Question about Fujitsu 24C1 Air Conditioner
Keypad displayed 2EEE, not responding to on/off button or silmutanious press enrgy saving and zone control, lcd change to 0000
I am talking abt maytag refrigerator . New board panel and the PE0000 just keeps flashing
You need to program the new board. Programming Mode:
NOTE: The Program Code is located on the Serial Plate on this unit after the word Code.
1. Press and hold the Door Alarm Keypad .
2. Press and hold Freezer Temperature Down Keypad .
3. Release the Door Alarm Keypad and wait 3 seconds.
4. The control will display PE to indicate the programming mode.
5. Entry is confirmed by pressing the Freezer Temperature Down Keypad once more.
6. The control will display the current Program CODE. This value should be validated with the
Program CODE printed on the unit serial plate.
NOTE: If the Program CODE is correct, the Programming Mode is exited by pressing Door Alarm Keypad for 3 seconds.
7. Press the Refrigerator Temperature Up Keypad or Refrigerator Down Keypad to change the digit value with each key press.
8. The decimal point indicates the selected digit. Press the Freezer Temperature Up Keypad to select the next digit.
9. Once the desired Program CODE is entered, press and hold the Freezer Temperature Down Keypad until the Program CODE begins flashing indicating it has been saved.
NOTE: If you attempt to enter an invalid Program CODE the control will not save the new code, but will beep. (The unit will NOT run with a Program CODE of 0000).Once the Program CODE has been saved the Programming Mode is exited by pressing any key. If the new code is incorrect this process should be repeated.
The Programming mode can be exited at any time
Oct 13, 2016 | Maytag Refrigerators
I have replace the front panel of my kithchenaid fridge model KFIS25XVMS9 code 1813 but it doesn't work.
It is easy to make a mistake in the instructions below so pay close attention to the instructions or they will not work until you do.
Programming Mode:
NOTE: The Program Code is located on the Serial Plate on this unit after the word "Code."
2. Press and hold Freezer Temperature Down Keypad within 3 seconds .
6. The control will display the current Program CODE. This value should be validated with the Program CODE printed on the unit serial plate. NOTE: If the Program CODE is correct, the Programming Mode is exited by pressing Door Alarm Keypad for 3 seconds.
9. Once the desired Program CODE is entered, press and hold the Freezer Temperature Down Keypad until the Program CODE begins flashing indicating it has been saved. NOTE: If you attempt to enter an invalid Program CODE the control will not save the new code, but will beep. (The unit will NOT run with a Program CODE of 0000).
Once the Program CODE has been saved the Programming Mode is exited by pressing any key. If the new code is incorrect this process should be repeated. The Programming mode can be exited at any time by pressing Door Alarm key for 3 seconds or will exit if unattended for four minutes.
Aug 26, 2016 | KitchenAid Refrigerators
How to check for a bad sensor on my MFI2569YEWO maytag fridge? We've replaced the control board in the back and display board in the door. the display reads PE0 000. Can't get it to program. HELP ME!
Patti when you change the main control board you have to reprogram the refrigerator to understand the board there is a code just below the model number and here are the instructions you need to follow them carefully
Programming Mode:
http://www.appliance911seabreeze.com/
Aug 09, 2016 | Maytag Refrigerators
I just replaced the control board and now it won't reset
Hi try this. 1 press & hold the door alarm keypad. .2 press & hold freezer temperature down keyboard within 3 seconds. .3 release the door alarm alarm keypad and wait 3 seconds. 4.the control will DISPLAY PE to indicate the programming mode 5.entry is confirmed by pressing the freezer temperature down keypad once more. .6 the control will display the current program CODE this program should be validated with the program CODE printed on the unit serieal plate ..NOTE.IF THE PROGRAM code is correct the programming mode is excited by pressing door alarm keypad for 3 seconds. .7.press the refrigerator temperature up keypad or refrigerator down keypad to change the digit value with each key press. 8,. the decimal point indicates the selected digit press the freezer temperature Up keypad to select next digit. . 9.. Once the desired program code is entered press & hold the freezer temperature down keypad until the program CODE begins flashing indicating it has been saved.Note.if u attempt to enter an invalid code the control will not save the new code ...but will beep ,,(the unit will not run with a program code of 0000 ,). Once the program CODE has been saved the programming mode is excited by pressing any key.if the new code is incorrect this process should be repeated.the programming mode can be excited at any time by pressing door alarm key for 3 seconds or will exit if unattended for 4 minutes..good luck
Jun 16, 2016 | Maytag Refrigerators
How to program a w10319823 Kenmore refrigerator control board
Yes, here are the instructions to program:
Programming Mode:
1. Press and hold the Door Alarm Keypad.
2. Press and hold Freezer Temperature DOWN /- Keypad within 3 seconds.
5. Entry is confirmed by pressing the Freezer Temperature DOWN /- Keypad once more.
6. The control will display the current Program CODE. This value should be validated with theProgram CODE printed on the unit serial plate.
7. Press the Refrigerator Temperature UP /+ Keypad or Refrigerator Temperature DOWN /- Keypad to change the digit value with each key press.
8. The decimal point indicates the selected digit. Press the Freezer Temperature UP /+ Keypad to select the next digit.
9. Once the desired Program CODE is entered, press and hold the Freezer Temperature DOWN /- Keypad until the Program CODE begins flashing
Feb 05, 2016 | Kenmore Refrigerators
Installed a new control board in a Whirlpool G15FSAXVY04, display reads PE0 000 flashing, what should I do next
You need to program the control board to match the refrigerator. Look for the serial plate and locate the number following "Code". That number is the program code and you will need that value.
1) press and hold Door Alarm keypad.
2) Press and hold the Freezer Temp Down keypad.
3) Release the Door Alarm keypad and wait 3 seconds. The refrigerator display should read PE - programming mode.
4) Press the Freezer Temp Down keypad to confirm that you are in the programming mode. Compare the Code number displayed to the one you recorded off the serial plate.
5) If they are the same, press and hold the Door Alarm keypad for 3 seconds to exit the programming mode.
6) Otherwise, press the Refrigerator Temp Up or Down keypads to change the first digit in the program code to get the correct value.
7) Press the Freezer Temp Up keypad to move to the next digit in the program code to adjust that. Use the Refrigerator Temp Up/Down buttons.
8) Repeat steps 6 and 7 until all of the digits match the Program Code from the serial plate of your appliance.
9) Press and hold the Freezer Temp Down button until the display begins to flash to save the code. If you hear a beep, the code is incorrect and was not saved.
If you heard a beep, return to steps 6 and 7 to correct the program code. Then go to step 9 again. If the code was saved, press any keypad to exit the programming mode.
I hope this helps.
Aug 08, 2015 | Whirlpool Washing Machines
CODE ERROR E.EE
When EE:EE is displayed on remote control , press "Energy Save" &
"Zone Control" buttons simultaneously for longer than 3 secs. The error
code will then be displayed on the LCD.Thanks.
Jan 15, 2011 | Fujitsu Heating & Cooling
I don't know how to increase the volume
OSD Menu Functions
English
All the function settings for the LCD monitor are controlled via the control keys located on
the bottom part of the front panel. To display the OSD main menu, press the “Menu”
keypad button on the control keys2.gif. (Note: The OSD menu display will disappear
automatically after approximately 10 seconds, if no action is taken.)
The LCD2.gif monitor has been adjusted to optimal settings before shipment. Adjustments to
the monitor settings can be made using the OSD menu.
• Press the “Menu” button to display the OSD.
• Press the ▲ or ▼ button to select the function to be adjusted.
• Press the �� button to access the function to be adjusted.
• Press the ▲ or ▼ button to select the sub-function to be adjusted.
• Press the �� or �� buttons to change the current setting of the sub-function.
• To go back to the previous menu, press the button. Changes are saved
automatically.
Source
• To exit the OSD menu press "Menu" again. It automatically will save any changes
that have been made.
If this is helpfull; please indicate so.
JZKlipper/Mike
Nov 11, 2009 | Westinghouse LCM-19v5 Monitor
I don't know how to increase/adjust the volume on my LCM-19v5 computer monitor
OSD Menu Functions
English
keypad button on the control keys. (Note: The OSD menu display will disappear
The LCD monitor has been adjusted to optimal settings before shipment. Adjustments to
automatically.
Source
JZKlipper/Mike
Nov 11, 2009 | Westinghouse Computers & Internet
How do i reprogram my HV board?
HERE TIS RIGHT OFF THE INSTRUCTION SHEET.  THE TECH JUST LEFT. POWER UP REF. PROGRAM CODE IS LOCATED ON SERIAL PLATE ON THIS UNIT AFTER THE WORD CODE.-1. PRESS & HOLD THE DOOR ALARM KEYPAD.-2. PRESS & HOLD FREEZER TEMP DOWN KEYPAD.-3. RELEASE DOOR ALARM KEYPAD AND WAIT 3 SECS.-4.CONTROL WILL DISPLAY PE TO INDICATE PROGRAMMING MODE-5. ENTRY IS CONFIRMED BY PRESSING TEMP DOWN - KEYPAD ONCE MORE.-CONTROL WILL DISPLAY CURRENT PROGRAM CODE. THIS VALUE SHOULD BE VALIDATED THE THE PROGRAM CODE PRINTED ON UNIT SERIAL PLATE.-NOTE: IF PROGRAM CODE IS CORRECT, THE PROGRAMMING MODE IS EXITED BY CLOSING THE FRIG DOOR.-7.PRESS REFRIG TEMP UP KEYPAD + OR REFRIG DOWN KEYPAD -TO CHANGE THE DIGIT VALUE WITH EACH KEY PRESS.-8.THE DECIMAL POINT INDICATES THE SELECTED DIGIT. PRESS THE FREEZER TEMP UP KEYPAD + TO SELECT NEXT DIGIT.-9.ONCE DEIRED PROGRAM CODE IS DISPLAYED, PRESS AND HOLD THE FREZZER TEMP DOWN KEYPAD - UNTIL UNIT PROGRAM CODE BEGINS FLASHING INDICATING IT HAS BEEN SAVED. *note* IF YOU ATTEMPT TO ENTER AN INVALID PROGRAM CODE, THE CONTROL WILL NOT SAVE THE NEW CODE, BUT WILL BEEP! (THE UNIT WILL NOT RUN RUN WITH A UNIT PROGRAM CODE OF 0000). ONCE THE PROGRAM CODE HAS BEEN SAVED THE PROGRAMMING MODE IS EXITED BY CLOSING THE FRIG DOORS.
Oct 26, 2007 | Maytag MFI2568AES Stainless Steel Bottom...
Fujitsu 24C1 Air Conditioner Logo
59 people viewed this question
Top Fujitsu Heating & Cooling Experts
Fotis Papastamatiou
AJMAL KHAN
Donni Steen
Are you a Fujitsu Heating and Cooling Expert? Answer questions, earn points and help others
