Question about AOpen (FSP200-60SAV) 200-Watt Power Supply
The power supply goes off after booting up as connected to the motherboard.
  • 348 Answers
Then there is a problem in the motherboard replace the motherboard and confirm if faulty then there is mosfet on the motherboard which is shirt replace it the problem will be solved
Posted on Mar 07, 2010
This machine has a G31MX board. It will not boot no matter what order I put the boot order in. I tjust restarts. Pressing tab for post screen or delete for bios it functions normally, but when I try the...
Unplug all drives and USB connections from the board. See if it goes far enough to error out on finding a boot disk. If it does, add items back in one at a time. When you hit the magic one, the problem will return.
If it happens even with nothing connected, you've either got a bad power supply, or the motherboard's shot.
Jul 06, 2011 | Foxconn G31MX-K socket LGA775 motherboard
I have a T5026 EMachine won't power up. Green light on motherboard is on , could it be the switch , tried putting a new power supply box in it.
to see if the power swithc is the problem-
first, try to isolate the wire that connects the power switch to the motherboard. once you have deternined where the power switch plugs, then remove the wires from the motherboard leads and try to short the leads by connecting them with a metal device like a screwdriver tip. if the switch is broken, it will boot when shorted with the screwdriver. if it still will not boot, then you probably need either a new motherboard or a new cpu.
Nov 06, 2010 | E-Machines Emachine T5026 power supply **...
Board will not boot.power supply changed
The power supply and motherboard have a connection (4pin) that communicate to each other. Without this connection, the board will not boot and the power supply will not come on.
The power supply can be fooled by jumping certain pins, but the motherboard must be connected.
Please consult your motherboard manual for the location of this connector.
Visit this site for more clarification please.
http://www.pcguide.com/ref/power/sup/partsMotherboard-c.html
Sep 27, 2010 | MSI MS-6734-10 (-6734-010) Motherboard
When the power supply is connected to motherboard it goes off itself
problem lies in the motherboard there is mosfets on the motherboard which is short and because of short circuit protection power supply goes off itself so either replace the motherboard or repair
Feb 01, 2010 | AOpen FSP200-60SAV (5604200H220) 200-Watt...
I have a HIPRO HP-305 power supply. The green
the 4 pin connector is for cpu power. the hipro power supply are not very reliable.
Jun 14, 2017 | Hi-Pro (HP-P401W) (HPP401W) Power Supply
PC fans turn on but it doesnt do anything else
HI. check the hard drive pin plug that connects to the main power supply unit. make sure it is connected properly. if the connections are correct, this will confirm that the motherboard has failed.
Oct 03, 2009 | Computers & Internet
IBM X-206 SERVER : NOT BOOTING : HANGS
As a first step, I would check to see if the power supply has become defective. There should be no foul smell comming from any part in your computer, so get in there and figure out which part is stinking up the place.
Other reasons for a computer not booting;
defective motherboard defective RAM or poor connection from RAM to motherboard defective peripheral or poor connection from peripheral to motherboard
Aug 07, 2009 | IBM eServer X206 (84823mu)
No booting
plz try with new power supply
May 22, 2008 | Computers & Internet
ADSL modem hangs when booting!!!
It doesn't really sound more than it may be a bad phone line, I mean the actual wire. When you move it your connection changes. There isn't enough signal really to interfere with the motherboard on a EFI level.
May 03, 2008 | MSI 865GM3-LS (MS7043020) Motherboard
Computer is an eMachine
Well Most Likely Your Problem Is A Bad Connection Of Power To The Hard Drive Or Motherboard Also You Should Check The IDE Or SATA Cable That Goes From The MotherBoard To The Hard Drive Is Securely Connected On Both Ends
Nov 24, 2007 | Instek Power Supply, Triple Output, DC,...
AOpen (FSP200-60SAV) 200-Watt Power Supply Logo
131 people viewed this question
Top AOpen Computers & Internet Experts
Matthew Spark
Matthew Spark
David
David
Gareth Cockram
Gareth Cockram
Are you an AOpen Computer and Internet Expert? Answer questions, earn points and help others
