Question about Axial Syma 9086 Helicopter
How do I adjust the pentitometer on the 9077? I am a newbie and don't even know the pentitometer looks like!
2000 Windstar front blower intermittently works
Look at the relay. find another relay with the same rateing that you can borrow & still use the car (horn if same) swap relays & test 4 while if ok you know the prob is the relay. I don't think relays are expensive if yoy just wanted to try a newbie.
Jun 02, 2012 | 2001 Ford Windstar
How do I adjust emergency brake on 1990 ford f 350 dually
Under the cab on the drivers side about even with the door hinge the cable splits for the two different sides, right in this junction is an adjustment rod in the cdables connecter. If all things are the same and the brake is'nt tight enought to hold the truck don't adjustr any hting till you check the rear brakes as your describing the brake shoes worn out and even groung into the drums. The cables only need to be adjusted as the cables are removed or changed and once adjusted are good to go. The rear break shoes can be OK but thier adjustment to be as close to the break drums as possible with the shoes adjusters. You can get into the back of the drum though the adjustment hole but some don't have the hole and the drum will need to be removed. If you have this problem the brakes need to be looked at anyway and worn parts changed to new as failure altogether cvan cause a crash.
Jun 24, 2011 | 1990 Ford F350
Accidently chose german instead of english while setting up my Kodak C195......can't read german so don't know how to correct I want ENGLISH, provide step by step instructions.....newbie here!!!
Ok this may get alittle confusing but here goes. if you remember where the settings button is you can look for one of these words Sprache; Zunge they mean language in german or you can scroll down to Reset Alle Kamera Einstellungen which means Reset settings to default. this should do it
Jun 15, 2011 | Cameras
Hello Fixya experts, I'm having a SYMA 9077 Double Horse Eagle. The problem is it doesn't lift off but just spins on the ground. The bottom blades are CCW, the top ones are CW. Plz help me analyze this...
The problem may be due to broken blades or untrimmed. Change the blades with new one is the first option if the same is all right trim your copter through trimmer button on remote. sometime copter not fully charged and this problem occurs.
Jan 05, 2011 | SYMA Toys industrial 9077 Double Horse...
Bushnell Telescope 78-4678
A telescope like that has a very narrow depth-of-field, so you need to focus very, very slowly to be able to see any image. Try focusing on something bigger (like a spot on the moon) and adjust the crosshair accordingly. The two eyepieces gives different magnification.
Jun 30, 2010 | Bushnell 675x5 EQ Reflector Telescope
Repair manual for double horse 9077 change bottom blade holder
How much charging time for double horse 9077 egle...using original charger
Jun 23, 2010 | SYMA Toys industrial 9077 Double Horse...
9077 eagle justs spins and will not lift off ground.
i need blueprints or repair plans for the double horse 9077
Nov 29, 2009 | Axial Syma 9086 Helicopter
Web Form development problem
Try this: <form method="post"
instead of this: <form method=post
leave everything else the same.
Mar 13, 2009 | Computers & Internet
Mymonitor is black and the on button from the monitor is green and is flashing
i havent seen this question asked, and believe me i have searched. i have compaq presario, windows xp media edition 2005, 64 amd processor, model # SR2017CL, with HP 1703 17" monitor. Prob-put computer in hibernate mode other evening, without turning it off. when i woke up, screen had diagonal lines going across it. i rebooted, well manually restarted, since comp would not respond.
Message comes up white with black writing, essentially, prob with active desktop, restore or turn off. i tried to turn off and screen went back to diag. lines. looks like the horizontal hold of a tv screen is asque. tried adjusting monitor to no avail.
tried a few more times, was fine for a few mins then went to same thing. now when i turn monitor on it blinks red, blue, and so on.
just whole screen that color. so i am at the point where i dont
know if its the comp or the monitor. (i am quite a newby)
ty for any help you can give
ellie
Jan 30, 2008 | HP Pavilion F1703 17" LCD Monitor
Axial Syma 9086 Helicopter Logo
Top Axial Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you an Axial Toy Expert? Answer questions, earn points and help others
