Question about Toshiba 1360 Black and White Copier
Toshiba 1360 first page is good. second copy is pale. third copy is paler then second etc. if i want good copy again, i ned to turn it off and wait 5 minutes
  • 26 Answers
You have a developer or charge problem.I would call for service.
Posted on Feb 02, 2010
How can I solve Toshiba e studio 257 photocopier toner problem?
Try turning the main power switch off or disconnect the power, wait 20 seconds then turn back on again. This should reset the toner.
Aug 29, 2016 | Toshiba Office Equipment & Supplies
Pale copies and two vertical white streaks
I'm afraid that regarding pale copies, you are better off checking your consumables (toner, fusers, etc) and then try talking to Toshiba. However, the vertical white streaks can be caused by excess ink and other contaminants on the inside of the printer. If you open the main door to both the printer and finisher (if fitted) and look at all of the visible runners, feeders and other handling devices, try to see if any of them line up with your vertical streaks on a page. If so, try manually rolling them and cleaning them thoroughly. This might help remove some of the streaking (it did on mine).
Hope this helps, Alistair
Feb 28, 2011 | Toshiba e-Studio162D Copier
I have a Toshiba 1360 copier. Went to use it
sounds like one of the charge corona wires broken or the hvt board blown
Jun 11, 2010 | Toshiba Office Equipment & Supplies
Toshiba 1360 B/W copier - top half is blank
if you watch closely on the right lower side of the machine you may see that the lower jam access cover is opening during paper feed-this normally indicates that the feed clutch is staying on for too long-remove clean and hope.
Feb 05, 2010 | Toshiba 1360 Black and White Copier
Blanc copie toshiba 1360
Hello sir; Check the charge corona wire, see does it broken, it located above the drum unit with blue tab.
Oct 11, 2009 | Toshiba 1360 Black and White Copier
Lproduce light copy on the right side of the paper.
It can be on ensemble of the reasons. More often - unevenly portioned developer on magnetic cyst develob unit . Extract him(it) and check, telling lies magnetic gross, magnetic hand must be even. The Second, abrade the rollers of the magnetic gross. They are calculated on 100 000 mineses, but can be used previously.The Third. The Corona of the carrying , lower can have a slanting or it is not enough clean from that edges, where beside you pale scene. The Second and third mirror are sometimes covered fine слоем the raid, which does not disappear simply pay attention to blank засветку if lamps blank засветки dirty, that will be a pale scene. Good luck!
Sep 15, 2009 | Office Equipment & Supplies
The ink level indicator is more than 1/2 full yet the print quality is pale. I cleaned printer heads several times, alligned etc., but still pale print quality. I changed ink cartridges, printed about 40...
try to change the properties of the printer. Usually it has a configuration to increase the printing quality.
And also, look for the configuration for ink drying wait time. Change it to long.
If you dont have any problems with your cartridge. then i think you should need some adjustments from your configuration.
well, i hope this works.. :)
Thank you.
Aug 08, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
No image
hi,easy clean optics section that include mirrors.if the mirrors full of dust there is the poblem.
try the first then another solution check scanner section or replace.
May 14, 2009 | Toshiba 1360 Black and White Copier
Toshiba
Check the corona wires.
Jul 26, 2008 | Toshiba 1360 Black and White Copier
Toshiba 1360 Black and White Copier Logo
99 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
Branko Djurdjevic
Branko Djurdjevic
CheckitRight
CheckitRight
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
