Question about GE GSH25JFR Side by Side Refrigerator
No water from dispenser in door .... ice machine works but no water.
  • 619 Answers
If this is a GE the water supply in the freezer door is frozen. Quick easy way to check is disconnect at the bottom of the freezer door and close door and activate the water switch and see if water getting to that point. If it is turn off ref and use a hair dryer on the upper section around thr recessed area and defrost the ice line. Will take a while so be patient.
Posted on Feb 01, 2010
  • robjob1 Jan 04, 2011
    The troubleshooting that was given worked like a charm. Thank you!!!
HVACRH20
  • 237 Answers
SOURCE: Roper RS22AQXMQ00
When you try to get ice does it make any sounds (clanks, whirring, grinding,etc.) like something is happening inside or is it just quiet? If quiet, see if you can look up inside the door switch area with a flashlight and press the button with your finger instead of the lip of a glass. Post more info when you have it and we'll go from there.
Posted on Dec 14, 2006
SOURCE: Jenn Air JCD2389GES ice dispenser problem
my ice maker is not making ice.
Posted on Mar 26, 2008
tech master
  • 120 Answers
SOURCE: kitchenaid superba 42 side by sside water dispenser
usually when i get a kitchen side by side i trouble shoot the wtr valve first by using a cheat cord that applying volatge directly to the vlave to see if it opens but usually the wire harnes under frezeer breaks the wires so my money is on the wires under the frezerr door cut the sleve off and chec the wires one by one the one to the water is broken
Posted on Nov 03, 2008
  • 16 Answers
SOURCE: No water to door dispenser
The water lines might be frozen. The found the water lines in my fridge behind the bottom drawers and used a hair dryer to melt the ice.
Posted on Jan 23, 2009
SOURCE: Front ice/water dispenser stopped working.
I had the same problem. Turned out to be a microswitch under the lever used to activate it. The microswitch fell from the original position so it wasn't turning on anything. I tried gluing into position but the fumes from the crazy glue messed up the switch and I had to replace the whole rig.
The part is under the control display. You can pry it open from the left side.
Posted on Jun 04, 2010
Ice maker isn't working. Water is not filling the tray but the water dispenser in the door works fine.
could be frozen water fill tube to Icemaker. or solenoid water valve is not opening when ice maker calls for ice. there are 2 separate solenoid valves : one for dispenser another one for ice maker.
Mar 28, 2015 | Refrigerators
GE profile refrigerator ice maker not working
Ice dispenser doesn't work
  1. Dispenser control board
If the ice dispenser is not functioning at all the most likely cause is going to be the dispenser control board. The dispenser control board governs the major portion of the systematic functions of the dispenser and is less likely to be the issue if only certain components are malfunctioning. If the dispenser control board is at fault, it will need to be replaced.
  1. Water inlet valve & low water pressure from house supply
If the ice dispenser on your refrigerator is not working properly, one of the first things to consider as an issue is the water pressure to your appliance. The ice dispenser cannot properly function with a psi less than 20. If psi is appropriate, proceed to replace the water inlet valve to correct the issue. You may also be dealing with low household water pressure. This low flow can be examined by using a water pressure test gauge. Once the household water pressure is resolved, you can double check your refrigerator connection to ensure it is now flowing properly and that the ice dispenser is functioning.
  1. Water tube in door is frozen
If the ice dispenser is not working on your refrigerator, the issue could be a frozen water supply tube located in the door. Although this may be a tricky problem to locate, the first thing to do is find a connection point in the tube. After this has been found, attempt to blow air through the tube. If the air flows freely through the tube, it is not frozen and this is not the issue. If it does not, the tube is frozen and needs to be removed to thaw out. As it thaws, attempt to ascertain why it froze and correct the positioning of the tubing to prevent the issue from occurring again in the future.
  1. Dispenser switch
If the refrigerator ice dispenser is not working properly you could be dealing with a defective dispenser switch. Activated by the dispenser actuator, the switches are responsible for numerous actions including ice cube disbursement, type of ice, and water controls. The switch can be tested using an ohm meter and should be replaced if it does not reveal continuity.
  1. Door switch
If the refrigerator ice dispenser is not working, the functionality of the door switch can be inspected. This switch is responsible for turning on the light in the freezer and simultaneously turning off the ice dispenser when the freezer door is opened. If this switch malfunctions, it will show no continuity on the ohm meter and will require replacement.
  1. Dispenser switch
  1. Door switch
Water dispenser doesn't work
If the water dispenser is not functioning at all the most likely cause is going to be the dispenser control board. The dispenser control board governs the major portion of the systematic functions of the dispenser and is less likely to be the issue if only certain components are malfunctioning. If the dispenser control board is at fault, it will need to be replaced.
If the water dispenser on your refrigerator is not working properly, one of the first things to consider as an issue is the water pressure to your appliance. The water dispenser cannot properly function with a psi less than 20. If psi is appropriate, proceed to replace the water inlet valve to correct the issue. You may also be dealing with low household water pressure. This low flow can be examined by using a water pressure test gauge. Once the household water pressure is resolved, you can double check your refrigerator connection to ensure it is now flowing properly and that the water dispenser is functioning.
If the water dispenser is not working on your refrigerator, the issue could be a frozen water supply tube located in the door. Although this may be a tricky problem to locate, the first thing to do is find a connection point in the tube. After this has been found, attempt to blow air through the tube. If the air flows freely through the tube, it is not frozen and this is not the issue. If it does not, the tube is frozen and needs to be removed to thaw out. As it thaws, attempt to ascertain why it froze and correct the positioning of the tubing to prevent the issue from occurring again in the future.
  1. Dispenser switch
If the refrigerator water dispenser is not working properly you could be dealing with a defective dispenser switch. Activated by the dispenser actuator, the switches are responsible for numerous actions including ice cube disbursement, type of ice, and water controls. The switch can be tested using an ohm meter and should be replaced if it does not reveal continuity.
  1. Water filter
If your water dispenser's flow is running slow check to ensure that your water filter is not clogged. If after checking you determine that the filter is clogged, simply replace the filter. Filters should be replaced every six months to ensure clean drinking water.
  1. Door switch
If the refrigerator water dispenser is not working, the functionality of the door switch can be inspected. This switch is responsible for turning on the light in the freezer and simultaneously turning off the water dispenser when the freezer door is opened. If this switch malfunctions, it will show no continuity on the ohm meter and will require replacement. Appliance Repair Help Troubleshooting and Appliance Parts
Aug 18, 2014 | GE Refrigerators
Ice machine not working
  1. Dispenser switch
  1. Door switch
Ice maker not functioning or producing ice cubes
  1. Check connections
Check all hose connections to ensure that water is being transmitted through your appliance and there is no frost build up.
  1. Feeler arm
Double check to make sure your feeler arm is not stuck or that ice cubes are not blocking the feeler arm's motion to produce more ice.
  1. Ice maker heater
The heater may be stuck on. The heater comes on for 1-2 minutes to break cubes free from mold. If the heater stays on too long ,the ice maker will get hot and stop making ice. Carefully feel around the ice maker mold; if it is hot to the touch, the heater is on. This indicates that the ice maker is jammed, and it is better to replace ice maker than to try and repair it.
The water valve supplying the ice maker is a key component of the ice-making system. When the ice maker calls for ice, its switch closes an electrical circuit and energizes the solenoid-operated water valve. This allows water to flow through the valve and into the ice cube tray. The water is frozen into cubes, and the cubes are dumped into the ice bin. When this part is not operating correctly, a repair/replacement part may be needed. Refrigerator Repair Help Troubleshooting and Parts
Aug 17, 2014 | GE Profile 26.6 cu. ft. Side-by-Side...
I have an Amanda double Door refrigerator with an ice & water dispenser. The ice machine unit's dose not dispense ice cubes,
If the unit is making ice and the water will work from the door but the does not dispense, you will need to replace the "auger motor". Here is the part to order.
Nov 28, 2012 | Amana 22 cu.ft. Side-By-Side Cabinet Depth...
GE GSH25JFRF BB ice maker doesn't dispense. Water dispenses and ice maker makes ice but won't come out.
There should be a plastice hinge cover on the left top hinge on freezer door. Take it off and press the plug together firmly. Try that and let me know, Sea Breeze
Aug 19, 2012 | GE Refrigerators
Ice maker stopped working
sadly you need to turn off the fridge let it dry out with the doors open then turn it back on.
Mar 31, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Jan 23, 2009 | Hotpoint HSS25GFP Side by Side...
Ice maker not getting water
PULL THE TUBE BEHIND THE ICEMAKER OUT AND SEE INSIDE IF IT IS FROZEN,IF NOT ALL THAT'S WRONG IS THE WATER INLET VALVE ON LOWER BACK OF FRIG.IS BAD,YOU HAVE A WATER DISPENSER HOSE ON ONE SIDE AND A ICEMAKER HOSE ON THE OTHER,THE ICE MAKER SIDE OF THE VALVE IS BAD,THANKS-MIKE
May 29, 2008 | Whirlpool GS5SHGXLS Side by Side...
Ice dispenser comes on by itself.
you need to replace the dispenser selector board.
Sep 03, 2007 | Frigidaire FSC23F7D Side by Side...
GE GSH25JFR Side by Side Refrigerator Logo
235 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
