Question about Broadcom BCM5721 NetXtreme Ethernet Controller for Servers
How i istall ethernet driver from internet - Broadcom BCM5721 NetXtreme Ethernet Controller for Servers
  • 415 Answers
If you have no internet because the ethernet controller was not installed, you will need to download the ethernet drivers from another computer.
To do this, you will need either the motherboard model or the ethernet controller model. Search google for your motherboard model, and then on the drivers page, find "LAN drivers". Download the drivers, save them to a usb and transfer and install them to your pc.
Posted on Feb 01, 2010
Marvell yukon ethernet shows with yellow exclamation mark and will not allow me to connect to internet
The driver should be on the motherboard disc or the one supplied by your ISP internet service supplier
make very sure all leads are plugged into their specific connection plugs you might have to connect the usb lead to your modem to get a connection then
click start control panel,administrive tools,computer management,device manager scroll to network adapters could see a yellow question mark? right click install drivers
hope this helps if you cant find the driver hopefully one of these will help you
http://download.cnet.com/Realtek-RTL8139-Family-PCI-Fast-Ethernet-NIC/3000-2112_4-91313.html
Realtek RTL8139 Family PCI Fast Ethernet NIC
http://download.cnet.com/Realtek-RTL8168-8111-PCI-E-Gigabit-Ethernet-NIC/3000-2112_4-99235.html
Realtek RTL8168/8111 PCI-E Gigabit Ethernet NIC: The Realtek RTL8168 Gigabit Ethernet controller combines a triple-speed IEEE 802.3 compliant Media Access
http://download.cnet.com/Realtek-RTL-Gigabit-and-Fast-Ethernet-NIC-Driver-Windows-2000-XP-XP-64-bit/3000-2112_4-10278840.html
Drivers for RTL8100B(L)/RTL8100C(L)/RTL8101L/RTL8139C(L), RTL8139C(L)+/RTL8139D(L)/RTL8100(L), RTL8130/RTL8139B(L)series. Windows
Feb 08, 2012 | Marvell Yukon 88E8001/8003/8010 PCI...
Driver CDROM MFC-J410W will not load
it seems that your windows get corrupted. format your pc and then istall the new window.then the cdrom driver will also loaded automatically. otherwise you can download cdrom drivers from the internet and can update your existing cdrom driver
May 31, 2011 | Brother Office Equipment & Supplies
No ethernet drivers
if your internet modem has an ethernet connection the drivers should be on the disk provided by the internet provider control panel admistrive tools,computer management,device manager scroll down network adapters +expand Ethernet driver right click update driver,disable,uninstall or select properties general you can trobleshoot or driver to update,rollback or uninstall
hope this helps
Oct 23, 2010 | Computers & Internet
I have installed windows xp sp2 into my hp compaq dx2300 microtower, but i am asked to activate over the internet or call microsoft representative for an istallation ID. the computer is failing to activate...
Check your Ethernet device in device manager option. Click on the "Network adapter" option in device manager. Now re-install with your motherboard installation disc or click on "Update driver" option, it will automatically run and fix your problem.
Jul 19, 2010 | HP Compaq dx2300 Microtower - RT950UTABA...
DRIVER NEED FOR ASUS M2N MX SE PLUS FOR WINDOWS XP
Dear! Please go to www.asus.com and give your motherboard's Number in search bar and download your motherboard's driver and istall it and ready to use it easily.
Nov 27, 2009 | ASUS M2N-MX Motherboard
Speedstream 6520 driver
Windows doesn't detect Ethernet connected devices. You could hook up a dozen Ethernet Modems and Windows would not see any of them, but they all would work fine using TCP/IP. It is not like you installed the DSL Modem/Router inside the case of the PC. You do know how Ethernet works, right? The only driver needed is the correct one for your Ethernet card, but that comes the Ethernet Card or the Motherboard Drivers CD for onboard Ethernet.
Found a few things, here are some websites to try:
Troubleshooting: Here
USB Driver for your Speedstream: Here
Sep 25, 2009 | Computers & Internet
I like to download ethernet controller driver but not from driver detective as this require an internet connection to complete what i want to do.
you nedd to go to a website and download an updated ethernet controller driver are useless because you can't even access the internet without the ethernet controller, unless you have a second PC already hooked up to work with the internet, then make a copy of the ethernet driver, and then copy it onto the original PC to get it acces the intenet. Most people may have to go to a computer repair store and ask if they can buy the ethernet controller driver for their OS and PC on a CD or flashdrive, or instead, but an external Ehternet controller device and connect it to your PC via USB.
Jun 19, 2009 | Compuware DriverStudio (dd-rstd-np/nm31)...
Adapter issue
Pls reconnect the Ethernet cable back to the other PC and check how is its getting IP address, automatic (Obtain an IP...) or fix (Use the following...). To do this go to your Control Panel, click on Network Connections, right click on Local Area Connection, click on Properties, highlight Internet Protocol (TCP/IP), click on Properties button. If it is the latter, note down the numbers.
Plug the Ethernet back to your laptop and do the same. Set your laptop's Internet Protocol Properties to mimic the other computer settings. The only possible difference would be is if the other computer is ticked on "Use the....", the IP address of the laptop should be different from the other PC. Example if the other PC is 192.168.1.5, make the laptop 192.168.1.6. All others stay the same.
Hope this ne of help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Jan 24, 2008 | Broadcom BCM5704 10/100/1000BASE-T...
Computers & Internet Logo
1,570 people viewed this question
Top Broadcom Computers & Internet Experts
Prashant M
Prashant M
Laxman Bisht
Laxman Bisht
Computer Links
Are you a Broadcom Computer and Internet Expert? Answer questions, earn points and help others
