Question about Savin 9935DP Laser Printer
Savin 4090 error code
I have a Savin 4090 copier that has a error code SC495. What is this?? It will run about 100 copies and then the error will appear. Any help will be much appreciated.
Beth
  • 1 more comment
  • HesDaley Feb 21, 2008
    The error codes did not list any for Savin 4090 copier
  • Anonymous Mar 17, 2014
    Savin copier
  • Anonymous Mar 30, 2014
    my savin 9920dp copier is showing error massage sc320 what is the solution?
Hi this code means they are no toner in the toner hopper which is attached to the developer unit. hope this helps.
Posted on Jul 26, 2008
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Savin Master
  • 1,362 Answers
Check this link, look under error codes
http://checkitright.spruz.net/main.asp?page=dp&dis=592197
Posted on Feb 18, 2008
  • 313 Answers
Check the waste toner bottle is set properly or it may need to be emptyed if the waste toner is not full check the sensor at the back to see if it is actuating properly
Posted on Jun 24, 2009
Ricoh aficio mp2105 error code sc495 how to recover
http://terraofficesolutions.com/forum/index.php?topic=36.0
Quoting from the link above:
Ricoh Error Code 495, SC495 Fix - Printer, Copier, Fax Machine « on: October 02, 2012, 11:18:43 pm » The Ricoh copier error code 495 / SC495 is a toner recycling unit error code.
If you receive this error you will want to check:
Your Waste toner transport is nor working ( motor overload )
Check Toner end sensor detective, (is not connected )
If the problem persists you may need to contact a local service technician to take a look at your copier.
Contact us by phone, email, or reply to this post with any questions you may have, we can always help.
Steve Jensen
steve@terraofficesolutions.com
(760) 580-4190
Mar 21, 2018 | Ricoh Office Equipment & Supplies
I have a savin 9060 and it is telling me I have an error 92 can u help me??
What do error codes 91 and 92 in the error log mean?
91: The job was reset by the device.
92: The job was manually reset by a user.
Dec 18, 2014 | Savin 9060 Copier With Feed, Finisher,...
SC392 ERROR CODE
There's a video showing how to clear SC error codes: Resetting Ricoh Savin Lanier SC Error Code There's also a discussion here: Thread Ricoh Aficio 220 error SC392
Jun 30, 2014 | Ricoh 885288 Black Copier Toner Cartridge...
My Savin SDC 103 has an SC-172 call service error. The copier was given to me, it only has 7800 copies on it. The error showed up after they moved it.
That code is related to the scanner unit.
Probably after they move the machine the lamp went out of position.
I advise you to see the all scanner; Lamp, Mirrors, White plate...
May 23, 2011 | Savin Office Equipment & Supplies
SAvin error code Sc542 need to reset
press clear mode once- its a yellow button
pres 107 clear/stop and hold for a while untill you see the screen changes to copy sp mode. this is the machines service program mode.
press copy sp on screen and off and on the machine.
it should reset the code. if not email me on ronils_singh@yahoo.com.au. i am a Ricoh techinician
Sep 30, 2010 | Savin 8035e Copier
I have the same problem with a Ricoh aficio 700 SC495
check the door contacts and the contacts on the transfer unit these need to be clean also
Sep 17, 2009 | Savin 9935DP Laser Printer
Savin error code E-547 error code?
Fusing unit trouble.Clean the thermofuse and thermistors,check the heater lamp.After ,enter in the service mode turn the power switch OFF unplugged the crd.Wait 10 sec. plugg the cords and turn ON the machine.I think the Savin is based the Ricoh copiers machine.The service enter code is : Press the toral clear key - 1 - 0 - 7 -hold down the C key more 3 sec.
Aug 17, 2009 | Savin Office Equipment & Supplies
Ricoh 2051SP error code J013 & SC495
SC495 is a toner recycling system error, due to strain on the system. Most likely due to a blockage. system needs to be removed and thoroughly cleaned. J013, is simply a jam, and this would be happening because of the toner recycling system being locked up, and seizing the motor. You DEFINITELY need a tech for this.
Jul 16, 2009 | Ricoh Office Equipment & Supplies
Copier reset procedure.
hi fixya180,
It seems that the error code 541 (which indicates a problem with the heating unit thermistor in the machine), cannot be reset by the user for safety reasons, ref;
http://savin.custhelp.com/cgi-bin/savin.cfg/php/enduser/std_adp.php?p_faqid=7081&p_created=1102093227&p_sid=9TrLDc-i&p_accessibility=0&p_lva=&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PWRmbHQmcF9ncmlkc29ydD0mcF9yb3dfY250PTQzNiZwX3Byb2RzPTI1MTAsMjUxNCZwX2NhdHM9MCZwX3B2PTIuMjUxNCZwX2N2PSZwX3NlYXJjaF90eXBlPWFuc3dlcnMuc2VhcmNoX25sJnBfcGFnZT0xJnBfc2VhcmNoX3RleHQ9ZXJyb3IgY29kZQ**&p_li=&p_topview=1
This error requires service support from your local authorized dealer or original point of purchase. You say that you've verified the functionality of your fuser unit; then a authorized Savin printer technician will probably just have to reset the error code of your copier.
Hope you find this info helpful in solving the problem and thanks for using the FixYa service
Kind regards
Mar 07, 2008 | Computers & Internet
744 people viewed this question
Top Savin Office Equipment & Supplies Experts
quennie732
Adorjani Laszlo
Don  Farrell
Don Farrell
Are you a Savin Office Equipment and Supply Expert? Answer questions, earn points and help others
