Question about Canon USA - COPIERS - ImageRUNNER 2010F Copier
Half looks great but the other half is gray scaled has been getting worse for about a month
  • 1,219 Answers
1)So, your copie is half with good black color, and other half light, with possiblle white streaks?
IF YES: you need to clean the laser unit and replace the toner cylinder cleaning blade, also check the drum unit - if it got over 25000 copies change it too.
2)So, your copies are half good and half like no toner is fixated on paper?
If thats the case replace fixing roller and bushings, and check the press. roller bushings.
Posted on May 03, 2010
Halfway point between 2 cities
run a ruler between the two points and half way will be half the distance of the ruler measurement multiplied by the scale of the map example if the ruler is 6 inches between the cities and half way is 3 inches and the scale is I inch equals 300 miles then 3 inches will be 900 miles ( scale is on the front or back of the map)
Dec 30, 2013 | Cars & Trucks
When I try to print in grey scale on my HP 8150, it starts out in grey, then switches to a purple-blue with grey scale stripes in it. This is a new problem with this printer, which has always been great. ...
i think there will be also one option use only black cartridge
that will solve ur problem
actually when it print in gray it uses all colour and then print in gray
Aug 07, 2013 | HP Photosmart 8150 InkJet Printer
Water is leaking from somewhere under the machine, we have owned this for 5 months and it's getting worse. Is this something we can fix?
Sorry to read about your issue.
The brewer should be de-scaled at least every 3-6 months. Scale is harmless, but if left unattended, it can hinder optimal brewer performance. De-scaling your brewer regularly helps maintain the heating element, removable water reservoir and other parts of the brewer that come in contact with water. Better water quality and water heating means a better cup of coffee, tea, hot cocoa or iced beverage. We recommend de-scaling your brewer at least every 6 months (every 3 months if your water has a high mineral content). The de-scaling process involves using 48 ounces of undiluted white vinegar.
Take 48 oz of white vinegar. place in tank. pretend you are making coffee (Do No Use K Cup). let the water fill you mug. then empty that mug. Do it again until tank is empty. then let sit for 4 hours.
Then fill with fresh water to the top. let that tank of water run thru. towards the end taste the water.
If you taste vinegar..use more clean water, until the taste is ok.
I tried to help you. Please help me and Vote/Rate this response. Thanks and good luck
wer
wer
wer
we
r
ew
fds
Dec 23, 2010 | Keurig B60 Coffee Maker
After many uses, the cups are starting to get much smaller. when you brew a normal size cup, it comes out at about half the size of what it was previously
Dec 22, 2010 | Keurig B70 Coffee Maker
The water filler pump is very loud and getting worse - can it be replaced
Dec 19, 2010 | Keurig B50 Coffee Maker
De-scale
mix half white vinegar and water together...then pour this solution in just as you would if you were making coffe....minus the coffe grounds of course... then run it through a cycle and then run clear water through again... and you will be good to go...do this once a month or so to keep it working great...
heatman101
Aug 26, 2010 | Keurig B100 Coffee Maker
My coffee machine is flashing
That means that you need to clean it...
heatman101
Apr 26, 2010 | Keurig B50 Coffee Maker
The screen will turn white and freeze up
how to fix my verizon wireless cell fone when the screen turns white?
Sep 20, 2009 | LG VX5500 Cell Phone
My printer won't print in color
Check the printer properties, go into Printer and Faxes from Control Panel or Start Menu, then right click on the printer and choose properties.
Look for Printing Preferences and in tab Paper/Quality, set the color setting to Color.
Dec 20, 2008 | HP PSC 1315 All-In-One InkJet Printer
76 people viewed this question
old marine
old marine
