Question about HP S3120N Pavilion Slimline Desktop Computer PC - REFURBISHED
Front usb port got shorted now multiport card reader is inop and front and rear usb ports won't work with some devices
    Problem Solver:
  • 13 Answers
Unplug the PC, look inside on the board for a small glass-body fuse and replace it with the exact rating the one that blew had i.e. volts and amps
Posted on Feb 01, 2010
Testimonial: "Wow I'm going to look for the fuse tomorrow. It would be super to have it all working again."
USB WON'T WORK ON EMACHINES W3050
  • Verify in BIOS the devices are enabled
  • Verify in device manager there are no driver problems and the devices are not disabled
  • Open the case and verify the cables for the front ports are plugged in all the way
Jan 29, 2013 | E-Machines W3050 PC Desktop
IBM ThinkCentre 8172-MM4 desktop pc. I am getting low voltage measured on the USB ports(all) when I have a few things plugged in... 320G HD{rear ports}, 3G modem {Front ports}, SD card reader {Front ...
The main pc power supply is failing, this is an easy fix with any generic pc power supply.
most competent persons can do this themselves with a little caution and a photograph before you remove the old one...!
good luck !
Mar 30, 2017 | Computers & Internet
My sandisk 8gb cruzer blade is a very slow one,,n givs a max data trnsfr rate of 2.8 mb/s. How can it b solved??
Hi sayak.
When you plug in the card reader, does a little bubble pop up on your screen saying that it could work faster if plugged into a USB 2.0 port?
2.8mb/s is actually a pretty fast transfer rate for a card reader, but it is possible, if you are using the front USB ports of your computer, that you could get a faster rate by plugging it into the rear ports, as they are 2.0 in most boxes.
Sky_Signal
Oct 30, 2010 | SanDisk 8GB microSDHC Memory Card with...
Front card readers and ubs ports not responding
Most likely the USB driver is corrupted.  Uninstall the one you have now from Device manager, reboot and when the New Hardware wizard appears let it get it from Windows Update.
Jun 15, 2010 | Computers & Internet
HP Pavilion zv6000: USB ports are inop. USB port on rear of computer works fine. USB port on left/front will power my flash drive, but the light stays on constantly. The flash drive is does NOT show up in...
After reading the description, I think you need to try updating BIOS and latest device drivers for USB. Because USB are getting power on that means there would not be any fault to from the motherboard.
So please try updating latest BIOS for your notebook.
If you can provide me the product no for your notebook and the operating system which you are using currently then I can find the one for you.
Otherwise you can also do the same.
Type in the product no. on www.hp.com. Then go to software and driver download page, select the proper OS and search in BIOS ROM pack available for your notebook.
I hope this will help.
Jun 11, 2010 | HP Pavillion ZV6000 Notebook
3.5'' internal memory card reader/writer installation problem
Your reader/writer is set up for use on 2 USB ports (hence the 9 pin connector), one port for the reader and one for the externak USB port. This has nothing to do with the port version. The long and short of it is you need a card with a matching internal header. NEVER break off a pin! Some of these headers have reversed connectons so you probably broke of one of the data pins and runed that header's ability. Typically the readers like you have come with several cables, so that they can match the headers you have available. Older motherboards and add on USB cards did not use standardized header configurations aas you seem to have found out. Your best bet at this point is contact the manufacturer of the reader and find out what brand of add on USB cards they recommend and go with that. AND AGAIN NEVER REMOVE ANY PINS FROM A HEADER !!!
Feb 11, 2010 | Computers & Internet
Moultrie 40 spy camera will not put photos on sd 1gb card
TRY A DIFFERENT USB PORT ON PC...usb has 2 standards...1.5 and 2.0...new Dell,at least, has 1.5s on front;faster 2.0 usb ports on back...2.0's will drive 1.5 devices, but 1.5 ports won't drive 2.0 devices
Aug 31, 2009 | Moultrie GameSpy 4.0 Digital Camera Deluxe
USB ports work at 1.1; s/b 2.0
Your computer is functioning correctly.
The USB ports on your laptop are USB1 ports its pard of the hardware.
Your PCMCIA USB 2 card runs at USB 2 speed and therefore when you connect a USB 2 device to this port you will not get this USB message.
Jan 18, 2009 | Lenovo ThinkPad R51e Notebook
Downloading digital camera to computer
I'm not familiar with the Vivicam, but most cameras do not require any software. You just plug in the cable to a USB port on the computer and then look in Start - My Computer for the camera's memory. If that does not work, try some other USB device to make sure the computer's USB port is actually working. A memory stick would be perfect to try. If the port does not work, take the computer back to the store and have them fix it. Probably just a matter of the ports not being enabled in the computer setup or a loose connection. If you have ports on both the front and back of the computer, try them. If all else fails, you could use a card reader. Many all-in-one printer devices have card readers and you can buy a little card reader for perhaps $25 so you can take the memory card out of the camera and read it on the computer.
Sep 09, 2007 | Vivitar ViviCam 5100 Digital Camera
HP S3120N Pavilion Slimline Desktop Computer PC - REFURBISHED Logo
95 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
