Question about GE GSS25LGM Side by Side Refrigerator
I recently replaced the water dispenser filter. The original style was no longer available, so I installed the recommended replacement part #MWF. A couple days later the water dispensor stops working. I can hear the switch and pump activating, but, no water comes from nozzle.
  • 619 Answers
The water supply line going up thru the freezer door has frozen. Quick way to test is to disconnect incoming line at bottom of freezer door and close door and activate switch to see if water getting to the door at least. If it is then you will have to defrost the line in the door with a hair dryer. The area that freezes is near the switches. Slow process but will work. or unplug for 24 hours which is real inconvenient.
Posted on Feb 01, 2010
2 Suggested Answers
iwillfixforu
  • 619 Answers
SOURCE: No water from dispensor in door.
Ice supply line is frozen in the freezer door. Using a hair dryer with the door open you have to thaw the line. This will take time but this will fix.
Testimonial: "It took awhile, but it works now. Thanks"
I replaced my GE profile MWF water filter (identical GE part) and now I dont have water dispensing and don't have a working ice maker
Quite frequently carbon fines can be flushed from filter and plug the filter. If you have the bypass plug to replace the filter. Put that in and flush system completely. Take the filter and flush it at the kitchen sink. It is best to fill these with water before installing and flush the carbon fines before installing in fridge.
RJ
Mar 09, 2011 | GE Mwf Ge Refrigerator Smart Water Filter...
After installing a new mwf filter no water comes out of the dispenser. It worked before changing the filter. With the filter bypass plug installed - still no water. I held the dispenser for more than 3...
the inlet valve has jammed shut & needs to be replaced it's just coincedence that it happened when you changed the filter unless the taps turned off it has to be a faulty inlet valve.
Feb 18, 2011 | GE 3 Ge Mwf Smartwater Water Filter Fits...
There is no water coming out of the dispenser on the door. I have tried removing the filter and installing the bypass piece, but that does not work. It has a MWF Filter Cartridge, which is wet, and the...
You didn't mention what brand of fridge you have. your fill tube may be clogged or iced up. Has your water supply been shut off recently? There may be air in the line.
Jan 26, 2011 | Refrigerators
GE SmartWater MWF Refrigerator Filter is making noise when dispensing water
The filter body for the unit is poorly designed and can only stand maybe 8 filter changes before it starts failing to open fully with the new cartridge. As far as I can tell the only solution is to replace the filter body.
Oct 14, 2010 | GE GSH25JFT
Replaced my GE double wide refrigerator SMARTWATER FILTER #GWF With a which is supposed to be better. Yet, the water stream has cut down to half. Do I need the adapter collar for this newer model? ...
I have exactly the same problem. Replaced my GWF filter with the "new improved" MWF filter and the same thing happened. Tried replacing the filter not once, but twice - same low water flow. If you install the bypass plug the water flow is normal, so don't bother checking for water restrictions, bad hoses, tanks etc.. My refridgerator is a GE Profile 26 cubic foot purchased in 2004. I'm afraid these MWF filters don't work well in older models.
Oct 07, 2010 | GE Replacement SmartWater Filter for GE...
How do you change the filter on my ge refrigerators model number GSS25JETBB?
locate the filter look for any part numbers on it, some common ones are the oil can one a MWF, or a GSWF, MSWF, which are longer filters..
remove cover if its a long one in corner and twist or turn it out..
if it is an oil can style just remove by turning it out..
there is no need to shut off the water there is an internal shutoff .
replace filter and u should be set ,, hope this helps
Feb 06, 2010 | GE Refrigerators
Feb 01, 2010 | GE GSS25LGM Side by Side Refrigerator
Need to replace the water dispenser filter, where do I get one?
Your part number is "MWF" and you can get a filter from www.repairclinic.com or probably any local parts distributor in your area.
Jan 19, 2010 | Hotpoint HSS25GFP Side by Side...
Slow water flow from GE Fridge water dispenser
slow water from my ge refrig side by side. less than a momth old
May 04, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
GE SmartWater Filter - Model MWF
make sure filter is installed correctly (not to doubt you but it can happen) make sure there isn't some foriegn object or packing materialetc in the filter end. You could have a bad filter. also make sure the unit is purged well
May 15, 2008 | Refrigerators
GE GSS25LGM Side by Side Refrigerator Logo
221 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Ilia Bichin
