North America
Jan 11, 2014 | Honda Prelude Cars & Trucks
I have a 1996 Acura 3.5 R.L. just put a new fuel pump in and it won't start. It turns over, but will not stay started.
Check your main fuel relay.
Fuel Supply System
PGM-FI Main Relay
Description
This PGM-FI main relay is located behind the dashboard
lower cover. The PGM-FI main relay actually contains
two individual relays. One relay is energized whenever
the ignition is on. It supplies battery voltage to the PCM,
power to the fuel injectors, and power for the second
relay. The second relay is energized for 2 seconds when
the ignition is switched on, and when the engine is running.
It supplies power to the fuel pump.
PGM-FI
MAIN RELAY
FUEL
PUMP
RELAY
Relay Testing
NOTE: If the engine starts and continues to run, the PGMFI
main relay is OK.
1. Remove the PGM-FI main relay.
2. Attach the battery positive terminal to the No. 3*
terminal and the battery negative terminal to the
No. 2* terminal of the PGM-FI main relay. Then
check for continuity between the No. 5* terminal and
No. 2 terminal of the PGM-FI main relay.
• If there is continuity, go on to step 3.
• If there is no continuity, replace the relay and
retest.
*: 8P CONNECTOR
To FUEL PUMP
3. Attach the battery positive terminal to the No. 4 terminal
and the battery negative terminal to the No.
7* terminal of the PGM-FI main relay. Then check
that there is continuity between the No. 3 terminal
and No. 1 terminal of the PGM-FI main relay.
• If there is continuity, go on to step 4.
retest.
4. Attach the battery positive terminal to the No. 1 terminal
and battery negative terminal to the No. 2*
terminal of the PGM-FI main relay. Then check that
there is continuity between the No. 5* terminal and
• If there is continuity, the relay is OK;
If the fuel pump still does not work, go to Harness
Testing on the next page.
retest.
To PCM CONNECTOR
TERMINAL A4
To ST. SWITCH
To GROUND
To IGN. 1 To BAT
To PCM
CONNECTOR TERMINALS
A13 and B1
FUEL PUMP
RESISTOR
FUEL PUMP
Sep 18, 2013 | 1996 Acura TL Series
Fuel pump wiring diagram for 95 honda delsol
Below is the diagram you needed. This was the biggest I was able to post on here due to a size limit (made it 2 parts). I do want to add one thing that may help you out. Honda's in that era had some problems with the PGM-FI relay. You may want to look into that if your wiring is good. I have seen the PGM-FI relay work fine in cooler weather but when it got hot outside the relay would not work. I hope this helps
Dec 19, 2011 | 1995 Honda Civic del sol
What sound files can be loaded from a pc to an mpc 500? aiff, wav,mpc...? thanks
Data Compatibility
MPC1000: SEQ, WAV, PGM
MPC2000/2000XL: SEQ, WAV, SND, PGM (Most parameters of PGM file can be loaded.)
MPC4000: SEQ, WAV, PGM (DRUM program only. Only note assign and tune are loaded.)
MPC3000: SND (THRU Computer)
Z4/Z8: SEQ, WAV, PGM (DRUM program only. Only note assign and tune are loaded.)
S5000/6000: WAV only (THRU Computer)
S1000/3000: No compatibility
Feb 21, 2010 | Music
PGM WIRED
pgm wired how do i fix this?
Sep 19, 2009 | Radio Shack Pro-84 Handheld Scanner
Buzzing fuel pump
sounds like the fuel pump relay is stuck on. find the relay and replace it. hope this helps mike
Jun 16, 2009 | Acura TL Cars & Trucks
Donuts tax(casio te-2200)
move the pgm key to pgm mode 3 subtotal 125 subtotal ( tax table) rate tax and subtotal beginning  level tax ejemplo : for ten cent = 10  and subtotal 5002 subtotal subtotal.
to applay the tax to dept or plu
move the pgm key to pgm mode 3 subtotal 366 subtotal 1 and all dept o plu  subtotal
Apr 06, 2009 | Casio Parts Cash Register PC Desktop
I need to know how to program a new tax rate
Mar 31, 2009 | Casio Parts Cash Register PC Desktop
Can't enter casio qt-2000 pgm mode
You can only enter PGM mode as manager.(our manager key is #1). The, you are brought to a admin menu.
Jan 01, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Radio Communications Logo
41 people viewed this question
Top Radio Shack Radio Communications Experts
John
John
Greg Cann
Greg Cann
Jason
Are you a Radio Shack Radio Communication Expert? Answer questions, earn points and help others
