Question about Campbell Hausfeld Air Tools & Compressors
Need new pressure regulator for Campbell Hausfeld
Need new pressure regulator for Campbell Hausfeld FP200201AV, 6 gal, 120 psi 2 hp. compressor.
Friend had some pressure regulators and one of them fit. It is also a step up from a direct replacement OEM part. Thank you for your responce to my question.
Posted on Feb 01, 2010
    Top Expert:
  • Campbell Hau... Master
  • 13,723 Answers
Their web site is chpower.com can order on line if not to old can check warranties also they can direct u to service location in ur area
Campbell Hausfeld Air Compressor 1.8hp 135 max psi 20 gal wl611800aj the prob is there is a fluild leaking from the motor
You compressor is listed as being oil free. The only liquids that could possibly leak out of the motor (if still from factory condition) is black substance from overheated capacitor/s or grease from a failing bearing. Remove capacitor covers and check for failed cap. Motor bearings will become noisy before failure. Capacitors are available from motor repair shops and many times on ebay. Replace with same uf rating and same or higher voltage. Some caps are larger /smaller with same reading (notice size so cap cover will fit). Good luck
Jul 11, 2011 | Campbell Hausfeld 1NNF5 Air Compressor,...
Compressor shuts off at 60 psi will not come back on until opsi
If the pressure switch has been changed you will need to reset it if not ,then is the compressor trying to come back on but will not start untill it reaches 0 psi?
Apr 25, 2010 | Campbell Hausfeld 26 Gallon Low Rider...
My compressor runs way too long to fill up to 150 PSI. It fills up quick to 120 PSI then just takes forever to get to 150 but finally does. It's only 1 year old with very little use. 17 gal, 1.1 horse,...
The pressure switch should be at the factory setting of about 120# max. Not to be hurtful,but what you discribe is normal. Even a 2 HP 220V is minimum for a compressor.. You go by the CFM Rating. You and I can not afford a two thousand dollar 12 CFM Unit. Your compressor is simply too small, to do much. It is pushing against tank pressure so much,after 90# that the reed valves can't hold it. Set it at 100 to 120. It is not designed to run up to 150 max. Now if it is,an oiless compressor , it won't last long. My Campbell- Hausfeld lasted 31 years. Got a new one two years ago
Mar 13, 2010 | Air Tools & Compressors
My campbell 2 gal quiet air compressor stop working. The motor runs but no air is going into the tank, why ?
valve or internal compressor motor failure crack open fitting between compressor out put and regulator if no pressure than failure in compressor if pressure regulator needs repair or replacement
Mar 01, 2010 | Campbell Hausfeld Air Tools & Compressors
Got a Husky 6 gal pancake, 1.5hp. motor runs- no air pressure ??
the regulator may be turned down, find the regulator turn it to the right to allow air into the tank, tank must have air in it to deliver air
Oct 19, 2009 | Campbell Hausfeld No.FP2028 Gal Pancake...
Campbell Hausfeld Air Compressor auto shut off switch not working
i have the same one and mine was broken by my kids , i had to replace the entire component, DONT RUN COMPRESSOR with out the regulator working IT CAN EXPLODE IF OVERFILLED,a must fix situation i believe i got mine from sears , a great unit ive used it painting and with many air tools over many years now , well worth fixing mine is a little loud but dependable good luck.
Mar 15, 2009 | Air Tools & Compressors
Air Tools & Compressors Logo
294 people viewed this question
Top Campbell Hausfeld Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you a Campbell Hausfeld Air Tool and Compressor Expert? Answer questions, earn points and help others
