Question about Dryers
The dryer is not producing any heat. What might
The dryer is not producing any heat. What might be the easy fix to try first?
  • 111 Answers
Look for reset button for heating element,high temp cutout switch if electric--airflow switch, high temp cutout if gas
Posted on Feb 01, 2010
Frigidaire dryer doesn't produce heat, but everything else is working. What do I do to fix that problem?
Unplug remove panels necessary
Check the element for breaks or issues
if no problems found replace the safety devices directly in line with the power supply for the element
Nov 15, 2011 | Dryers
My Samsong dryer runs and turns, but won't produce heat. Would I likely be able to look inside and see the problem? How easy would it be for me to fix it?
This will probably be your heating element, 99% of the time it is. You can look online with your model # and find a replacement one. I would need to know the exact model of the dryer to provide more help. I hope this helps you out :)
May 16, 2011 | Samsung DV448AEE Electric Dryer
My dryer has power and tumbles, but produced no heat (tested with vent tube off). I reset the circuit breaker and now it produces heat. What is up?
If your dryer is clogged up this will not produce heat inside the dryer but will produce heat to the vent tube. Try unclogging the Vent tube and see what happens.
I’m happy to help further over the phone at https://www.6ya.com/expert/al_e83b1941f9c0f302
Feb 18, 2011 | Dryers
Whirlpool Cabrio dryer gas does not stay lit after a few minutes.
It sounds like your solenoid coil(s) might be no good. Easy fix and not very expensive.
Jan 11, 2018 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
No heat
take off the back of the dryer you will see wires to the lint tube thats heating elements take the removeable plate off and see if its clogged with lint if so clean it out that should fix it if its not elements are probably bad. its also easy fix
Oct 17, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Gas Dryer won't produce heat
Hi, thanks for the inquiry.
It's most likely a thermal fuse. Basically, the voltage has to go through the fuse before it goes to the ignitor.
It should only cost you about $90 to repair if a technician comes out to fix a fuse.
I wouldn't try to repair it unless you have some knowledge of electrics. If your dryer is less than 12 years old, I would recommend you fix it. Hope this helps.
Best of luck :)
Aug 25, 2009 | Whirlpool Dryers
My dryer is running but it doesnt producing any heat. The dryer has air moving thru the system and the timer but no heat? it worked yesterday
One of three things is your issue.
1. Thermal fuse is bad
2. Thermistor is bad
3. Heat element is bad.
This is a newer type dryer that probably has control board also. Probably gonna need a service tech to come inspect unless inside parts are like an older style dryer.
Old dryers are easy to fix, but these new ones have parts like a computer in them making it harder to take apart and fix unless you have technicial background.
Make sure your lint trap stays clean all the time, this is usually the cause of one of the three parts above to go out prematurally.
Hope this helps
TankMurdock
Apr 27, 2009 | Maytag Neptune MDE6700A Electric Dryer
Dryers Logo
218 people viewed this question
Top Dryers Experts
