Question about Casio FX-115ES Scientific Calculator
Easy low bat???
How can i change the battery?
  • 4 Answers
On the back upper right is a cover held in place with a screw. You will need a small screw driver to take off the cover. LR44 battery - one needed
With the new battery it is highly recommended to wife it off with a soft cloth first and then place it into the calculator and replce the cover.
NEXT VERY IMPORTANT press the following buttons to turn on for the first time.
Press "ON" "Shift" "9" "3" "="
This will clear it for use again.
Posted on Aug 03, 2010
Honeywell Ademco alarm panel reads Chime BAT 11
The answer above is incorrect. If the back up battery was low it says, "bat" on the screen and that's it. Since the "11" is being displayed, zone #11 on your wireless system as a low battery.
Jan 07, 2014 | Honeywell 5804 Ademco Wireless Security...
I changed the batteries in my Power Shot A720 IS recently when the low battery warning flashed, and had taken only two photos when the warning flashed again. I moved the mode switch to playback and the...
Hi, 1st you must use alkline bat or minimum 800 mhp bat....
and if problem is not solved then cheak the bat cap and connection clean with aomthing,,,,
If any thing else contact me
Khatricamera@gmail.com
Mar 27, 2011 | Canon PowerShot A720 IS Digital Camera
My beutler 800 said lo bat we replaced them and still reads bat lo
The other "solution" posted here is not a solution. According to this web site: http://www.espenergy.com/faq_honeywell_thermostat.htm
First, replace the batteries with a new set of AA alkaline batteries. If you insert the new batteries within 20 to 30 seconds of removing the old ones, you will not have to reprogram the thermostat. If the bAt Lo indication does not clear itself once new batteries are placed in the device install the batteries backward for 5 seconds, take them out, and reinstall correctly.
So I tried it... put the batteries in backwards. It completely reset the thermostat so I had to reprogram it (which was easy enough). One thing I did that the instructions did not specify. After I removed the batteries, I let it go completely blank before installing them backwards. Then I waited 5 seconds, pulled em out and put them back in correctly and eventually it started flashing indicating it needed to be programmed. HINT: Don't forget to set the current time!
Dec 04, 2010 | Honeywell Programmable Thermostat Heater
2000 ford mustang 3.8ltr bat died, charged and now motor cranks strong but will not start. always started easy prior to the bat goinf dead, what could it be?
you need to check out the Alternator...it might not be charging the battery...
if thats good then check if the battery is 5 years old...if so then you might need to change it...it might be that the battery doesn't hold the charge...
lets just hope that there is nothing wrong with the engine!
Good Luck!
Oct 11, 2010 | 2000 Ford Mustang
Screen says bat low
Found the manual online and it said to put the batteries in backwards for at least 5 seconds to re-set the thermostat. Amazingly, this worked.
Oct 01, 2009 | Honeywell Programmable Thermostat Heater
Ademco 6128 keypad beeping at random times & says bat on the display screen now - is there a battery in there we need to change?
you need to change your main control battiery.
the main control panel takes a 12 volt 7 amphour or a 12 volt 4.5 amphour battery. the larget the amphour the longer the system will last when the power is out. available at fry's radio shack or on line. ps: if the key shows a zone number with the bat, that means you have a wireless sensor low battiery.
mj
Aug 29, 2009 | Honeywell 5804 Ademco Wireless Security...
I can not locate anything on the camera that tells me when the batteries are getting low. am i missing something?
there is no "bar graph" to show you battey condition. However, it will warn you when they are getting low. You can still take many pictures with after low bat. indicators are flashing. You can take like 300 pics. with the camera.
I spent a week in on vacation & took 100's of pics. & looked at them later, on the same set of batteries (Not rechargeable bat. either).
Aug 05, 2009 | Canon PowerShot A620 Digital Camera
Casio FX-115ES Scientific Calculator Logo
126 people viewed this question
Top Casio Office Equipment & Supplies Experts
k24674
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
