Question about Haier HTE21WAAWW Top Freezer Refrigerator
If theires a punkture inside the frige can it effect the cooling ?
    Problem Solver:
  • 12 Answers
Yes
Posted on Feb 01, 2010
Was dripping inside frige,leaking from front bottom, is running.Frige not cooling for a few days. Now the freezer has stopped cooling
Is your compressor running. Check that and if it bis not then you probably just have a bad start device (relay/overload)
Jul 22, 2015 | Refrigerators
Frige not cooling on bottom freezer frige
Check the air vents, from the freezer to fridge. Air travels through those vents. Sometimes, products get shoved under the vents, preventing air flow. It sounds like, the vents are clogged with something. I guess, the fan is working inside, of the freezer? Ice in the bottom, of the freezer pan, could be clogging the vents. You'll have to dig deeper. Good luck.
Aug 16, 2014 | Kenmore Refrigerators
Kscs251 not cooling
Most likely your defrost element(s) are burned out and the evaporator coil is frozen over.
Aug 02, 2014 | KitchenAid Superba Architect KSCS25INSS...
Coleman 3 way refrigerator does not keep cool temperature
I would guess you have a refrigerant leak if I understand you. Have this guy pull a vacuum on the system and see if you lose the vacuum.
May 18, 2013 | Cars & Trucks
It is not cooling as well as it does usually. The freezer is cooling at frige temperture and the frige side is hardly cooling.
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
May 31, 2011 | GE Profile 23.3 Cu. Ft. Counter-Depth...
I have double door refrigrator and have cooling problem in lower portion
i am haven the same issue but lol mine is at the top i found out what it is the frige has no motor if u look closly you will see holes from the freezer side to the frige side that is what cools the frige. ur freezer needs 2 be defrosted by pulling evrything out then the back panel needs to be pulled out as well from the inside of the freezer and u may have to buy a heating element is what i did and it worked for a year now haven same issue lol but this time it is my thermastat i hope
Aug 15, 2010 | Refrigerators
REPLACED STARTER HOW LONG SHOULD IT TAKE TO FREEZE OR COOL?
it can take as long ans 3-4 hours to start cooling and then 8-12 hous to get to normal depending on the temperatures inside the refrige now. thanks peyton
Feb 18, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
My freezer is working but my frige is not cooling
wrong model # ,defrost problem. remove freezer panel, check heater, check limit switch while still covered in ice, if both ohm infinity, replace defrost timer.
Sep 15, 2008 | Haier HTP18GAA Top Freezer Refrigerator
Frige problem
This is almost a word for word common problem. On frost free fridge freezers of this type all cooling is generated through the freezer side and is merely forced into the fridge side through airflow. Therefore if you have a problem with the fridge you have a problem with the freezer section. The most likely cause is that the coil is frozen up. We would always suggest defrosting unit overnight in case it was simply a door left ajar being the cause of the fault. If the unit then pulls the fridge temp down and it was not the door ajar then you probably have a defrost problem (heater or defrost thermostat, or defrost timer). If it fails to pull the fridge temp down on restarting then it could be the fan or part of the defrost circuit or even possible the cooling circuit. The normal outcome after defrosting is that the temp will drop in the fridge due to air circulation improved, which will probably remain cool for 2-3 weeks until the coil becomes frozen again. On either result I would contact an engineer on the 2nd failure occurrs so that the engineer can establish the exact cause. Hope this helps.
Aug 13, 2007 | Maytag MZD2768G Side by Side Refrigerator
Haier HTE21WAAWW Top Freezer Refrigerator Logo
50 people viewed this question
Top Haier Refrigerators Experts
John Tripp
John Tripp
doggzzz
Level 1 Expert
Are you a Haier Refrigerator Expert? Answer questions, earn points and help others
