Question about Canon MX700 Office All-In-One InkJet Printer
Canon MX700 - VERY LIGHT print/copy. Could this be a print head issue resulting from being placed on a not-so-sturdy surface? How can I tell?
    President:
  • 4,070 Answers
Good day, have you tried running maintenance check / cleaning? if not please do so. you may try cleaning it manually just by removing the ink cartridge and remove the dried ink inside so that the ink can pass freely, hope this helps, have a nice day.
Posted on Feb 08, 2010
I have a canon multifunction MX700. Suddenly, my black ink stopped printing. Printer prints in other colors. I have turned the power to both printer and computer on and off, have checked the USB cable,...
Try removing the print head and placing in in a shallow tray of HOT clean water for a few minutes. Then place it on a pad of paper towels to draw ink and water from the print head. Re-install in your printer and run a deep clean cycle. re-test your printer with a nozzle check. If still no ink showing at all, repeat the process. If no success after that, the print head is probably dying. Printheads can be replaced, but it is cheaper to replace the machine.
Nov 18, 2017 | Canon PIXMA MX700 All-In-One InkJet...
My canon pixma mx700 can't print normally, both of them (color and black), the print result is disappear or blur. I think the problem is the printer head, can you help me to resolve this problem,...
Hello.
Try this link below for a great method of unblocking print heads and getting them flowing.
To remove the print head take out all the cartridges, lift the leaver on the side of the cartridge holder inside the printer, and lift out the head.
http://www.fixya.com/support/r3986425-unblock_print_heads
I hope this helps
Regards GM
May 26, 2011 | Canon MX700 Office All-In-One InkJet...
My MX700 canon printer is flashing the on ff green light and the gold alarm light and say error code 6A80. My book says to unplug all power and the plug back in but it is doing the same thing. Thanks for...
The printer head has locked itself and won't move.
I have found a solution for you on the Internet - here are the details :-
I was able to unlock the print head - just with a small piece of foil.
Cut a 3-5cm wide stripe from a sheet of overhead-foil (90um thickness), move it below the print head, and move it to the front and upwards, to the back and upwards. Remove the foil. After switching the printer on - it will work as before and be able to move the head. No need to disassemble the whole MX700!
Leo.
Nov 21, 2010 | Canon PIXMA MX700 All-In-One InkJet...
I replaced the ink on my Cannon MX700 All-In-One. Now, anything I print has stripes on it where the ink is apparently not working. Any advice?
Most possible that the ink has dried out on the head, someitmes a cleaning can help or if not the printing head has to be replaced.
use the maintenance key to do a head cleaning several times, if there is no result you can try to reinstall the driver after removing printer and then connecting once again.
If none of these work a new head can be the solution.
Sep 17, 2010 | Canon MX700 Office All-In-One InkJet...
Print to Canon MX700 via wireless print server (no network)
If you know the ip address of your printer, you can add that manually from add printer wizard copy first driver to your local drive.
Mar 23, 2010 | Canon PIXMA MX700 All-In-One InkJet...
Double images, error 5100 when printing, copying
5100 is a carriage error, check the timing strip for contamination(plastic strip about 1/4" in width)
The unit is not homing, check for obstructions.
Jan 02, 2010 | Canon PIXMA MX700 All-In-One InkJet...
Canon MX700 with new cyan cartridge very faint
The print head needs a chemical solution. You have to soak it to chemical solution to unclog it. It should be a chemical solution that is really use for print head. If it does not work, the worse thing to do is to buy a new print head.
Sep 24, 2009 | Canon MX700 Office All-In-One InkJet...
Canon MX 700. I cannot get print alignment. I am missing lines. Have done head alignment 20 times and still cannon resolve issue. Have replace cartridges, cleaned heads, rollers, deep clean and still no...
My MX700 is 1 year old and I to have issues:
1) Alignment
2) Says it's out of paper when there is paper in it. Shutting off an Turning on usually helps
3) Feeds multiple pieces of paper at once!
HELP
Aug 30, 2009 | Canon MX700 Office All-In-One InkJet...
Canon pixma mx700 print default
In your print dialogue box should be a setting to tell printer to print black only
Apr 23, 2009 | Canon PIXMA MX700 All-In-One InkJet...
Canon MX700 Office All-In-One InkJet Printer Logo
55 people viewed this question
old marine
old marine
