Question about Dishwashers
My Maytag Dishwasher won't close. Tried to empty it, put back the racks and close again but it won't.
  • 111 Answers
There is a safety latch on door that won't let you open it when it's running,feel lucky it didn't fail with your dishes in it,i'd say it is a problem with that latch mechanism
Posted on Feb 01, 2010
How do i clean a maytage dishwasher?
Put(throw) a cup vinegar into bottom on dishwasher and place a container with a cup of vinegar upright on the top rack and then run a fell cycle with no detergent or dishes(empty)
Mar 10, 2015 | Maytag 24 in. MDB5600A Jetclean II...
Elctrolux dishwasher won't start, display won't light and it randomly beeps
Check continuity of the 4 small wires that connect to the control panel to the control board. They seem to break where they flex for the door to open and close.
Jul 25, 2012 | Electrolux EWDW6505GS Fully Integrated...
What is the float switch
I have no real experience with float switches on dishwashers, but have with some in humidifiers. It's a piece of styrofoam on a narrow metal stick that lifts when the appliance fills with water & lowers when the water empties. If this gets stuck on something, like a dishwasher rack, the unit won't fill or empty the water & the cycles won't work properly. Take a look & see if there is such a thing hung up somewhere in the dishwasher. If you can loosen it, your dishwasher should work again.
Feb 21, 2012 | Beko 24 in. D3421F Free-standing...
The dishes are not being cleaned.
clean the arms of any food debris,then if this doesn't solve the problem,replace the water channel conduit that runs up the wall of the inside of the dishwasher,after years of water pressure it will erode the fitting on the wall and rack and when the drawer rack is pushed in to wash,water will get past the o-ring on the conduit and you will lose water pressure and the arm will not function properly,replace it from the sump to the top,its not that expensive and it will assure full pressure
Apr 11, 2010 | Maytag 24 in. MDC5100A Free-standing...
Dishes on top rack do not come out clean. Bottom rack O.K.
Have you tried cleaning the filter? We had a similar problem. The repair man came and removed all the spinners and the other stuff at the bottom above the motor to get to the filter. It was blocked with all kinds of old food bits and pieces, the odd bit of plastic film etc. He cleaned it, replaced it and we havn't had a problem since but he said it needs to be done about every two years. It can be done by someone who has reasonable DYI skills.
Jan 04, 2010 | Maytag 24 in. MDB7600A Jetclean® II...
Close the Maytag dishwasher, cycle starts, but I noticed a leak! Dishwasher door can be opened by putting your fingers on the edge and pulling it open. Tried it again, door clicked, thought it was ok but...
your problem appear to me like it come from your upper basket . pleas try 1st to ensure the basket goes inside untill the end it is important.. thank you
Jun 10, 2009 | GE Dishwashers
Maytag dishwasher quiet series 400. Dishes have hard stuck on grit and food particles after rinsed and dried.
Very common problem is soap build up in these machines. Try putting it into a wash cycle with no dishes, and no soap. Let it wash for about 5 minutes, and then open the door. If you see alot of soap suds, then soap build up is the problem. Try doing a couple loads with no soap, and no dishes, and throw a cup of vinegar into the machine halfway through the wash. Repeat as necessary. This should solve your problem.
Mar 14, 2009 | Dishwashers
Top shelf not getting clean
It sounds like the hose at the rear of the top shelf has come unconnected. Pull the top shelf out when the washer is empty and take a look. If the hose has come apart you should be able to push it back together. Good luck with it.
Dec 27, 2008 | Maytag 24 in. MDB8600AW Jetclean II...
Racks corroding.
Check on Ebay. I just entered this to check for you. maytag dishwasher racks" and there were several on there. One was universal and could be used with 40 different model numbers.
Oct 25, 2007 | Maytag MDB9100A Dishwasher
Dishwashers Logo
65 people viewed this question
Top Dishwashers Experts
