Tv says invalid format when PS3 w/hdmi is hooked up
Olevia 226-S12 hdtv says invalid format when you hook a PS3 using hdmi, I also tried the old school a/v cable and the tv did not even register is was there? Is this a firmware issue for the tv, or PS3, or does the PS3 have to be set to its lowest resolution setting? I ask this because the Ps3 was hooked to a 37'' 1080p LG. However, I thought that when you plugged the a/v cable into the ps3 it didnt matter because you are only going to get low res with that anyway? Just trying to hook the ps3 up to my child's tv and running into these issues, please help?
SOURCE: Hooking up a PS3 through HDMI
what you have to to is hold the start button till the TV shows 480i then you will have what you need, it will set up for your tv
Posted on May 03, 2008
SOURCE: olevia 432 s12 remote codes for time warner
These are the codes for Olevia if you have a Time Warner Remote 1144, 1240, 1331 or 1610
Posted on Jun 18, 2008
SOURCE: set up of tv
http://www.olevia.com
Posted on Aug 31, 2008
SOURCE: sony bravia won''t play PS3
Try setting the resolution to a higher grade or a lower grade.. That solved the problem for me.. good luck!
Posted on Jan 06, 2009
  • 40 Answers
SOURCE: i have an lg 50pg20 and i cant hook up my ps3 using the hdmi cabl
Make sure the xbox display settings are not defulted to 480. Have you tried using the component hookup instead? Theres really not that big a difference in quality between the two if your settings are correct in the xbox display menu.
Posted on Jun 19, 2009
Hooking up my ps3 using HDMI cord to my olevia 232-S13 and it says invalid format
Setting up your HDMI cable on your PS3 games console
1: Turn on your TV and set its input to HDMI.
2: Make sure your PS3 is connected via a HDMI cable.
3: Power on your PS3 and press and hold the power button for approx. 5 seconds, you will hear the PS3 start to beep, release the power button after the second beep.
4: Your PS3 should automatically configure itself for HDMI video and Audio output.
Jun 28, 2015 | Olevia Televison & Video
Hi, I have a samsung LE40B750. It is connected
Ur tv some how causes HDMI 1 and 2 port hubs link together so changes back and fourth 1 or 2 HDMI hubs will not a difference.Ur tv have 4 HDMI hub ports wright?Tries not to used HDMI hub ports as like HDMI ports like 1,2,3,4 to as in sequences.Tries used like 1 and 4,2 and 4,3 and 1 as skips sequences might work for ur tv.Tries to hook up the PS3 system as the old format hook up same hook as PS2 format like used the PS station old RCA AV cable hook up.Then that should not causes conflict at all because now tv have two difference kind of format hook up.
Sep 05, 2011 | Samsung Televison & Video
I have my olevia 232-s12 hooked up to my ps3 it has worked fine for years now for some reason when i had to reboot my ps3 i let it attempt to set the display settings and when i try 1080i or 720p it tells...
this could be a PS3 software issue, if you can let it auto update, if the problem isnt resolved try a 720i setting or a 1080p, if still no joy your display may be on the way out
Mar 05, 2011 | Syntax Olevia 226T 26 in. LCD Television
Receive an invalid format message from my Olevia 32 tv
You get invalid format, or format not support becuase the video resolution setting on your PC is too high for the monitor to display, you need to lower your PC video resolution to the native resolution of the TV to get the best picture. Look at the owner manual for your TV or search the web.
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
Jul 11, 2010 | Olevia LT32HVM 32 in. LCD Television
Received used Olevia 226-s11 hdtv, hook-up up (no
I need to go to Menu, Picture, Mode, Home.....
The default setting for the TV was Showroom which wouldn't let the cable signal through. Thanks for trying to help.
Jan 12, 2010 | Televison & Video
No video display,
UUUHH HHHH DUH!!ITS NOT MENT 4 PS2!!!
Jan 26, 2009 | Sony Playstation 3 (PS3) Console
Sony bravia won''t play PS3
Nov 24, 2008 | Sony BRAVIA XBR KDL-V26XBR1 26 in. LCD...
Televison & Video Logo
968 people viewed this question
Top Televison & Video Experts
