Question about Canon PIXMA MP130 All-In-One InkJet Printer
Print cleaner is not working
The graph at the top is broken, should be solid
  • Wilfred Bendig
    Wilfred Bendig Mar 26, 2008
    Removed and cleaned cartriges and put unit back, worked for a while then went back to the same problem. Thanks for your help.
    Problem Solver:
IS THE WORDING CHOPPY IF SO YOU WOULD WANT TO USE A DAMP RAG OR BABY WIPE SLIDE IT UNDER THE CARRIAGE SO YOUR ABLE TO GRAB BOOTH ENDS AND KIND OF GOING FROM RIGHT TO LEFT SO YOUR CLEANING THE GUNK UNDER THE CARRIAGE.
Posted on Feb 18, 2008
What does error code 91721.0014878 mean
Process drive unit broken. Common problem on solid ink series.
Jan 25, 2015 | Xerox Corporation Xerox ColorQube 8570DT...
I send a print from Word. The green light that normally blinks goes on solid and no printing happens. I push the long reset button and 1 page comes out with one line of gibberish across the top. The...
Does it happen from every word-document? This is a postscript error. It can be in your document (you can test it by making an other document in word and print it. If it comes out properly, than you have to look for components like photo's, pictures, graphs in your document that causes the problem. It can also be a problem of your driver. In that case you need to uninstall and re-install your printer again. It can also be a memory problem of your printer. Please turn off your printer, wait a while, than turn it on again and see if it is still the same problem.
Aug 05, 2011 | HP LaserJet 6p Printer
There is a variety of solid arrows in front of the Y1= in the screen to enter equations to be graphed. How do I get back to the original \?
Repeatedly press left-arrow to get the cursor over the arrow, then press ENTER to cycle through the different graph styles until you get the one you want.
Jun 17, 2011 | Texas Instruments TI-84 Plus Calculator
Im getting an error "see my documentation" on my
I had this issue and contacted epson support. They had me open the top to access the cartridges and physically slide the cartridge from its resting place over to the other side and and there was a small piece of paper that got caught in a print and was between the the ink and the cleaners. I then needed to physically move the cartridges back to the resting place and then close the top. Then on the printer, go to the menu and clean the nossels and the test the cartridge. if the lines are broken at all or you dont see words at the top of the test page, then clean the nozzles again. complete this and print a test page or copy. I was good to go.
May 08, 2011 | Epson Workforce 520 Printer
My printer is not working properly. On the test page, not every line prints clearly.....faint and grey compared to other lines. Lines 1, 4, 8, ll, 14, etc. prints very light compared to the other lines. ...
sounds like your heads are all gummed up with dried ink.Is this a older printer or previously used if so run the cleaner that should have come with your printer software. keep running it until clean or bring it to get cleaned.
Feb 22, 2011 | Computers & Internet
What is a rectangular prism ?
A solid (3-dimensional) object which has six faces that are rectangles.
It is a prism because it has the same cross-section along a length.
Nov 03, 2010 | MathRescue Word Problems Of Algebra Lite
How can I print graphs?
  1. Create your graph on calculator.
  2. Connect the calculator to the computer using one of the two methods: SilverLink Cable of the USB Direct Cable.
  3. On the computer RUN the TIConnect Software.
  4. In main window, find the TIScreenCapture icon (it is afflicted with a Camera and a curve graphed)
  5. Click the TIScreenCapture and
  6. save the image in jpeg or png format (bmp format file are too big)
  7. You will be able to print it from the computer using an image editing software,
  8. or insert it into a word document and then print the document.
Apr 17, 2010 | Texas Instruments TI-84 Plus Calculator
Copies are shaded and have a solid black line down
Is this an analog or digital copier?
Multiple things could cause what you describe.
To answer your question rubber rollers can be cleaned with soap and water and a damp cloth.
Hot rollers cannot be cleaned and should be replaced as the teflon coating has failed.
Organic drums should not be cleaned with a cleaner but just a clean dry cloth.
I would look at your mirrors(under the glass) if there is dust on them it will darken your copies and could cause lines.
If it is digital print out a counter if it is a good print the your problem is dirty mirrors and / glass
Apr 13, 2010 | Lanier Office Equipment & Supplies
The HP laserJet Colour printer
I have reduced the size of the mega pixals on the digital camera before taking photo graphs this appears to have fixed most of the problem.
Apr 05, 2008 | Office Equipment & Supplies
Canon PIXMA MP130 All-In-One InkJet Printer Logo
82 people viewed this question
old marine
old marine
