Question about Arris SB5100 SURFboard DOCSIS 2.0 Cable Modem (50120900100)
How can I connect to xbox using this?? I plug the ethernet cord from the surfboard to the xbox360 and it says it isn't connected.. I can plug the same cord into my laptop and that works but it doesn't when I put it in the xbox.
  • 32,281 Answers
For instruction on how to configure/network the XBox please click on this link and follow the instructions :-
http://fixhomenetwork.com/xbox-play-station-wii.php
Posted on Feb 01, 2010
Connection to XBOX Live is not good
Hi!
Who is your internet provider and are you using an ethernet cord or a WiFi connection?
Thanks.
Jul 21, 2017 | Arris Surfboard Cable Modem Sb5105
Tip
Connect your 3g mobile broadband to an xbox360!
Have you ever wonder if you could connect your 3G mobile broadband modem to your xbox360? Well i have done it and it works fine.
What you will need to do is enable network sharing in your laptop/pc
I am using a vista laptop and orange mobile boradband, and this is how i done it!
First of all connect your 3G modem to your laptop/pc as you normaly would. Now get an ethernet cable and plug this into your laptops ethernet port and then into the back of your xbox's ethernet port.
Click on start> connect to> Then you will see "open network and sharing center" Click that. In the next window you will find all networks connected to your laptop/pc. You will see one below your normal internet connection called unidentified network. Click "view staus" Now in this window click and go to properties. now in this window click on the network tab at the top of the window. While now in this window click on enable network sharing via this device. Now go to your xbox360 and try to connect to Xbox live if at the first atempt it did not work test your connection via xbox as it will ask you to do this anyways. You should now be eable to connect to xbox live using your 3G modem.
Hope this helps!
on Dec 28, 2009 | Computers & Internet
Cant connect to xbox live
Make sure you are connected directly to the modem if you are using the usb cord .If you are using the wireless adapter make sure the code u imputed corresponds with your own.
Nov 15, 2010 | Microsoft Xbox 360 Console
How to hook your xbox360 to laptop to get on xbox live
wel if you have wireles internet you can get a wreles adapter for your xbox and conec it that way
Oct 25, 2009 | Microsoft Xbox 360 Console
I have a siemens gigaset se587 wireless router and a xbox360 network adapter it does not connect up to my network where am i going wrong I have connected it up using the ethernet cable and it works fine...
sorry to bother but i cant get xbox live to work with the ethernet cable, where did u plug the ethernet cable into? ive tried different places and none seem to be working
Oct 17, 2009 | Microsoft Wireless Network Adapter Xbox...
XBOX360 Wireless Adaptor does not see my already set-up wireless network. I have Verizon FIOS as my ISP and a Linksys Wireless-G WRT54G Router. I can plug an Ethernet cord into one of the ports on the...
Please follow the steps below to setup your Xbox with your Linksys Router:
  1. With your Xbox powered down, take an Ethernet cable and plug it into a numbered port on the router, and plug the other end into the Xbox.
  2. After you have your Xbox connected to the router, start up the Xbox without a CD in the tray.
  3. After you start the unit, you should arrive at the “Xbox Dashboard”. Select the Xbox Live option and press the “a” button on the controller.
  4. After “Xbox Live” loads select the Network Setup and press the “a” button your controller.
  5. On the “IP Address” settings, you can choose “Automatic” or “Manual”, make sure it’s Automatic.
  6. Select the Connect option and press the “a” button on the controller.
After you use the “Connect” option, the Xbox will detect the network cable, and will ask you if you want to connect to Xbox Live.
Aug 17, 2009 | Linksys Wireless-G WRT54G Router
Motorola Surfboard 4220 not working with my Netgear WGT624 router
Make sure that you have the ethernet cord from your modem plugged into the WAN/Internet port on your router. Then unplug the power cord from your cable modem and plug it right back in. After the modem fully comes back online, unplug the power cord on the wireless router and plug it back in. wait 30 - 60 sec and then try and connect.
Most cable companies only allow one active"CPE" at a time for internet access. All this means is when you change what is connected to the cable modem you must always reboot the cable modem to allow access.
Hope this helps. Let me know if it does not work.
Please rate.
Mar 23, 2009 | Arris SURFboard SB4220 Modem
Linksys router and modem problems
Most cable company's will not allow you to use the USB and the ethernet connection at the same time. You will need to only use ethernet to your PC and your XBOX. Once you have the ethernet cord connected from your modem to the WAN/Internet port on your router you will need to press the reset button on the back of the arris to authorise the router for access. After that is done you will plug you XBOX into 1 of the 4 numbered ports on the router. Then you will need an additional ethernet cord for your PC.
Hope this helps
Jan 04, 2009 | Arris SURFboard SB5120 Modem
Xbox live connection
three is the network
connect and install three usb modem
connect xbox to pc with ethernet cable
then start right click my network places and go to properties in network connections right click 3 usb modem then properties then advanced, tick the box allow other network users' then okay
now connect 3 3g device turn on xbox and BINGO !
Dec 15, 2007 | Microsoft Xbox 360 Console
Arris SB5100 SURFboard DOCSIS 2.0 Cable Modem (50120900100) Logo
145 people viewed this question
Top Arris Computers & Internet Experts
bobkoure
Level 1 Expert
Jerry
Jerry
Are you an Arris Computer and Internet Expert? Answer questions, earn points and help others
