Question about Sony Playstation 3 (PS3) Console
Im trying to connect my playstation 3 up via hdmi, when setting up it says it detects the hdmi cord do you want to use it and i say yes then the screen goes black for 30 seconds, i have tried switching the tv to the hdmi iput unpluging the av cord when selecting the hdmi output but nothing seems to work please help!
  • 20 Answers
Have you tried using another HDMI device with any success on the same port? It would be good trying something else on your TV just to make sure the TV isn't the problem.
Also, try turning your PS3 off, then, while it is off, hold the power button down for about 5 seconds. The system will beep, and it will reset the video settings. Try your HDMI setting one more time, but this time set it to 720 p to make sure the resolution isn't too high for your television.
If none of this works, you could possibly have a faulty HDMI port on your PS3. I've seen it happen before.
Posted on Feb 01, 2010
I have my ps3 plugged in but powered off so just a red light is on.i push power button light turns green I hear fan come on and everything sounds normal but it has no picture at all.it takes cd no pro
Rudy, are you connecting to the TV with HDMI, or RCA cords? HDMI carries both picture and sound thru 1 cord, whereas RCA splits it to YELLOW RED and WHITE. The HDMI connection is automatically detected when connected to your TV. It will say"HDMI is detected, do you want to use these settings?" RCA is not automatic, and is prone for the video(YELLOW) cord to develope a bad connection. I wouls duggest first replacing the cord. They are inexpencive, and the fastest way to check your issue. I am going to include a link to a youtube video that will guide you through the steps on how to reset your video settings on your system.
How To Reset PS3 Video Settings PS3
Oct 08, 2014 | Sony Playstation 3 (PS3) Console
Tip
Playstation 3 has sound but not showing picture
It sounds like you have changed your display settings either to HDMI but are not connected with HDMI or you have set the progressive scan to ON and it's not supported by your TV. Try turning off the Playstation 3 and then hold the power button for about 5 seconds, until you hear a second set of beeps. This procedure will reset your display settings, then auto detect your connection, provided you have kept up with the updates. If you have kept up with the updates or aren't sure, you can use the same steps, but you will need to be connected via Composite Cable and not HDMI. If this doesn't work, you may need to send it in for reparis.
on Nov 25, 2013 | Sony Playstation 3 (PS3) Console
Samsung TV Is Not Picking Up A Playstation 3 HDMI Signal
If you are able to connect your PS3 to another TV using the same HDMI cable that would rule out your PS3, if it works.....or
does the PS3 itself have any settings that perhaps need to be set to an HDMI output as opposed to Composite or SCART etc?
Also have a look at the HDMI settings in theh TV menu too.
Jan 10, 2014 | Video Game Consoles & Games
I have a panasonic Th-42pv500a. I'm trying to connect my ps3 Via HDMI but it won't work. The ps3 works in my other tv with the same HDMI cable. And the foxtel box works in the panasonic with the same HDMI...
the playstation detects that you are changing display settings. hopefully you still have the old red yellow and white cord that we all used to use to plug in stuff to your tv . use this cord to connect your playstation to the tv, it should pop up that you want to change display settings. then after you go through that unplug and recconect the hdmi and it should run you through it again, Another option - when you plug in your ps3 to the tv , turn everything on the tv and playstation. if nothing pops up turn off your tv and playstation , literaly unplug them from the outlet for a good minute then plug everything back in and you should fix it that way. hope one of these work
May 04, 2011 | Televison & Video
My ps3 was recently connected to a hdmi cord at my friends house now im back home nd i plug the av cords in and nothing is coming up its still connected to the hdmi
Hello. Sounds like you need to adjust the video output setting back to component. Go to settings, display settings, then video output setting. you may need to do this under an hdmi connection in order to see it. Once you change it to component then it will switch over to a standard AV connection.
Apr 05, 2011 | Sony Playstation 3 (PS3) Console
When i connected my ps3 and plasma via a hdmi cord, i was asked "connect via hdmi - yes/no". i selected yes. Subsequently my hdmi card is faulty on the plasma and now have connected via av cables again but...
Ok you just have to do a video reset on the system, this is easy. first turn the system to standby/off with just the red light on. Then hold the front power switch (the system will turn on) till it beeps twice and shuts down. Then turn the system back on, this will reset the video/audio output to its default settings which are AV.
Dec 02, 2009 | Sony Playstation 3 (PS3) Console
My ps3 is hooked up to my tv via HDMI cord. The
1 - Turn on TV and set input to port being used.
2 - Make sure PS3 is connected via correct cable.
3 - Power on PS3 via power button and HOLD IT for 5 seconds (release after the second beep). It should automatically configure your PS3 to the TV's native resolution for all settings.
Then after that change the output setting to HDMI on your PS3 and see if it works after that, if not, try the system on another TV to make sure its not a problem with your tv.
If it still doesn't work try another cable and then after that it could be a problem with the main board inside of the ps3.
Nov 30, 2009 | Sony Playstation 3 (PS3) Console
Can't watch dvds on playstation 3
No, but you do have to select HDMI output in the settings in the PS3 menu and make sure the TV is switched to the correct HDMI input ( Whatever one you plugged your PS3 into)
Mar 13, 2009 | Sony PlayStation® 3 (80GB) Console
No picture connected via HDMI
Your PS3's HDMI settings may be the issue. When you go to turn on your PS3 next time, instead of just pressing the poser button and letting go, hold it for 5-6 seconds until it beeps again and then let go. This will force the PS3 to autodetect your TV again and should bring up the video. good luck!
Jun 19, 2008 | Sony Playstation 3 (PS3) Console
PS3 no longer communicating with TV
All: Try this -
P
erform the following steps to reset the Video Output Settings.
  1. Make sure the HDMI cable is connected to the [HDMI OUT] port on the back of the PLAYSTATION 3 system. Connect the other end of the HDMI cable into the [HDMI Input] port of the TV or display monitor.
  2. While the PLAYSTATION 3 system is in standby mode (red light on the front of the system), hold down the touch-sensitive On/Off button on the front of the system until the system goes into standby mode again . (So the light cycle would go from: red light to --> green light --> then back to red light) This will ensure that you have held down the On/Off button long enough to reset the Video Output Settings.
  3. Turn ON the PLAYSTATION 3 and once the system finishes powering up, the Video Output Settings will automatically reset to the standard resolution (or detect the current display output settings of your TV/monitor). [If resetting does not auto-detect your HDTV, see next step below.]
NOTE: As of system software update version 1.60, the PLAYSTATION 3can automatically detect an HDMI connection to a TV. If the PLAYSTATION 3 is turned on with an HDMI cable connected, the screen for switching video output settings will be displayed automatically. (Does not function unless the TV that is connected by the HDMI cable is turned on.)
As of version 1.80 of the system update for the PLAYSTATION 3, the PLAYSTATION 3 can upscale the video content of PlayStation® format software, PlayStation®2 format software, and DVDs to HD resolution.
If Resetting the Video Output Setting Did NOT Detect Your HDTV Automatically (Certain TV's Only)
With certain televisions, the PLAYSTATION 3 may not automatically detect the HDMI source (TV) which it is plugged into, even after resetting the Video Output Setting (as described above).
If resetting the Video Output Setting did not work, you may need to follow these steps to manually locate the HDMI source:
1. Connect both the AV Cable and the HDMI cable from the PLAYSTATION 3 to the corresponding (AV and HDMI) ports on your TV. 2. Proceed with resetting the Video Output Setting on the PLAYSTATION 3 again. (Follow these steps, then continue to step 3 below.)
3. Turn the TV channel to the corresponding "Input" or "Video" channel for the AV Cable connection.
4. Manually change the Video Output Settings to HDMI. (Follow these steps, then continue to step 5 below.)
5. Now switch the "Input" or "Video" channel on the TV for the HDMI port the PLAYSTATION 3 is currently plugged into.
6. Accept the display settings for HDMI before the timer runs out (30 seconds). Highlight "Yes" and press the X button.
7. You can now disconnect AV Cable from the PLAYSTATION 3 and the TV, as it is no longer needed.
Dec 16, 2007 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
161 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
