Question about ASUS MB P5KPL-CM C2D LGA775 INTELG31 ICH7 DDR2 PCI-EX16 FSB 1600(O.C.) 10 Motherboard
The pointer keeps spinning and will not allow me entry into web
If I disconnect the PC from the power source for 30 minutes the problem goes away for about 6 hours
  • 67 Answers
Hopefully you mean the mouse pointer?
Could be a number of things but the first thing I would do is run a virus check.
Posted on Feb 02, 2010
New thermostat and control box only shows two EEs and does not work, Any suggestions?
There is an error in your thermostat...duh! Take the batteries out and replace with Brand New Alkalines, after 30 minutes. Meanwhile turn OFF or disconnect your furnace from the power source for 30 minutes. How? Turn the Circuit Breaker that is labeled for it (usually a 220 volt). This is to allow the computer in both items time to reset. If this is getting you too concerned about the power and all have a professional from Sears do it for $100.
Sep 30, 2015 | Heating & Cooling
My 40" samsung lcd tv goes blank at the top with picture at the bottom
Disconnect unit from power source for 10 minutes and allow to cool down to run temp.
Reconnect unit and try. If problem has not gone away, try a reset to factory defaults.
May 28, 2014 | Sharp LC-46D64U 46 in. LCD HDTV
I have sony digital audio/video that fuse blew i replace the fuse and it keeps showing protector
The fuse acts as a protection against shorts and circuit defects.
Try totally disconnecting the power source and allow to cool down for 10 minutes.
Reconnect system to power source and attempt to use.
May 28, 2014 | Audio Players & Recorders
Frigidaire f11 error
I suggest to try unplugging the device from power socket 5 minutes and reconnect. If the error goes away, then well and good; if not, you may have to replace the panel control.
Failure Code: F10 / F11 / F12 / F13
Condition:
- Runaway Temperature.
- Shorted Keypad.
- Bad Micro Identification.
- Bad EEPROM Identification/Checksum error.
Check/Repair:
1. (F10 only) Check *RTD Sensor Probe & replace if necessary. If oven is overheating, disconnect power. If oven continues to overheat when the power is reapplied, replace EOC. Severe overheating may require the entire oven to be replaced should damage be extensive.
2. (F11, 12 & 13) Disconnect power, wait 30 seconds and reapply power.
3. (F11, 12 & 13) If fault returns upon power-up, replace EOC.
Hope this helps; also keep in mind that your feedback is important and I'll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using Fixya, and have a nice day.
Nov 09, 2011 | Frigidaire Gallery 30" Self-Cleaning...
Ln55c650 keeps flashing bright to dim very fast after about 30 minutes of being on if i shut it off for a few minutes it goes away til about 30 minutes the picture never goes away just gets bright and dim...
I had the same issue occur on my ln55c650 (screen flickering, not the actual image but the front lights flashed which was too distracting) and they had to replace the power supply pc-board. Seems some issue with power module in the TV rather than the side panels. Luckily for me, TV was still in warranty.
Jul 22, 2011 | Samsung LN55C650 TV
I have an F7 code on my gas range that keeps beeping
F7 code usually means a stuck key on the key pad. Some of the keys can be unstuck, but if high heat caused the pad to warp it might not be repairable.
  • Turn off power
  • Disconnect the key pad from the clock
    • If code goes away key pad is at fault
    • If it does not the EOC (electronic control board) is at fault
You can try giving the oven a hard reset by disconnecting the power for 20-30 minutes, then restoring the power.
Apr 17, 2011 | Maytag Ovens
Compaq presario sr1010v power light blinking
Try disconnecting the A/C source.
Allow unit to set for 5 minutes.
Re-install power and restart uint.
If that does not work, Disconnect power and remover supply connections at the motherboard.
Allow to set for afew minutes, and re-connect.
Sometime, removing the connections at the motherboard, allows the supply to reset.
You should have a 4 pin video connection and a 24 pin main board connection.
Note. Make sure your power is disconnected before attempting this service.
Sep 29, 2009 | HP Compaq Presario SR1010V (568656) PC...
Security light flash no security system on truck
sometimes turning the ignition on 3 times quickly without starting will reset the computer. If the van has power locks and keyless entry then try using only the keyless entry. Sometimes your car wont have a alarm but an anti theft device which will not allow it to start if it goes off or something triggers it.
Jul 26, 2009 | 2003 Dodge Ram Maxi
I keep getting disconnected from the internet
Check your internet cable for loose connections, If you are using Windows XP, try the following methods:
1. Go to the Control Panel; right click on the Network Connections.
2. On the dialogue box, click Status; the Local Area Connection Status will appear, check if its is connected or not. If it is connected. Unplug the power source to your internet cable/connector.
3. Restart, your computer;then re-plug your internet power source.
4.Wait for at least 30 minutes then check your browser.
5. If there is no internet signal, you should call your internet provider's technical service.
Apr 28, 2008 | Computers & Internet
ASUS MB P5KPL-CM C2D LGA775 INTELG31 ICH7 DDR2 PCI-EX16 FSB 1600(O.C.) 10 Motherboard Logo
61 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
