Question about Hotpoint FFS70 Bottom Freezer Refrigerator
The drain pipe fizes within days of total defrosting and water starts dripping in the refrigerator creating a big mess. I have defrosted the fridge and the drain pipe several times but the problem persists. There is always a lot of ice under the sliding pan and on the aluminum pan.
  • 291 Answers
You will need to install a drain line heater or heat probe. When water is plugged up in the drain line, it freezes and expands. This sometimes destroys the insulation around the drain line, which causes the drain line to freeze up all the time. If you have a cal rod type defrost heating element( black metal element) Whirlpool has a drain line heater, whish is a long metal finger that clamps around the defrost heater and sticks down into your defrost drain tube. This heats up the line every time your refer goes into defrost. We have seen customers use a small length of metal wire to do the same thing, electrical or even a clothes hanger. If your defrost heater is glass,then you will have to figure out how to wire in an electical drain line heater. Ask your parts house to check with GE to see if they have one. Sub Zero has a couple but you will have to figure out how to wire it into you defrost wiring. Good Luck, Appliance Specialists
Posted on Feb 01, 2010
RF261BEAESP
Check the pipe that drains the water from the avaperator (the thing that gets cold inside on the fridge)
periodically your fridge will defrost and the water should drip through a tube and collect at the rear of the fridge
If the pipe is blocked the water collects inside at the bottom ( under the crisper)
Apr 15, 2014 | Samsung RF261BEAESP 25.5 cu. ft. French...
Kenmore 10677181791 water dripping into refrigerator from freezer
probably an ice buildup around the drain tube not allowing proper flow thru to the drain. Try defrosting fridge for a while so the entire ice mass defrosts in between fridge and freezer
Feb 09, 2012 | Kenmore Refrigerators
Samsung Fridge Freezer leaking water
hi August.
Cause: A blocked defrost drain is one of the most common causes of water leakage. This happens when food particles or other debris clogs up the drain hose, which can lead to ice buildup and, eventually, water leaking out of the freezer and refrigerator.
3 common refrigerator problems you can easily fix yourself
The freezer drain hose will drain the defrost water into a drip pan at the bottom of the freezer. When this pan becomes full, it will leak water onto the floor. This is a regular maintenance task whenever the freezer defrosts. Empty the drip pan during the defrost cycle.
How to Fix Water Leaking From the Bottom of Freezer
Why is my fridge leaking water on the floor? If the refrigerator is leaking water it's possible that the refrigerator has a clogged or freezing defrost drain. If the defrost drain freezes the defrost water will overflow the drain and drip down to the bottom of the compartment, If enough water accumulates in the bottom it can run out onto the floor.
SOLVED Water leak in refrigerator Refrigerator
Dec 03, 2017 | Samsung CoolTech Plus / Basic Bottom Mount...
Water is not draining into pan. it is going inside fridge under
sounds like a drain clog in the freezer compartment above. remove the freezer rear panel and totally defrost the evaporator area, directly under the evap you see( under all taht ice) a small drain hole that has become frozen over, try defrosting with either a hair dryer( not a heat gun too much heat youl melt everything) or by pouring hot water donw the drain until you get a free flow of water down the tube. after its clear reassemble and you should be fine
Mar 17, 2009 | Kenmore 21.7 cu. ft. Top Freezer...
Water in my fridge
Nov 18, 2008 | Kenmore 61282 / 61284 / 61289 Top Freezer...
Whirlpool fridge getting water from upper freezer compartment
well if you hat the freezer on top normaly air leaks inside freezer through the drain tube, that air turns into condensation and creates a ice and cloges your drain. now water can drain down to pan everytime ref goes into defrost , and water leaks to bottom section to air ducts and air returns. there are several ways to solve this problem the cheapeste way is to unplug refrigerator for 2 days then plug back up and it should go back to normal another way is to install a heat probe on your drain attached to your defrost heater , and add a grommet on drain tube that will let water drain but it will keep air out and that will solve your problem.
Oct 12, 2008 | Whirlpool Refrigerators
Our Whirlpool top freezer unit is leaking water into the refrigerator. The model number is ET21NKXGW01 and at the top of the inside of the fridge, water is draining out into the fridge. The defrosting...
We were able to fix the freezer water leak. We unscrewed the false freezer floor and the inside back panel. Ice had accumulated on the freezer floor and the defrosting drain was frozen. We removed the ice by using a blow dryer then poured boiling hot water onto the frozen drain hole. The frozen water in the drain pipe hole eventually melted and the water released into the defrosting drip pan at the bottom of the refrigerator. Problem solved. We no longer have water leaking into the refrigerator.
Aug 05, 2008 | Refrigerators
Bosch intelligent frost free 40
The small drain pipe on the back of the fridge gets clogged, hence no drainage when defrosting, hence ice blocks the airflow between the freezer compartment and the fridge compartment.
Remove the rubber stop from the drain pipe and clean (can be found above the motor)
Defrost the fridge for a few days (it takes at least 48 hours). During this time, if you are not brave enough to remove the internal panels of the freezer and continually clean the water, check for water coming out and clean.
If during the defrost there is no water coming out the drain pipe, use about 2m of flexible and strong wire to clean the pipe.
The aim is to unblock the pipe once the ice has melted.
Jul 27, 2008 | Bosch Refrigerators
Water dripping at top of refrigerator compartment
Try to blow air through the defrost drain hose from the bottom of the fridge to make sure the line is clear for defrost water to drain.
Aug 26, 2007 | Frigidaire FRT17G4B Top Freezer...
Hotpoint FFS70 Bottom Freezer Refrigerator Logo
470 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
