Question about Kenmore 72187 Air Conditioner
Heat no heat,fan works
  • 86 Answers
Chech heater n heater connection
Posted on Mar 15, 2008
Fan not working on Whirlpool microwave Model MH2175xss1
What do you mean "fan doesn't work"? Magnetron will over heat without fan.
Apr 26, 2017 | Whirlpool Microwave Ovens
I have a Rheem Classic Super Quiet 80 gas furnace (for heat). The fan stops when the "heat" turns on.
Any time I ever had trouble,first thing to suspect is the thermostat.
They lose contact sometimes and sometimes you tap the face and they work til next glitch.
If the thermostat has some years on it,go ahead and replace it.
Can't you just leave the heat and fan in auto? That would be best,I think. don-ohio
Jan 10, 2017 | Heating & Cooling
Fan doesn't work in heat mode it works on all other functions. Heat does come out but fan doesn't kick in. Outside unit is operating
AC inside fan doesn't come on AUTO - Community Forums > ... > Air Conditioning and Cooling Systems
Jul 21, 2004 - The inside FAN doesn't run when in AUTO mode. If I leave ... Is the thermostat not working correctly or something in the AC unit causing it to do this? Thanx ... The unit is electric central air-conditioning(heat and cool). It made ... Carrier A/C condenser fan not working
Jul 27, 2012
Heater Fan Doesn't Work on AUTO
Jan 23, 2006
Blower doesn't work in ON position after repair
Mar 25, 2005
Central AC/Heat, Blower Doesn't work on Auto
Nov 30, 2004
More results from
Nov 01, 2015 | Heating & Cooling
2010 Lincoln MKS Heated Seat on driver's side stopped working (Light in button turns off on its' own)
The most common cause of this problem is that the drivers seat heater grid is open or burned out. That is based on 25 years as a Ford dealer technician.
Feb 27, 2017 | Lincoln Cars & Trucks
Have a nutone 765hl-a heater blows but no heat
If the temperature control is turned up for heat but it is not heating, it is most likely a bad heating element or temperature control. Most heaters are not repairable.
Feb 19, 2015 | Dryers
Zafira radiator fan
Turning on the heat removes heat from the engine as it blows it on you. Make sure first that there are no air pockets in your cooling system as that can cause high temp reading and malfunctions in proper fan engagement. If that looks good test your fan, if it is working then test the fan relay, if it is working test the temperature sensor that gives the relay the go ahead to engage the fan.
Jan 16, 2014 | Cars & Trucks
My laptop is over heated now days and cooling fan also not working properly so what should i do ?
Hi, First blow out your fan and heat sink. Dust and lint may be causing your over heating issue. If you mean the fan is not working properly, due to it over heating this problem will also be resolved. If the fan is not working properly I.E. making noise, not spinning etc...Then the fan should be replaced.
Oct 20, 2013 | Computers & Internet
When heater is on the fan turns off. when we switch the fan on the heat element turns off but fan comes on. one or the other works but not both at the same time.
In some unit heat mode will start the fan after few seconds. Wait for max 3 minutes. If you turn it to fan mode, fan will only work no cool or heat will respond.
Dec 26, 2010 | Heating & Cooling
Soon as i turn on my heat my cooling fans come on first
It sounds like you do need a thermostat with your heat shut off and the gauge will raise a little then the car doesn't have that heat drawn from it indicating that you most likely do need a thermostat. As far as the fans coming on immediatly that could be a different problem it is most likely the coolant temperature sensor that tells the fan's when to come on. If this sensor says the coolant is hot the fans will come on immediatly. These are seperate problems as the coolant temperature sensor does not have anything to do with the cabin heating system. You should first check the level of your coolant is full, This could also cause your cabin heating system to perform poorly, and may have adverse effects to the engine cooling system. (fans)
Dec 31, 2009 | 1995 Nissan Maxima
Kenmore 72187 Air Conditioner Logo
65 people viewed this question
Top Kenmore Heating & Cooling Experts
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Kenmore Heating and Cooling Expert? Answer questions, earn points and help others
