Question about HP PSC 1315 All-in-One Printer
C:\Program Files\HP\Digital c:Program FilesHPDigital ImagingSkinsoov1skin.xml does not exist
  • HP Master
  • 12,061 Answers
This file soov1skin.xml is missing or corrupt. A reinstall may fix it. It should be on the install DVD
Posted on Feb 01, 2010
Help me fix a Parsing error in file C:\program files\HP\ Digital Imaging\bin\hp\qsclo\1033.xml.
In the following location there is a file called hpqscloc.dll. Right click the file and choose Properties.
Go to Version tab. What is the version of your dll? Mine is 120.0.26.58
Try double clicking the 1033.xml. Is there any error message when you do so?
Nov 07, 2010 | Computers & Internet
I HAVE UPGRADED MY DESK TOP FROM WIN VISTA TO WIN 7 HOME BASIC. I UPLOADED THE DRIVER FOR HP OJ 5610 FOR WIN 7. IT IS SUCCESSFULY UPLOADED BUT I AM NOT ABLE TO USE THE HP SOLUTION FUNCTIONALITY AS IT SHOWS...
SOLUTION:
Here are the steps to resolve this issue (was tested):
Disconnect printer USB from the computer.
Inside the HP software/driver cd, go to "util" directory > "ccc" directory.
In here run Uninstaller_L1 through L4 in order.
Check Add/Remove programs inside Control Panel for additional HP programs that weren't removed and remove them.
Delete HP and/or Hewlett-Packard directory inside Program Files.
Goto Program Files > Common Files and delete HP and/or Hewlett-Packard directory there as well.
Go to Start>Run and type "temp". inside this folder delete all files.
Go to Start>Run and type "%temp%". inside this folder delete all files.
For additional cleanup when using Vista, you can download Cleanup Utility and search for additional HP components that weren't removed. Here's a link for the program: http://support.microsoft.com/kb/290301
Restart and reinstall the driver using the CD or web driver.
The issue should now be resolved.
Sep 13, 2010 | Computers & Internet
When I try to open the HP Solution Center I get the error message: Parsing error in file c:\Program Files\HP\Digital Imaging\bin\hpqsdoc\1033.xml
This message is because Microsoft XML services are having a problem.Here is what you could do to fix.
Step 1: Uninstall All-in-One software
Step 2: Restart the computer
Step 3: Install the Windows installer 3.0
http://www.microsoft.com/downloads/details.aspx?FamilyID=3144b72b-b4f2-46da-b4b6-c5d7485f2b42&displa...
Step 4: Download and install MSXML
Step 5: Reinstall All-in-One software
Hope this helps
Aug 11, 2010 | HP Office Equipment & Supplies
Please give me a solution for this error - Parsing error in file C:Program FilesHewlett-PackardDigital ImaginginhpqsclocC3.xml
That XML file is corrupt. You will have to uninstall all the HP soft, manually delete all remaining files and folders then reinstall it using a new installer that you must download directly from the HP site.
http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?prodNameId=391319&lang=en&cc=us&
taskId=135&prodTypeId=15179&prodSeriesId=391317
Jun 08, 2010 | HP Scanjet 3770 Flatbed Scanner
80070246 error when trying to update windows how to fix problem
Clear the contents of the WindowsUpdate folder
  1. Click Start, click Programs, and then click Windows Explorer.
  2. In the left pane, double-click the Program Files folder.
  3. In the left pane, double-click the WindowsUpdate folder.
  4. In the right pane, click the V4 folder, click Edit, and then click Invert Selection.
  5. Press DELETE, and then click Yes to confirm.
  6. Open the V4 folder, then in the right pane, click to select the IUHIST.XML file, click Edit, and then click Invert Selection.
  7. Press DELETE, and then click Yes to confirm.
Note When you delete the IUHIST.XML file from the WindowsUpdate folder, you clear the whole Windows Update installation history. Microsoft does not recommend that you do this because you lose your record of previous downloads. The steps in this section delete all your files except the IUHIST.XML file.
Apr 04, 2010 | HP Pavillion ZV6000 Notebook
HP Solution Center
When you click on the icon it is trying to open an xml file which is like a web page. The parsing error means there is an error in the page. I think the best way to cure this problem is to go to http://www.hp.com/#Support and put in the model number of your computer and download new drivers for your printer. You should also uninstall any current drivers you have from control panel's add and remove programs.
Dec 07, 2009 | Office Equipment & Supplies
Hpc20155.xml is needed. i don't know why this happened. i can't use my printer HP LaserJet P2015.
You have to end a .inf file from Microsoft to get it to work. Open up c:\windows\inf\oem16.inf in your favorite text editor. Search for "hpc20155.xml" and you will find this section:
;hp LaserJet 2015 files
[DATA_FILES_20155]
hpc20155.xml,,,0x00000020
hpzsc43e.dtd,,,0x00000020
hpc20155.gpd,,,0x00000020
hpc2015b.ini,,,0x00000020
Change hpc20155.xml,,,0x0000002 to hpc2015.xml,,,0x00000020 (take out the last 5 in hpc20155.xml). Save it and go back to add a new printer in windows. This should fix the problem.
There is one thing to add, however: the name of the oem inf file might be slightly different on different computers. Easiest way to find it is to go to Start –> Search –> Files and Folders; Set your search location to C:\Windows\Inf, and enter “hpc20155.xml” in the field labeled "”A word or phrase in the file”. If you get multiple results, you’ll have to check them one by one; just follow the rest of the bjones’ walkthrough from that point on.
Thanks.
Jul 01, 2009 | Office Equipment & Supplies
Hi, when I want to open scaner in hp office jet6213 I recieve this message "selektskin-error" (the file c:program fileshpdigital imageskinsoov1skin.xmldose not exist) What should I do?
The 'missing' file exists, but is in the wrong folder. This problem is known to HP. Here is the solution:
# Open Windows Explorer.
# Click the + sign next to Local Disk (C:).
# Click the + sign next to Program Files .
# Click the + sign next to HP or Hewlett Packard .
# Click the + sign next to Digital Imaging .
# Click the + sign next to Skins .
# Make sure there are only two folders; one named hp1 and one named 00v1 . If there are any variations to the folder name, or extra folders, delete them.
# If there are not any extra folders, check the contents of the folder and make sure they are correct.
1. Look inside the hp1 folder; it should contain sixteen icons (including folders).
2. Look inside the 00v1 folder it should also contain sixteen icons (including folders).
What you will probably discover is that the skin files in the 00v1 folder are all or partially missing. Copy all the files in the hp1 folder to the 00v1 folder, and be sure skin.xml is one of these files. And if there are any other folders in that subdirectory delete them, and if the 00v1 folder is missing, create it.
You can go to the following site for a deeper discussion of this error message: http://h10025.www1.hp.com/ewfrf/wc/genericDocument?docname=c00215691&cc=us&dlc=en&lc=en&jumpid=reg_R1002_USEN
Apr 28, 2009 | HP PSC 1315 All-in-One Printer
HP PSC 1315 All-in-One Printer Logo
275 people viewed this question
Seeker5211
Seeker5211
