Question about Tomtom ONE GPS Receiver
No gps signal with tomtom - Tomtom ONE GPS Receiver
    President:
  • 1,738 Answers
Solution for No GPS Signal
To pinpoint your location, you need to get signals from at least 4 satellites. If you receive signals from less than 4 satellites or the signals are not strong enough, the Driving View stays gray and one of the following messages is shown in the bottom right corner of the Driving View:
  • Waiting for a valid GPS signal
  • The GPS signal was lost sec ago
Note: In previous versions of the TomTom application the message may vary.
If you see any of these messages, try the following:
Finding a GPS signal
In the following cases it can take up to 5 minutes to find your current position:
  • You use your TomTom device for the first time.
  • You haven't used your TomTom device for a longer time.
  • Your TomTom device has been relocated without using it (e.g. after traveling by plane or train).
If it takes longer than 5 minutes, make sure that you are in an open place without tall buildings or trees around you.
Once your TomTom device has located your current position, the Driving View is shown in full color and shows your position on the map.
Tip: Most TomTom devices can use QuickGPSfix™ to locate your current position faster.
Flight mode
On devices with built-in GPRS connectivity, flight mode also disables your device’s GPS reception.
To switch flight mode off, tap Flight mode in the preferences menu and then select Restore connections.
Clear View
Your TomTom device must be outdoors to locate your current position.
Try repositioning your device in your car; ideally, try to position it at the lowest possible point directly on the windscreen.
Some vehicles have a heat reflective shield embedded in the windscreen, which may prevent your device from locating your current position. If this is the case in your vehicle, use the TomTom External Antenna Kit (available as an accessory).
Tip: As a reference, place your device outside your parked car to see if it can find your current position.
Reset your device
Reset your TomTom device. Click here to learn how to reset your device.
Install the latest application
We recommend always having the latest version of our application installed on your device.
See also: How to check for and install an updated version of the TomTom application?
Posted on Feb 04, 2010
TOMTOM GO LIVE 2050 problem with TOMTOM Server
Have you been able to get satellite connections (signals) when you're outdoors ? and not under/around tall buildings or overhanging obstructions.
Regularly get QuickGPSfix update (using TomTom HOME) to download the latest satellite positions (for the next 7 days), to enable your GPS to find the satellites quicker.
Jul 17, 2013 | Tomtom GO GPS
Tomtom wont turn on after chaging it
Reset your TomTom GPS receiver. Some TomTom users report occasional difficulty in getting their TomTom navigation device to start or respond to commands. If this happens to you, remedy the problem by performing a soft reset on your TomTom GPS. A soft reset will reset the data on your TomTom GPS receiver without erasing any data. To reset a TomTom GPS receiver, press and hold the "On/Off" button for 15 seconds or until the device restarts.
Let your TomTom GPS acquire the necessary satellite signals outside. If the device has trouble connecting to the satellite signals necessary for its operation, try an easy fix to the problem. Take your TomTom GPS receiver outside, away from mountains, tall buildings or heavy foliage, where the receiver has a clear view of the sky. Wait for a few moments while the device acquires the necessary satellite signals.
Read more: How to Troubleshoot a Tom Tom GPS ' eHow.com http://www.ehow.com/how_5533906_troubleshoot-tom-tom-gps.html#ixzz1hV4FBQ91
Dec 21, 2011 | GPS
My tomtom one gps can't get signal
When was the last time you updated the QuickFix of your TomTom? It helps your GPS to find the satellites.
Please, do the following:
1) Install "TomTom Home" software in your computer from www.tomtom.com
2) Start TomTom Home in your computer
3) Plug in the GPS dock to your computer's USB port and place the GPS on the dock. The green light on the bottom right of the GPS should turn ON to indicate that the GPS is getting power from the dock and charging
4) Start your GPS while being in the dock. If the GPS asks "do you want to connect to computer" answer "YES"
5) The TomTom Home software will detect the GPS and check if there are any updates for it. Then you'll be offered updates to install. Some are free, some are not. Be sure you choose to update "QuickFix".
Please, report back if you need further assistance
My ID: alexocuello_
Mar 19, 2010 | Tomtom ONE GPS Receiver
NO GPS SIGNAL
hi go online and update automatic. it wil receive new info about satts an wil function like before. do this couple of times a year. good luck
Feb 04, 2010 | Tomtom ONE GPS Receiver
The TomTom now takes 20 minutes to find a signal
try downloading tomtom home on your pc and synchronise, this should download any updates and gps fixes etc onto your device, good luck
Aug 05, 2009 | Tomtom ONE GPS Receiver
Waiting for valid gps signal
Go to TomTom Home on your computer and do a update for your unit. In the update list you should see a GPS quick fix which helps the TomTom's aquire a signal faster. Hope this helps.
May 21, 2009 | Tomtom One XL GPS Receiver
My tomtom keeps saying waiting for gps signal. was working perfectly, now wont pick up signal wherever we are
go to tomtom website ----> support ---->select product,
in the search box type in "lose signal",
click the "2. Updated - No GPS signal"
then follow instructions.
if it help rate the Solution Please
21/Apr/09
Apr 20, 2009 | GPS
My tomtom not finding any gps signal
did you save a backup of your original settings/software via tom tom home?
Jan 07, 2009 | Tomtom ONE GPS Receiver
No GPS signal?
I had this problem (waiting for a valid GPS signal). I did a factory reset and the unit started working again (yes, I lost all my settings, but what good is a GPS unit that just sits there waiting for a valid GPS signal?). To do a factory reset, go to menu -> change preferences -> Reset factory settings.
Jan 17, 2008 | Tomtom ONE GPS Receiver
Tomtom ONE GPS Receiver Logo
354 people viewed this question
Top Tomtom GPS Experts
Martin Murray
Jon Piercy
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
