Question about AOpen FSP200-60SAV (5604200H220) 200-Watt Power Supply
When the power supply is connected to motherboard it goes off itself
  • 348 Answers
Problem lies in the motherboard there is mosfets on the motherboard which is short and because of short circuit protection power supply goes off itself so either replace the motherboard or repair
Posted on Mar 07, 2010
Wont start when I push button.
Make sure when you put it back together that you did not forget to plug in the power button or button cable. Also the battery may not be charged if it is new. Batteries do not hold charge being li-ion for a long period of time.
Apr 15, 2014 | HP Mini Computers & Internet
Dv9920us motherboard check
Remove the power supply, battery, hard drive and RAM. Connect the power supply on its own and press power on. If it now goes to the first screen, add the RAM and then the hard drive. If it did nothing, I would suspect the GPU has unsoldered itself from the motherboard due to overheating.
Dec 26, 2013 | HP Pavilion dv9000z Notebook
When I turn on the power the processor fan does not start but when I disconnect the 12volt four pin power connector the processor fan start but no display in both the state. (865 GVHZboard, 2Ghz pro, 512...
The power supply connector might be not place properly. Check the connector in the motherboard there might be one missing that is not being connected the processor connector located near the processor itself...then check also the connector of the cooler fan...it might not be connected...
If all the things is in place but still the problem is exist. Replace your power supply with new...because there might be a defective component into your power supply which is not enough to supply the entire motherboard...
Sep 19, 2011 | Intel D865GVHZ Motherboard
The power supply goes off after booting up as connected to the motherboard.
then there is a problem in the motherboard replace the motherboard and confirm if faulty then there is mosfet on the motherboard which is shirt replace it the problem will be solved
Feb 01, 2010 | AOpen (FSP200-60SAV) 200-Watt Power Supply
Which two connections supply the power from the battery
Hi Ray,
In a computer, nothing connects directly to the battery, as the battery is not what powers the system. The battery controls the CMOS settings, which involves all of the things that come up before windows loads when you turn on your computer.
As for how the computer actually gets the power, there's a box in there called a power supply, which receives its power from the 3 pronged plug you put into the back of it. The Power Supply gives power to the computer through a series of different wires.
There are a bunch of 4 pin molex connectors, that go from the PSU (power supply unit) to the various drives throughout the machine. In addition, it supplies power to the motherboard itself via a 20 or 24 pin connector, that goes straight into the board. Some have an additional 4 pin one as well to supply power to the processor.
If you were looking for something else, feel free to leave a comment.
Hope this helps :)
Nov 29, 2009 | Packard Bell Computers & Internet
My case fan speeds up for no reason. could this be the case power supply ?
If it is connected to the motherboard itself then it is likely that the motherboard adjusts the speed to maintain the correct temperature. If it is connected directly to the power supply then it could be a poor connection or power supply fault. The problem could also be the fan itself, this could be a sign of the bearings wearing out. Hope this helps.
Oct 10, 2009 | Computers & Internet
Power light flashing HP Compaq Presario SR1230NX PC Desktop I powered the unit down; when I tried to powered it up the only reaction is a green led flashing. The led is located in the back close to the...
Sounds like the Power Supply is bad likes its not able to power on itself. Best thing to do, try a different known good power supply and attach it to the motherboard, if you get the same symptom with the machine not powering on then its a bad motherboard. If the machine does power on then you know your original power supply is bad.
May 28, 2009 | HP Compaq Presario SR1230NX (PJ518AA) PC...
Hp pavilion 764c wire diagrams
Take a picture of the inside of your computer and put it up on the website with the wire connectors that need to be connected. The connecting wires should be in four groups. 1. The power supply connectors. These connectors will supply power to to all the power using components not supplied power by the motherboard itself. 2 The connections to the other components in your system like the dvd/cd player and the harddrive and floppy drive.3. The motherboard connections for the case. The power switch connector andreset switchconnector. The power led and theharddrive activity light.The USB connector and the audio connector.The fan connections like the cpu fan and other fan only connectors found on the motherboard.The external fans ( Fans that need to be connected to the power supply).Most of these connections are labeled on the motherboard. The case connectors also should be labeled for the correct connection. The best way to find the answers to this hook-up, may be to call HP pavilion with your computer make and model number,motherboard model number including revisions number. Computer made by big manufacturers tend to have may revisions and the only way to make sure your are getting a correct hook-up to the motherboard is call them for assistance.Especially if the motherboard and case labels are not present or so small that they cannot be read.Hope this helps you with your problem.
May 16, 2009 | HP Computers & Internet
AOpen FSP200-60SAV (5604200H220) 200-Watt Power Supply Logo
182 people viewed this question
Top AOpen Computers & Internet Experts
Matthew Spark
Matthew Spark
David
David
Iqbal Husain
Iqbal Husain
Are you an AOpen Computer and Internet Expert? Answer questions, earn points and help others
