Question about Razer RZ01050300 Mouse
Razer copperhead problem
I bought a green razer copperhead mouse about 3 weeks ago... and about 1 week ago it started to go crazy... i can't move it properly... when i try to moove the cursor verticaly or horizontaly it only mooves diagonaly... it's practically uncontrolable... i changed the usb port... same pb, i formated my pc and reinstalled windows and the copperhead driver, same pb... the thing is that when i plug in my other mouse(logitech mx318) in the same usb port it works just fine.
also i've tried the razer copperhead mouse on another 3 pc's and it worked just fine...
can someone help me with this??
  • 2 more comments
  • Anonymous Apr 10, 2008
    Having the same problem here i've recently updated the drivers aswell but nothing seems to work.
  • Anonymous Aug 13, 2008
    i have exactly the same problem,its driving me mad........please help!
    Same here, works sometimes then goes crazy, only moves horizontally back and forth between top left and bottom right where ever I try to move the mouse. Looking for another mouse to try now.
  • Sonny Martinez
    Sonny Martinez Sep 05, 2008
    Me Too! on two different computers.
    Seems like it started on the last couple windows update.
    I'm ready to get rid of the razers all together.
    Sonny
  • 3 Answers
I have something like you've all described with mine occasionally, normally, turning the mouse over and rubbing the laser surround with my finger vigorously is enough to clean off the crud that seems to be causing the problem..
I've never had any software problems or anything with mine..
Posted on Sep 23, 2008
For now I uninstalled the driver in add and remove programs and the mouse seems to be working fine.
Running XP Pro Service Pack 3
AMD Athlon 64 X2 Dual Core Processor 3.21 GHz
2.00 GB RAM
Posted on Sep 05, 2008
  • Sonny Martinez
    Sonny Martinez Sep 23, 2008
    I know about the cleaning under the mouse 4zzdawg, my problem isn't that, I have owned razer mouses for about 3 years now and this issue is software or hardware. I still haven't figured it out. It seems to wrk fine then it gliches, I have to disconect it and reconect then it will work fine for a while. I went and bought a $9.00 mouse, it works great. If a solution comes up I'll used the razer again.
What operating system are you using? Because i know that Ubuntu and MAC's both have issues with the Copperhead.
Im running Vista (used to run Xp), ive had the copper head since its first release...and not a single issue like you have described has ever came up.
Posted on Aug 20, 2008
Copperhead cursor won't move when i move the mouse
this is because the laser light in the mouse had gone bad...all that you can do is to replace that with a new one... or buy a new mouse...
Apr 04, 2010 | Razer Copperhead RZ01-050100-R1M1 Mouse
My Razor Copperhead mouse restarts
I found that when this was happening to me the problem area was where the wire meets the mouse. By wiggling that (moving the mouse) it would cause it to disconnect and reconnect.
Some claim it could be the firmware for various hardware pieces on your pc IE: motherboard, usb. Depending on how old the mouse is this could be true. Mine, however, is 4 years old and needs to either be repaired or replaced.
Mar 30, 2010 | Razer Copperhead RZ01-050100-R1M1 Mouse
My copper piping inn my home is turning green at one location under the house. The plumbing was installed approx. 25 to 30 years ago. Is this going to be a problem? Should I get a plumber or don;t worry...
Hi:
Copper pipe that is exposed to the elements will turn green, but normally isn't a problem, though you should periodically have a look at it. If any of the "green" area starts looking puffy, or building up, it could be more serious corrosion, and could cause a leak down the road..
Dec 15, 2009 | Razer Copperhead RZ01-050100-R1M1 Mouse
My copperhead Razer mouse has started double clicking for one
This double-clicking can be due to a worn out micro-switch in your mouse. If you are well -verse with repairing such gadgets, you can go ahead and replace this switch yourself or refer it to a qualified technician
Apr 23, 2009 | Razer Copperhead Chaos Green Gaming Mouse...
Copperhead working, but not detected
what i did was. i went into c drive -> program files -> Razor -> Copperhead -> driver64 and ran the program called "DPInst"
try that and see if it works
Dec 09, 2008 | Razer Copperhead RZ01-050100-R1M1 Mouse
Razer copperhead ....it moves slowly of its own
your problem is common reinstall your mouse driver if it does not fix this try to change it plug to usb
Aug 17, 2008 | Razer RZ01050300 Mouse
Razer
Hmm...I managed to solve the problem of mouse "breaking" while playing counter strike..Its a lil technical...
1. Right Click My Computer -> Properties
2. Choose 'Hardware' tab and then 'Device Manager'
3. You should see a Yellow exclamation mark on 'Razer Copperhead USB mouse' under 'Human Interface devices'
4. Right click -> properties
I do not exactly remember the wordings of the prompts that appear after this..
5. Click on something which says "install / update driver"
6. Choose the 1st option which has something missing in one of the columns..
7. Unzip downloaded driver files on your desktop
8. Choose logical options from here...
9. At some point it will ask for "Razerlow.sys" file...
10. Click browse and go to C:\Windows\system32\drivers....you will find it there...
11. Choose logical options from here and your "breaking" problem will be solved...
This does not solve the "No mouse detected" message in configurator...but atleast you can play your favorite game :-)
May 17, 2008 | Razer Copperhead RZ01-050100-R1M1 Mouse
Razer Copperhead mouse problem
Check the BIOS settings on your computer: is it set to boot from USB drive?  that may be the problem.
Mar 28, 2008 | Razer Copperhead RZ01-050100-R1M1 Mouse
Detected before, but not after. Help me please,
Go to device manager and uninstall everything under the USB heading and restart your computer. This should reinstall all the drivers and hopefully reinstall your mouse. You may need to rerun the driver you downloaded for the mouse afterwards.
My next suggestion your be to try the mouse on another computer to make sure it is not defective.
Jan 15, 2008 | Razer Copperhead RZ01-050100-R1M1 Mouse
Mouse cutting out
Wish i had a proper solution for this, but im getting the same problem but have found out something interesting....
I recently formatted my machine (xp) and i didn't have a single problem for about 4 weeks!
I have an idea that its a windows update that causes the problem.
Oct 17, 2007 | Razer Copperhead RZ01-050100-R1M1 Mouse
Razer RZ01050300 Mouse Logo
1,318 people viewed this question
Top Razer Computers & Internet Experts
Alun Cox
Sunday Ojelabi
Sunday Ojelabi
Larry Chandler
Are you a Razer Computer and Internet Expert? Answer questions, earn points and help others
