Question about E-Machines eMachines Desktop PC
Restore discs how do i use emachine restore dics
    Sergeant:
    Champion:
  • 317 Answers
Put the first CD in the Tray, then shut down the computer. Next boot up, and press F9 or whichever option is system recovery. Now select recover form CD. This should work, otherwise it will automatically, start the recovery on boot up.
Posted on Feb 18, 2008
I am trying to reload my operateing system w. disc that came with emachine t 5048,its not recignizing the dics,wiill read any disk but that 1???It came w. computer when i bought it. disk is perfect,no...
At power on, enter the bios (usually by tapping a function key like Tab or Del or F2) and change the boot device order to have the CD drive first. Put the disc in the disc drive. Save and continue. Now, you may get a message asking you to "press any key to boot to the CD". Touch any key, and the reload should start.
See...
http://pcsupport.about.com/od/fixtheproblem/a/biosaccess_pc.htm
Feb 07, 2013 | E-Machines T5048 (7136) PC Desktop
Restore my emachines w3507 back to factory settings how do i do it
Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer
If done properly the user should get to a screen similar to the below screen. Select the option for Safe mode command prompt only Windows Advanced Options Menu
Please select an option: Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode Start Windows Normally
Reboot
Return to OS Choices Menu Use the up and down arrow keys to move the highlight to your choice. To perform a system restore, follow these steps: 1.Click Start, click Run, type msconfig, and then click OK. 2.On the General tab, click Launch System Restore. 3.Select Restore my computer to an earlier time, and then click Next. 4.Calendar dates in bold are possible restore points. Click the most recent one to view system restore information. 5.Select a system checkpoint or an installation restore point, and then click Next. 6.Close all other programs. 7.To start the system restore, click Next. 8.Your computer restarts. Repeat steps 1 through 8 until you fix your configuration issue.
or
It is possible for the Windows operating system on your eMachines computer to have a critical failure. If the operating system on your eMachines computer is failing, you can use your recovery discs to restore your computer. Recovery discs come with your purchase of an eMachine, and contain your operating system and all your basic drivers. You can recover your eMachines W series in about an hour.
Turn off your computer and press "F8" to enter the BIOS menu. Tab over to the "Boot Sequence" or "Boot Order" menu. Move your optical drive to the top of the list. Press "F11" to exit and save changes. Insert your recovery disc into your optical drive, then restart your computer. Press any key to boot from disc. Select the "Full Recovery" option from your recovery disc menu. Allow the recovery procedure to complete. Hope this helps.
Dec 28, 2012 | eMachines W3507 PC Desktop
EMachine EL1850-01e
It looks like you'll have to either return it or perform a default factory recovery. These instructions are from their site but proceed knowing that this will erase any data that is stored on the primary partition (meaning if you have anything on it, it's gone...). Esentially it resets it to a point as if you just picked it up in the store (which you did.. :( )
How can I restore my computer with the backup discs I created?
With user created backups you are able to restore your computer to the factory default settings. If backup discs were created instead of factory restore discs, these can be used instead and will restore the system to a user backup point.
    If you have a recovery disk:
    1. Ensure that the computer is completely shutdown, then turn on the computer.
    2. When the eMachines splash screen appears, tap the Alt and F10 keys simultaneously. A screen stating "Starting eMachines eRecovery" should appear.
    3. From the recovery options, choose Restore system from CD/DVD.
    4. Insert either the first Recovery or Backup disc that you created.
    5. From the on-screen options, choose a backup.
    6. Click OK and the installation will begin.
    7. Change the disc as necessary when prompted.
      If you do not have a recovery disk:
    8. Restart the computer.
    9. When the eMachines logo appears on the screen, press the Alt and F10 keys repeatedly.
    10. If you are prompted with a Microsoft Windows boot screen, press the Enter key.
    11. After the system recovery application has loaded, follow the prompts to reinstall the Operating System.
Dec 13, 2011 | E-Machines eMachines Desktop PC
I want to restore my emachine to factory settings how do I do it
Could be F10 on boot up for the restore, depends which Emachine you have and if it was set up with a restore partition or you got a set of discs with it that is your restore set.
Feb 02, 2011 | Computers & Internet
I have a emachines and would like a restore disc
Access the manufacturer's web-site: http://www.eMachines.com
and read about how to order (via telephone & credit-card)
a "System Restore" set of CDs.
Oct 20, 2010 | E-Machines eMachines Desktop PC
T6534 RECOVERY DISC
I have this disc, and will make a copy for You if You still need it.
webgal03
Mar 24, 2009 | eMachines T6534 PC Desktop
Need large disc support for old emachine, flash bios? or try restore cds?
flashing a bios, can render your machine/motherboard useless.
You should always ensure any bios download is from a trusted source. if you experience a power failure, or an incomplete bios file. your computers as good as dead.
Windows 95/98 only supports disk drives to a certain capacity. if you updated to windows 2000/ME/XP your problems may be solved. I,d certainly try that first.
Bios flashing Last resort, even after finding a reliable bios update. also ensure the bios file is 256mb-512mb or equivalent. as this is standard bios file size.
Finally check that your hard-drive does not have a jumper ( Small white/black ) plastic block restricting the drives registered size.
When you install windows XP, it will ask you if you wish to enable LBA ( large block Allocation ) Select Y ( yes )
Mike @ compurepair.
Mar 12, 2008 | E-Machines eMachines Desktop PC
E machines restore disc
hit f11 when computer is starting up..it will take you to the restore menu...do a complete system restore from the restore partition.. as far as the restore discs goes, when you pop that in, the computer will boot from the cd and take you to the restore menu...do a complete system restore..after formatting the hard drive.it will show a bunch of files..be patient and let it complete the process...
Feb 23, 2008 | E-Machines eMachines Desktop PC
E-Machines eMachines Desktop PC Logo
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
