Question about HP LaserJet 3330 All-In-One Printer
HP 3330 - No Cartridge Detected
A HP 3330 that does not detect a cartridge when it is in place.
  • Gary Feb 18, 2008
    In replacing the gear train after solving another problem, I had replaced the pin that detects the Cartridge in a "reveresed" direction. Upon correcting all is OK.
  • 461 Answers
SOURCE: HP PHOTOSMART C4280 PRINTER WONT READ INK CARTRIDGE.
The cartridge is not seated properly and/or the contacts are dirty. Use a cotton swab with rubbing alcohol and gently clean both the copper contacts on the cartridge and inside the cartridge socket. Allow several minutes to dry and then try again.
Posted on Nov 28, 2008
techniwiz
  • 275 Answers
SOURCE: cartridge not detected or missing message.
did you remove the tape from the new cartridge ?
Posted on Dec 23, 2008
  • 4 Answers
SOURCE: HP 4280 - new black refilled cartridge not recognised
hi steve... the solution to your problem is a costly one. the printer keeps in memory 2 cartidges for colour and 2 for black, when a third is placed in the printer the first one is deleted out of memory same for the colouredand same for the black... therefore you need 3 cartridges each to do the trick.
eg. if you want to use colour cartridge #2 then 1st place colour nuber 1 or 3, then turn it on let it reads, then open door and place in colour number 3 or 1 let it read, then take out and place in coulur number 2 and it will see it as new
Posted on May 01, 2009
  • 46 Answers
SOURCE: HPPhotosmart C4250 mgs "Printer Cartridge missing or not detected
There may be debris that is blocking the communication between the cartridge and the printer, especially if you are using a remanufactured cartridge. Remove the cartridge and unplug the printer from the power supply. Take a little bit of rubbing alcohol on a cotton swab and wipe off the contacts on the cartridge as well as the contacts inside of the printer. Allow both to dry for a few minutes before plugging the printer back in and re-installing the cartridge. This should clear up any miscommunication between the two.
Posted on Mar 15, 2010
SOURCE: HP Photosmart C4580 Print cartridge(s) missing
This error message usually happen if the cartridge is not properly seated or the copper-colored electrical contacts have problem. Check this website for proper cleaning and installing ink cartridge.
If the problem is resolve try replacing the ink cartridges.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01442936&lc=en&dlc=en&cc=us&lang=en&product=3418707#N68
TNX
Posted on Apr 24, 2011
My printer says printer cartridge missing or not detected - but the cartridges are in. Whats wrong?
Try removing the cartridge and re-seating it. Be sure it "clicks" into place..
Good Luck
May 05, 2011 | HP PhotoSmart C4280 Laser Printer
HP Photosmart displays a message saying "Printer Cartridge(s) missing or not detected" though I've just put a new cartridge into the machine. How do I fix this so I can print again?
Remove the cartridge.
Make sure that you removed a piece of clear plastic tape that covers the ink-jets. It's placed there to prevent the ink from drying-out while the cartridge has been sitting on the shelf at the computer store.
Re-insert the cartridge, and be sure that it "clicks" into place.
Apr 02, 2010 | HP Photosmart C4280 Aio Printer
I have just inserted a new black cartridge. it clicked into place and looks correct, however printer displays "print cartridge missing or not detected" how do i resolve this? also, i have tried the clean...
Try cleaning the contacts in the head receptacle. If it is NOT an original HP one, then thats the reason. You MUST use HP ones. If it is, it maybe faulty, or the printer is.
Mar 29, 2010 | HP PhotoSmart C4280 Laser Printer
Apr 03, 2009 | Office Equipment & Supplies
Cartridge not detected or missing message.
Dec 23, 2008 | HP PhotoSmart C4280 Laser Printer
Internal drum on hp laserjet 3330 damaged. How to replace?
If by drum u mean toner cartridge, you will have to order a new toner cartridge from HP.
WWW.HP.com
Dec 14, 2008 | HP LaserJet 3330 All-In-One Printer
My HP laserjet 3330 all in one is now producing very dirty copies after I put in a new toner cartridge. Is it possible to clean it up without taking it to a repair place? I am only semi-skilled at taking...
You might have gotten a hold of a bad toner cartridge. (Did you use a genuine HP toner cartridge?) I would try a new toner cartridge and see if that helps.
Nov 09, 2008 | HP Office Equipment & Supplies
NEED HELP WITH MY PRINTER
HP PSC 1210 - The Print Cartridge Detected is the Wrong Type * The following message is displayed on the computer: "The color [or black] print cartridge detected is the wrong type" * The Check Print Cartridge light is blinking, and the Check Paper light is off. This problem usually occurs after replacing a print cartridge. Soloution: http://www.whatmobile.com.pk/hp/hp1210.htm
Aug 05, 2007 | HP PSC 1210v All-In-One InkJet Printer
HP LaserJet 3330 All-In-One Printer Logo
111 people viewed this question
Seeker5211
Seeker5211
