Question about Canon MX700 Office All-In-One InkJet Printer
After a good & solid year, my canon mx700 is suddenly giving me very light prints & copies. Could this be a printer-head issue from the machine being placed on a not-so-solid surface? Only guessing.
  • fionagelderm Feb 01, 2010
    Nope, I tried your sollution (I'm on a Mac btw) but no joy.
    Changed settings on the machine, tried various cleaning, head alignment options, but still nothing.
    I do think it's a hardware problem, probably a pretty mundane tune-up is required, but I'd like to be sure.
    Any other thoughts?
  • 6,993 Answers
have you checked the turner and when last did you replace the turner?
The ink in the turner must have reduced to minimum, and maybe that's why its giving light prints.
Try this and let's see the result.
Take care.
Posted on Feb 01, 2010
Issue: Printed image is light
Solution: Set the Ink Intensity (Windows) MX700
Set the Ink Intensity (Windows) The Intensity setting controls the amount of ink placed on the paper. The higher the intensity the darker (more ink) the printed image will be. If the Intensity setting is set too high, the printed page may become too wet and curl or streak. The coloring can be adjusted manually for all items, or automatically using ICM (Windows color correcting function). Follow the instructions below to adjust the ink intensity settings. Click on the link below to view more:
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=238&modelid=15651
I have a Canon MX700 and suddenly I began to have problems with the color. I am using Canon ink cartridges but all my color jobs come out with only blue and black, no magenta or yellow. Every time I run...
This worked for me:
Unplug (not just turn off) the printer. Wait at least 20 seconds, then plug it back in. Hold the Feed Switch down, then turn on the printer (continue to hold the Feed Switch down). When the printer finishes cycling the paper feed, release the Feed Switch. Copy anything and it should print. You're good to go.
Oct 01, 2013 | Canon PIXMA MX700 All-In-One InkJet...
How do you remove the printhead from my canon mx700
You remove the print this pull the scanner up,the carraige return in the middle of printer,then you drag the cart lift up, remove the cartridges....under the cartridge is the print head.If i have been useful please give me a vote :).Thanks
Apr 01, 2011 | Canon PIXMA MX700 All-In-One InkJet...
My MX700 canon printer is flashing the on ff green light and the gold alarm light and say error code 6A80. My book says to unplug all power and the plug back in but it is doing the same thing. Thanks for...
The printer head has locked itself and won't move.
I have found a solution for you on the Internet - here are the details :-
I was able to unlock the print head - just with a small piece of foil.
Cut a 3-5cm wide stripe from a sheet of overhead-foil (90um thickness), move it below the print head, and move it to the front and upwards, to the back and upwards. Remove the foil. After switching the printer on - it will work as before and be able to move the head. No need to disassemble the whole MX700!
Leo.
Nov 21, 2010 | Canon PIXMA MX700 All-In-One InkJet...
Canon pixma mx700 has error 6000?
Hi there maximum time we found it is a the head problem. The print head is what the cartridges sit in inside of the printer. For resolve the problem please follow these.
Open the printer and wait for the carriage to slide over. Some how if its not come then Unplug the printer & Manually slide the carriage.
Now Remove the ink cartridges from the printer head & Use wet warm cotton swab or use alcohol to thoroughly clean the print head.
Repeat this until there is no ink residue coming off on the cotton swab. After finished it make the head dry then fix it back. Now Try to print something now
If that does not work then follow the next step.
Remove the printer data cable & restart the PC & printer. Then fit back the data cable & turn on the printer. Hope that's start working , if no luck then Uninstall the printer driver & restart the PC & Printer both again. Now install the driver of the printer and connect it with PC ,Turn on printer & go for a test print from the printer preference. Thanks & waiting for your reply.
___
Jul 29, 2010 | Canon PIXMA MX700 All-In-One InkJet...
Double images, error 5100 when printing, copying
5100 is a carriage error, check the timing strip for contamination(plastic strip about 1/4" in width)
The unit is not homing, check for obstructions.
Jan 02, 2010 | Canon PIXMA MX700 All-In-One InkJet...
Canon MX700 multi-function printer error 5100, double-lines
You can Try
Solution 1:
Clean the timing strip.
Solution 2:
The purge cap (the white sliding mechanism that the print head parks to when it's not in use) may be not lubricated well enough .
Lubricate the sliders with some white grease (don't get it on the small wipers or the black caps); this repair probably require to remove the right panel off of the printer to gain access to the purge mechanism.
All best: Pineworks
Jan 02, 2010 | Canon PIXMA iP4600 Color InkJet Photo...
U052 prnt head is incorrect install the correct print head...it is the correct head head made by Canon how can I get rid of this message and resume printing..
You can check that it's installed properly, after that all you can do is replace the printhead. They are like a light bulb and burn out when you least expect it. If you printer is less than a year old Canon will replace the printhead, after a year you have to buy a new one. Anywhere from $60.00 to $100.00 The part number is on the side of the printhead, the number starts with QY6, the numbers after that are the actual part number.
Dec 15, 2009 | Canon MX700 Office All-In-One InkJet...
Canon MX700 with new cyan cartridge very faint
The print head needs a chemical solution. You have to soak it to chemical solution to unclog it. It should be a chemical solution that is really use for print head. If it does not work, the worse thing to do is to buy a new print head.
Sep 24, 2009 | Canon MX700 Office All-In-One InkJet...
Canon MX 700. I cannot get print alignment. I am missing lines. Have done head alignment 20 times and still cannon resolve issue. Have replace cartridges, cleaned heads, rollers, deep clean and still no...
My MX700 is 1 year old and I to have issues:
1) Alignment
2) Says it's out of paper when there is paper in it. Shutting off an Turning on usually helps
3) Feeds multiple pieces of paper at once!
HELP
Aug 30, 2009 | Canon MX700 Office All-In-One InkJet...
Scanner on Canon Pixma MX700 doesn't work
hi dear
try using another software like photoshop
or acd see
oke
Apr 03, 2009 | Canon PIXMA MX700 All-In-One InkJet...
Canon MX700 Office All-In-One InkJet Printer Logo
55 people viewed this question
old marine
old marine
