Question about DeLonghi EAM3200 Espresso & Coffee Maker
It doesn't produce coffee after grinding. The first light on the bottom line is on.
    Problem Solver:
  • 5 Answers
If it doesn't get hot. It is probably the thermal fuse has blown. $260 is ridiculous for a $2 part from Radio Shack, they should be ashamed.
The water rising and dripping is caused naturally by the hot water and boiling/bubbling. Transmission system LOL, there are no moving parts in this part of the process. Read below for a fix if your handy.
The fix below is for the BCO120T / BCO130T models but should be the same issue.
There are thermal fuses on the bottom. You must remove the bottom cover to see them under the heating tray. If the heating does not work the water will not heat and rise (no drip - nada). I posted some pics on my ebay store.
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&rd=1&item=150370700440&ssPageName=STRK:MESE:IT
TYPICAL FAILURE OF THIS MACHINE = THERMAL FUSE MALFUNCTION.
WHERE ARE THE THERMAL FUSES: There are 2 thermal fuses under the coffe tray and 1 fuse under the espresso boiler. (YOU WILL HAVE TO REMOVE THE BOTTOM COVER OF THE MACHINE). What this fuse does is regulate the temperature of the heating element so that everything doesn't melt (yep, I tried to bypass the fuse and found out the hard way..testing...testing..). Anyway, replacement for these thermal fuses are sold at RADIO SHACK for about $2.00. (Yep, only $2.00) If you open the bottom cover of the coffee maker and you will see the 2 fuses, they look like resistors. they are covered in a plastic tube to prevent damage. Clip them off I used a small wrench(radio shack) to pry open the small clamps that hold them, replaced them, then reclamped the new fuse back on.
REPLACEMENT FUSES: The thermal fuses have the watts/Amps and temperature stamped on them. There is 1 part that I use and has been working well for over a year ( over a year, yes this machine can last a long time!!).
The part # is Labeled - Raido Shack 270-1321 Thermal Fuse 438°F (226°C) 250VAC 10A (For heating devices like coffee makers and hair dryers). The temperature may vary + - a few degrees° on the label, from what I have seen.
HOW TO TEST THERMAL FUSES: These fuses are not only used for temp control but they also close the curcuit. If the fuse blows then it is open and will not heat. I use my ohmeter (put 1 prong at each end of the fuse) and if it reads open it means that the thermal fuse is bad, it has blown, there is no current running through it. I believe a light meter can check for continuity also and are much cheaper. Test by putting the test leads at each end of the fuse (1 prong at each end).If the light turns on then you are good, getting continuity. If you cannot get no light then it is bad. You can test your light fuse with a simple wire, touch each end and the light should go on, cut the wire in the middle and no light!!easy.
fyi. If your coffee does not get hot enough the fuse may need to be replaced also.
HOW TO READ THE OHMETER.
Know that a reading of OL means "over limit." That means the resistance is off the charts, and you have a break in the circuit. If you got an OL reading for the plug wires, you'd know there was a broken wire that needs replacing. In this case, we got an OL reading because the light switch is in the "OFF" position.
Read more: How to Use an Ohmmeter ' eHow.com http://www.ehow.com/how_2282412_use-ohmmeter.html#ixzz0zwX1LcJD
Consider that a low reading, anywhere from 0 to .5, indicates very little to no resistance. This means there's a continuity of current in the circuit. This is the reading you should get
Read more: How to Use an Ohmmeter ' eHow.com http://www.ehow.com/how_2282412_use-ohmmeter.html#ixzz0zwXjz6C0
Posted on Sep 30, 2010
I bought a pre-owned Delonghi Magnifica 4400 on eBay. It would grind the beans for an espresso, but then would not complete the function. Everything seemed to work fine except the machine would not deliver water anywhere-no espresso, no rinse, no steam, no hot water. I took it to the closest authorized repair shop (about 60 miles away) and it cost $260 for them to replace the "transmission system." I've had it back a few days now and everything is working perfectly...
Posted on Apr 26, 2010
What would cause the machine to grind the beans but not produce any coffee despite the water tank being full?
Your grinder setting might be too fine. Only adjust while the grinder is grinding -- set to a coarser grind. Have you tried the preground coffee dispenser? Again, use coarser ground coffee in case the sieve is getting clogged.
Mar 27, 2015 | Coffee Makers & Espresso Machines
Grind time is short, puck is wet and sloppy, espresso weak
Sounds like you might have more than one problem.
From page 12 of the manual... NOTE THE LAST LINE.
"8. ADJUSTING THE GRINDER
• Open the lid of the bean container.
• While the grinder is running turn the grind selector switch to
the desired position (Fig. 6).
-The smaller the dots, the finer the grind.
-The bigger the dots, the coarser the grind.
Important:
The grinding grade can only be adjusted while
the grinder is actually grinding."
Sep 08, 2014 | Jura Capresso Impressa E8 Espresso/Coffee...
My Saeco Odea Go only produces weak coffee (like water). Tried adjusting the grinder and also different coffee beans. Any ideas?
have you tried adjust coffee strenght?
This is the bean symbol on the bottom of the front control
Jan 23, 2013 | Saeco Odea Go
My SAECO Talea Giro is not working. I have cleaned it properly and coffee beans and water is filled up. The red exclamation mark and the warm water lights are flashing. I can produce steam without a...
The thing that comes to mind is the brew unit is blocked and or the grind is too fine. Remove the brew unit and clean the screen under the red o-ring.
Aug 06, 2011 | Saeco Talea Giro Espresso Maker -...
Saeco odea giro is not grinding enough coffee.. the pad is like half or less than that.. it seems like a pcv problem .. HOw can I reset or reprogram to grind more coffee?
Hi,..These saeco models have a auto adjusting grinder. If the brewunit is heavy or in other words overloading, the machine will reduce the grinding time lesser to produce less ground coffee.If it senses the brewunit is smooth and light in loading (compressing the grounds), it will increase the grinding until it reaches the optimum dose. So it is important to clean and lubricate the brew unit at all times. Hope it will solve the problem. Good luck.
Jun 18, 2010 | Saeco Odea-Giro Espresso Machine
My single cup portofilter on my ECM Giotto suddendly is pouring more coffee then it should. I'm using the same grind I've been using forever. My other portofilter (2 cup) works fine and still produces the...
How old is the coffee being used? Normally if you change baskets, the grind should be the same, because the single basket has finer and less holes in it than the double basket. The only difference would be the tamp then, since the coffee grinds works great with the double basket. You would also have to use a different volume of water to produce the coffee. To produce 2 ounces of espresso you need about 3 ozs of water,(about an ounces of water will remain in the coffee).
Jul 19, 2009 | ECM Giotto Espresso Machine
Machine doesnt produce coffee
Try this, your machine has a manual/coffee grounds input, press the button for that option and see if water flows from the coffee spouts, if yes then adjust the grind on the grinder to coarser, if it gives you a ventilate error, then one of the lines to the brew unit is blocked, nd you will have to run the descale again or open machine and find blocked line and clear.
Mar 16, 2009 | Gaggia Titanium Espresso Machine
Just set up a recently purchased used Astoria argenta single and can't get a thick Espresso
Try adjusting the grind on the grinder to a finer setting, and make sure that the machine ins producing about 9 bars of pressure on the water pump(check bottom gauge on manometer).
Feb 19, 2009 | Astoria Argenta AEP-2 Coffee Maker,...
Revere Ware old fashioned coffee pot
1) Boil the water you’ll need in another pot.
2) Put 1 tablespoon of ground coffee (drip grind, not percolator grind) in the reduced diameter, perforated bottom of the brewing chamber.
3) Put the grind/water separator (the perforated, flat handled plate with cup markings on the handle) in the Brewing Chamber, over the coffee grounds.
3) Put the Brewing Chamber on top of the Holding Chamber.
4) Pour the appropriate number of cups boiling water into the brewing chamber; put the lid with the black knob on the brewing chamber.
5) Let the water drain through the coffee grinds (5-10 minutes).
6) Remove Brewing Chamber, clean out the coffee grounds, and replace the lid on the holding chamber.
7) Enjoy your coffee! Keep it warm on the stove at LOW heat setting.
for the most information on the Revere cookware lines, go to: http://mysite.verizon.net/vzeoywo4/theshineshop2/id1.html
Charlie
Jun 16, 2008 | Coffee Makers & Espresso Machines
DeLonghi EAM3200 Espresso & Coffee Maker Logo
467 people viewed this question
Top DeLonghi Coffee Makers & Espresso Machines Experts
Paul Bade
Are you a DeLonghi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
