Question about Apple iBook G4 Mac Notebook
My screen is blank with a folder in the middle
    Guru:
  • 206 Answers
This is an icon indicating that the iBook G4 cannot locate the bootable Mac OS X volume on the hard drive.
Here is a procedure you can use in order to get back to your main desktop:
I am going to have you take your Mac into Safe Mode to see if we can't remove a possible folder(s) that may be affecting your Mac's start up function.
Try these steps:
-SAFE BOOT MODE-
• Reboot your Mac
• Upon restarting your Mac, press the Shift key.
• Hold the Shift key until you see a White Screen with Gray Apple icon and eventually a spinning gear.
• When you see the Spinning gear, release the Shift key.
• Allow the Mac to continue booting up. Also this may take a little while
(NOTE: this may take anywhere from 5 to 15 minutes to load to the Safe mode screen depending on the performance of your Mac, but if it exceeds this time, shutdown your Mac and try just once more. It may have just frozen up the first time around for you.)
• You are going to enter the Safe Mode (which looks like your main desktop environment - the only difference is certain startup items are disabled.)
• Once within the Desktop in Safe Mode
• From the Finder Menu, click Go> Go to Folder
• Type in this line: /System/Library/StartupItems
• This path, is going to take you to the System Library folder which has all of your Mac OS X Startupitems.
• Remove all of those folders to the Trash.
*Reboot your Mac normally and see if you can access your normal User desktop environment.
If this does not work, it could mean the Mac OS X directory on your iBook G4 may be damaged or corrupted. So the best step you can take to try to correct this without losing any data from your Home Folder(s) is to run an Archive and Install, with your Mac OS X installation disc.
What this process consists of (using your Mac OS X install disc),is removing the damaged or corrupted Mac OS X directory and replacing it with a brand new directory.
This procedure also allows you to save your applications, files and folders without the old directory no longer in the way of interfering with you accessing those files.
-ARCHIVE AND INSTALL-
• Start up from your Mac OS X Install Disc 1 or Install DVD. Please remember to use the install disc that matches the current operating system your system haves.
Usually, you can start from the disc by putting it in your computer, restarting, and holding the C key.
• Hold the C key until you see a White screen, with a Gray Apple icon and eventually a Spinning gear.
• Release the C key only after you see the Spinning gear.
-Your mac will now boot from the disc and load into the Installer environment.
• Select your language. The Welcome to the Mac OS X
Installer window appears.
• Click Continue. The Important Information window appears.
• Follow the prompts until you get to the licensing agreement screen
• An agreement sheet appears. If you agree with
the license agreement, click Agree. Then Select a
Destination window appears.
• Click the volume that you wish to install to (your primary
hard drive).
• Click Options. The installation options sheet appears.
• Select Archive and Install.
• Select the volume which already has Mac OS X installed.
• You should also select Preserve Users and Network
Settings, to preserve network and Home directory
settings.
• Click OK.
• Click Continue to begin the installation.
• Once the Archive and Install is completed, when you reach your desktop be
sure to run all Software updates to bring your new
Mac OS X directory back
up to current.
Also, if you look inside your Macintosh HD icon on your Desktop, look for a folder entitled "Previous System Folder" which will have all of your previous Home folder files prior to the Archive and Install.
Here is the link (below) from Apple for more information about how to locate the Previous System Folder
How to locate Previous System Folder (after Archive and Install)
If you don't have a Mac OS X installation disc, let me know.
Regards,
-Mactechtrainer
Posted on Feb 01, 2010
How do I password protect my iomega ego
Plug your USB imoga ego usb drive into your computer.
Click on the "My Computer" icon at the top of your computer screen.
Double click on the iomega USB icon.
Right click in a blank space in the middle of the window to pull up a small menu.
Select the "New Folder" option from the menu to create a new folder on your Iomega USB 2.0 drive.
Drag all of the files that you want to protect into the new folder you created.
Right click on the folder that you created and select the "Properties" option from the menu.
Go to the "Sharing" tab and click on it.
Scroll down to the "Make This Folder Private" box and check it. Click the "OK" button and wait for the window to close.
Use your Windows log-in password to open the file.
hope this helps
Oct 22, 2012 | Iomega 160GB Ego HD USB 2.0/FW Red 160 GB...
Vertical blanking
CHECK C2C52 10 UFD @ 50 V OFF THE BASE OF Q2C51 ON THE SIGNAL PCB. 2. CHECK C2P05 100 UFD 16 V OFF PIN 3 OF IC2P01 AND IC2P01 PART # 270P466020 (9-VOLT REGULATOR). BOTH ARE ON THE SIGNAL PCB.
Dec 06, 2007 | Mitsubishi VS-60705 60" Rear Projection...
Won't turn on
The problem in blank white screen is the display (LCD). Send it to a technician for repair. The blinking folder with a question mark is conflict on drivers. Have you installed a software lately? If you do please uninstall it. Maybe that is the cause of having a blank white screen.
Jul 12, 2010 | Apple MacBook Pro PC Notebook
My mac wont turn on.... when i switch it on there is just a blank screen and a little folder in the middle of the screen with a question mark in it and i cant use the mouse or anything, can anyone help me?
When you have that icon on the screen the computer is working but there is no operating system installed on the computer or the OS has been corrupt
What you need to do is reinstall the OS buy inserting you installation disk that came with your mac, reset the computer, and when you hear the charm hold down C until it boots into the disk.
Jul 20, 2009 | Apple Computers & Internet
Small text and screen blank top and bottom
try to replug the lcd connectors. you have to dismantle it
Jul 06, 2009 | Compaq Evo N620c Notebook
I turn on my mac and only this small folder icon appears in the middle of the screen
The face is probably frowning.  The computer cannot find the operating system.  Use a utility disk to boot up the computer and then use First Aid or Disk Utility to check the disk.  You may have to re-install the operating system.  This can be done without losing your files if done correctly.  Seek help from an Apple repair facility if you are in doubt about how to do it.
May 20, 2009 | Apple iBook G4 (Z0AZW13397068) PC Notebook
Middle of screen is blank
Your screen is probably damaged, and will need to be replaced, but try these:
The 5 Rs: Reset, Retry, Restart, Reinstall, Restore
Remember these five basic suggestions if you have a problem with iPod nano. Try
these steps one at a time until your issue is resolved. If one of the following doesn’t
help, read on for solutions to specific problems.
â Reset iPod nano. See “General Suggestions,” below.
â Retry with a different USB port if you cannot see iPod nano in iTunes.
â Restart your computer, and make sure you have the latest software updates
installed.
â Reinstall iTunes software from the latest version on the web.
â Restore iPod nano. See “Updating and Restoring iPod nano Software” on page 50.
Jun 02, 2008 | Apple iPod nano
File folder?
What you are seeing is the Mac's PROM telling you that it cannot find the "System Folder" The System Folder contains all the components of the operating system itself.
You have an option to boot from the install disks that came with your machine. Boot from the CD/DVD disk by holding down the "C" key. (Usually, this is not required. The Mac is smart enough to look on all connected devices to find a viable System Folder.
Anyway, once you have booted from the CD, you MAY be able to use Apple's "Disk Utility" or, if it's there, "Tech Tool" to repair the laptop's drive.
If you are unable to repair the drive, and, if it's not be physically damaged in some way, you should be able to re-install the OS.
This would be a good time to think about getting an external drive, and a copy of CC Cloner by Mike Bombich, and setting up a backup regimen.
ciao
Dec 16, 2007 | Apple iBook Mac Notebook
Apple iBook G4 Mac Notebook Logo
709 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
