Question about Dishwashers
Hi our dishwasher door is jammed shut and will not open. Help
  • 111 Answers
There is a safety feature that won't let you open the door when it's running,make sure all controls are in off position, make sure it has power going to it,if it still don't open, you may have to disassemble door to get at latch, lotta different latches and dishwashers out there,this is just a guess, hope it helps
Posted on Feb 01, 2010
Testimonial: "Thanks for your assistance. It is not a safety power issue i think it must be the latch but cannot see how to get the door off. Thanks anyway"
My dishwasher WQP12-9240A door will not open and my dishes are inside can you please help. Peta
Sounds like the door lock Mechanism is not shutting off , if still connected to power supply take out plug or turn off power for 10 minutes this may release door lock, this can sometimes reset a jammed programmer not always the solution but worth a try
Jun 25, 2014 | Dishwashers
Door locked shut
Hi found myself in same situation. Press in latch and insert fingers upwards there is a grey plastic strip push this up with fingers and door should open. Note upward press needed where this catch meets front of machine so just slide fingers up from latch/handle. There's actually no need to take top off to enable this.
Dec 27, 2013 | Smeg STX2 Dishwashers
The door on my aeg 40850 dishwasher is jammed shut. How do I release the latch or remove the door?
remove the top two screws at back, lift up about 5 degrees pull back, then you wll see the latch pins remove bolt/s,lift up trim{if it has some} and the door will open then remove inner door screws to get the front panel off to get at the latch
Jun 30, 2012 | AEG 24 in. Favorit 40850 Free-standing...
Dishwasher door stuck shut . How can I get it opened ? Thank you.
these doors should pop right open - some have latch releases, most do not..,. sounds like something is jammed up under the counter top preventing it from opening.
Best regards
Ck
Feb 16, 2011 | Maytag Dishwasher
I have a hotpoint aquarius dishwasher. although the door shuts it will not lock. Sometimes the door will almost shut but the lock seems to jam. Thanks Jim
Possible that this is a mechanical fault. So you might have to remove and clean the lock with a de-greasing spray and close the door few times as you oil it. this might solve the issue.
Please find help on the link below for tips to repair
Dishwasher
Dec 24, 2010 | Hotpoint 24 in. FDW60 Free-standing...
MDB7600aws Maytag dishwasher heats up with door shut when off
Your timer is jamming on the heat cycle. When you open the door the door interlock switch cuts the power off and stops the cycle.
Probably if you just close the door again it will heat again unless the machine is started again.
You need to repair or replace the timer.
Mar 16, 2010 | Dishwashers
Dishwasher door is jammed shut
Hi, I have the same dishwasher with the same problem. Basically i just have to pull it as hard as I can from both sides of the dishwasher door near the top, and it makes a loud "click" and comes open. Not sure what the problem is with it, but i've been doing that for a number of years.
Feb 01, 2010 | Dishwashers
Water keeps running
Hi
Sounds like the inlet valve has failed. You need to replace the part that the inlet hose is attached to
Feb 16, 2009 | Electrolux 24 in. EDW5505EPS Stainless...
Whirlpool g2p dwi
either the latch thats on the door is bad,,or the catch on the tub is out of line,,,now if the dishwasher door drops hard and wont stay up ..you need new door spring and the weight makes it pop[ open..
Feb 17, 2008 | Whirlpool 24 in. ADP5962 Free-standing...
Stopped partway through rinse cycle, doesn't power on again...
The problem is probably in the cycle switch/timer assembly. It probably burnt/shorted some contacts. This switch is of pretty intricate design, a bunch of wires run in and out of it and the turning action of the switch/timer opens and closes different contacts for pumps, heater, detergent door, etc... at different times in the cycle
Dec 20, 2007 | Danby DDW496W Free-Standing Dishwasher
Dishwashers Logo
150 people viewed this question
Top Dishwashers Experts
