Question about LG WM2688H Front Load Washer
L g steam washer front load
We are getting a e1 code when the rince cycle is suppost to start. e 1 is low water pressure code. we had the pressure checked at the hot and cold cutoffs and the water pressure was normal says the plumber @ 80 psi. We checked the intake filters and even removed the little grey water reducers at the filter intake connections. the machine is fairly new, 3 months. so when it codes it stops all functions and will not rince or spin. thank you for any suggestions. nicholas
  • Anonymous Mar 04, 2008
    makes music sound when you press start
  • 770 Answers
The model you have this listed under WM2688H (LG Steam Washer) a E1 Code Correct water level (246) is not reached within 8 minutes
after water is supplied or it does not reach the preset water
level within 25 minutes.
I suggest you
Check the screens in the water inlet valve for blockage
Posted on Feb 18, 2008
What does E2 error mean
Generic pump error
Error Code-control panel display "Err2" (Error 2, Error2) ' question ...
www.haier.com/za/help.../washing_machine/.../question/.../t20140313_209219.shtml
  1. Cached
  2. Similar
Mar 13, 2014 - Error message:Drain error, water can be not drained fully within the required drain time (controlled by PCB software). Reason 1. Pump filter is blocked. Solution 1. Please open and clean the pump filter. (Filter access door is on the bottom right, at floor level of the washing machine). Step 1.Push a flat blade ...
How To Fix Maytag Washer Beeping And Error Codes E2 and F3 Front ...
9k=? 5:23 https://www.youtube.com/watch?v=by94vOVmmhQ
  1. Similar
Mar 18, 2017 - Uploaded by Nancy Gurish How To Fix Maytag Washer Beeping And Error Codes E2 and F3 Front Load Washer Stopped, Repair Of ...
Washing Machine Error Codes - Front Load and Top Load Washers ...
https://removeandreplace.com/.../washing-machine-error-codes-front-and-top-load/
  1. Cached
  2. Similar
May 5, 2015 - F9 followed by E1 - (drain pump system error) F5 followed by E2 - (door will not lock) F7 followed by E1 - (motor drive error) "rL" - (remove load) Washer making error beeps - Door has not been opened and closed for at least 3 cycles. Washer beeps when HOLD TO START is touched - Door not closed
Mar 22, 2018 | Washing Machines
My mass 6 Bosch washing machine is locked up and was blinking in red light letter F what do I do
"Sd" - (Excess suds)
F8 followed by E1 - (water supply error)
F# E# code other than as described above appears in display - System Code Error
"nt" (interrupted) - Cycle was paused or cancelled
Clean Washer LED flashing at end of wash cycle - The washer has run 30 wash cycles and is indicating a reminder to run the Clean Washer cycle https://removeandreplace.com/2015/05/05/washing-machine-error-codes-front-and-top-load
Sep 21, 2017 | Bosch Washing Machines
Duet. What does F8E1 code indicate needs to be done to restore operation?
Check out the Link and the info below.
Question: Front Load Washer - Error Code - F8 E1 or LO FL Answer Product Symptom:
F8 E1 or LO FL Code in display:
No water detected entering washer after 13 minutes, the pressure switch input has not been detected.
If the washer has an F8 E1 error or LO FL error, the door will be locked, and the control will be unresponsive. The washer will start a drain routine which takes approximately 8 to 10 minutes, during which time the pump will run continuously. The control will not accept any input during this time. Please wait 10 minutes before trying to perform any functions.
Check the water supply:
Turn on the water. Check the household water supply to see if the hot and cold water faucets are turned on. Make sure to open both faucets completely for proper fill.
NOTE: Both Hot and Cold water must be supplied to the washer.
Whirlpool recommends that appliances be direct connected to the water supply for optimum machine performance.
If a "flood saver" device is being considered:
  • Check with the manufacturer of the device to ensure it will not affect the performance of the appliance.
  • Whirlpool has experienced that "flood safety" devices can interfere with the performance of the appliance. Whirlpool typically does not recommend these devices.
Two types of "flood-saver" devices, hoses and valves are illustrated below. anti%20flood%20hose%202.jpeg floodsafe%203.jpeg Whirlpool Duet Washer F8 Code Appliance Repair Forum
Jan 19, 2016 | Whirlpool Washing Machines
I have an E1 message on my samsung front loader, can you tell me what that means?
Is the system filling up with water then halting with an E1 error or can you complete an entire cycle?
E1 in Samsung Front Loaders: It means the machine has detected an error in inlet water filter or the water pressure. Some of my sources indicate E1 could also be a leakage error It could all mean a faulty sensor but you should check th water lines, the door seals and the floor beneath the machine for tell-tale signs of a leaking system. Is the system filling up with water then halting with an E1 error or can you complete an entire cycle?
If you can fill the washer, but it faults with and E1, and can go no further, my research shows a common cause for the problem is the PVC tube connecting the pressure sensor to the drum has experienced a problem. In some modern washers, the water level is measured and regulated with a pressure sensor connected to the tub with a plastic tube. As the water level rises inside the drum, the pressure rises inside the sealed tube. The tube can sometimes become detached or even plugged with lint, soap or wash grime. Check the pressure sensor line to make sure it is attached to the drum and is completely unobstructed by foreign objects or deposits. If so, clean the debris and/or reattach the tube to the drum and try running starting a cycle. If you don't get the E1 code - Hooray, everyone has clean clothes again :-)
If this does not work, here is a link to a Washing Machine User Blog which might be able to offer more experts and more specific information http://www.applianceblog.com/mainforums/washers
Hope this answers your questions and helps FixYa! If you found my information useful and informative, won't you please show some love and rate this solution or better yet, send us a brief testimonial on how our free support made your day and averted disaster.
Thank you for choosing FixYa.com.
Colt Baldwin - FixYa.com Guru
Mar 26, 2011 | GE WBVH6240F Front Load Washer
Duet Steam washer, F20 error. help
make sure pump is clear. open toe panel and access pump.
Feb 12, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Washer stops during begginning of cycle with F 35 reading .
F35 is a water level error.
The water level switch (pressure switch) has malfunctioned.
If you remove the top panel, three screws in the back, you will have access to the pressure switch.
With the tub empty, remove the vinyl hose from the switch and blow backwards through the hose to clear any restrictions.
If the fault codes return after doing this, you will likely need to replace the pressure switch.
Also - please be sure to use He soap.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 13, 2009 | Whirlpool Duet 4.0 Cu. Ft. Steam Washer
Side load washer spins cycle problem.
Clean your drain valve. The water is not pumping out. This puts a strain on the machine.
Remove the bottom front cover to access the drain valve.
Feb 20, 2009 | Frigidaire ATF6000ES Front Load Washer
E1 Code - tried fixing it according to manual still won't work
The error code E1 = Water supply error -Not enough water entering the W/M.
Try check water supply line is on and not have any kinked.
Mar 21, 2008 | Samsung WF337AA Front Load Washer
Long wash cycles
WHEN YOU WASH IS THE WATER HOT ENOUGH IN A REASONABLE TIME? ALSO DOES THE WASHER SENCE THE AMOUNT OF SOAP THATS IN THE TUB. IT COULD BE GIVING ADDITIONAL RINCES TO REDUCE THE SOAP CONTENT.(TRY WITH NO SOAP IN SYSTEM AND SEE IF TIME IS SHORTER)
Sep 18, 2007 | Whirlpool Duet GHW9150P Front Load Washer
LG WM2688H Front Load Washer Logo
221 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
