Question about Emerson EWF2004 20" TV
Video on tv
My magnavox smart series tv won't play video...I can't change the tv to input without the remote and the universal also has no input function
  • 2 more comments
  • Anonymous Feb 26, 2008
    im trying to hook up thru s-video
    but the screen is black and only has video 1 or video 2
    in blue words
    im trying to play my dvd player thru my tv using s-video
    im also using a universal remote
    what do i need to do to make this work
  • ryan stokes Mar 16, 2008
    I lost my sanyo remote and now can not get to video 1 or video 2 i also bought a uvniversal remote but it wont access it either is their any way i can access it manually?
  • toplfg Mar 22, 2008
    cant put it on video with universal remote
    I have a 15" sylvania tv, no original remote and a coax port in the back with an rca port in the front. i am trying to hook up cct cameras and dont have the original remote. i have a universal but not a video input button. What should i do?
  • 30 Answers
Then the only way to reach your tv is through coaxial antenna port. So you can buy an rf modulator ( very cheap) and connect your red yellow and white cables (rca cables from a dvd, game console etc) to the modulator then connect the modulator to your antenna with a coax cable. This worked for me.
Posted on Oct 15, 2008
    President:
  • Emerson Master
  • 1,779 Answers
Go to"remote controls .com " You should be able to locate your original there.
Posted on Feb 18, 2008
  • Jim Krause Feb 27, 2008
    Re: s-video,
    I assume you have the s-video jack on the jack panel in the rear of the set?. If your menu does not show s-video as an input the micro automatically detects it.( not in all models). You are using the four pin din plug for s-video?. Let me know....
I can't find my original Magnavox Model 20mf25iw remote. How can I change from DVD back to TV without it?
If you wish to select its input, you must have its original remote control. No universal remote control will go. Try get an original one. Contact the authorised service center for Magnavox.
Nov 04, 2013 | Magnavox New Original 27MS3404 Remote...
Can't find install code for philips magnavox smart series plus
Universal remote codes for Philips Magnavox TV are: 0062 0204 0207 0183 0226 0288
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand
Sep 27, 2012 | Philips Smart Plus TP3285C 32" TV
Try to switch tv to video input inorder to play my DVD,playstatio
yes as long as it has the button for it.look for tv/video button.if none, then buy a remote like a universal remote is the only option.
May 20, 2009 | Televison & Video
Need the remote code for a phillips dvd player
These are the codes printed in the owners manual for your dvd/vcr player.If they do not work you will have to contact Emerson and ask them for help getting the code. The contact number should have come with the instructions for the remote. Just give them the model number of you remote and the units model number and they should be able to help you. I hope this information helps you with your problem. Switch the input selector on your TV to an appropriate external input channel (usually near channel 0).
Press a button on the TV’s original remote control that selects an external input channel until the DVD
recorder’s picture appears. Check your TV owner’s manual for details.
Admiral
Curtis Mathis
GE
Hitachi
JVC
Kenwood
LXI-Series
Magnavox
AUX
LINE1, LINE2, 00, 90, 91, 92, 93
INPUT, TV/VCR, 00, 90, 91, 92, 93
INPUT, AUX
VIDEO, VIDEO 1, VIDEO 2, VIDEO 3
AUX
00
AUX CHANNEL
Input Mode Names for Common TV Brands (Example)
Panasonic
RCA
Samsung
Sanyo
Sharp
Sony
Toshiba
Zenith
TV/VIDEO
TV/VIDEO
VIDEO
00
VIDEO1, VIDEO2, VIDEO3
TV/GAME
00
Apr 25, 2009 | Philips Magnavox MWR20V6 DVD Recorder/VCR
My tv remote starts playing a tune?
It you are probably pressing a button the tv itself that activates the remote finder so you can find the remote. this makes the remote beep. try pressing the button on the tv to cut it off.
Apr 14, 2009 | Philips Magnavox Learning Universal Remote
TV WONT GO TO VIDEO CHANNEL
most inexpensive universal remotes will not operate input select functions. save yourself some hedaches, go to shopjimmy.com, enter yuor model# and buy an original remote, my dear! you'll thank me later! :) mch
Mar 09, 2009 | Philips Magnavox MS2530C 25" TV
Need codes to unlock the smart block on my phillips magnavox tv
do you have a 3 digit code for RCA TV for the philips universal remote?
Dec 30, 2008 | Televison & Video
DVD input with signal access
IF I understand you correctly, the VCR, Satellite, etc is connected using an RF modulator/coaxial cable wire going into Antenna in
IF this is true, then you have an AV IN port (red, yellow, white) free on the back. Just connect the red, yellow, white from the out of the DVD - you can use 1 or 2 - just remember which one you used; and connect it to the AV IN on the back of the TV.
THEN press ch down on the TV remote until you get to "AV1" - it is below channel 2; double check DVD player to make DVD is playing and voila!
Jun 22, 2008 | Philips Magnavox 27MS343S 27" TV
Emerson EWF2004 20" TV Logo
694 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
